Re: Cast tooling plate print bed flatness December 01, 2016 04:02AM |
etfrench
You can calculate how much expansion the bed will have using tools on this site: [www.engineeringtoolbox.com]
I'd also recommend using socket head machine screws with a counterbore instead of countersunk flathead machine screws. The later won't allow expansion.
Re: Cast tooling plate print bed flatness December 01, 2016 07:46AM |
Re: Cast tooling plate print bed flatness December 01, 2016 01:10PM |
Re: Cast tooling plate print bed flatness December 01, 2016 03:21PM |
Re: Cast tooling plate print bed flatness December 01, 2016 03:37PM |
Re: Cast tooling plate print bed flatness December 01, 2016 04:01PM |
Re: Cast tooling plate print bed flatness December 04, 2016 04:02PM |
Re: Cast tooling plate print bed flatness December 04, 2016 04:43PM |
Re: Cast tooling plate print bed flatness December 04, 2016 05:16PM |
Re: Cast tooling plate print bed flatness December 04, 2016 11:57PM |
Re: Cast tooling plate print bed flatness December 05, 2016 01:40AM |
Re: Cast tooling plate print bed flatness December 05, 2016 10:42AM |
Re: Cast tooling plate print bed flatness December 05, 2016 11:53AM |
Re: Cast tooling plate print bed flatness December 05, 2016 04:17PM |
deckingman
I think that if you buy machined tooling plate, it'll be guaranteed flat to the type of tolerance we need but check with the supplier. Here in the UK we can buy ECOCast aluminium tooling plate which is precision machined both sides.
Re: Cast tooling plate print bed flatness December 05, 2016 04:37PM |
simspeed
There are a couple of issues using glass in my scenario. First the size of the glass to cover my bed is larger than I'd like to handle on a regular basis. The machine will be fully enclosed in Lexan where the end panels are fixed and the front and back are sliding doors framed in 2020. The doors only slide open to roughly 80% so it won't be easy to remove a large plate of glass with the print attached. I can use smaller pieces of glass for smaller prints when necessary which will work considering that the silicone heater I ordered is zoned for smaller prints . I plan to cover the full plate with a sheet of PEI for the print surface. I probably won't be printing many single large prints but do plan to print a number of smaller ones at the same time. Based on accounts, the PEI is the best medium to use for the print bed surface. I do have a couple of large pieces of oven door glass that I want to run a dial indicator across once I get the bed locked down. It will be interesting to see how flat they actually are. Thanks for the feedback...TP.
Re: Cast tooling plate print bed flatness December 05, 2016 05:12PM |
Chorca
Using a BLTouch and doing a verbose grid bed level routine, I can get the values that Marlin sees whlie performing the grid leveling. By entering them into a spreadsheet and doing a conditional coloration, it shows my bed has a bit of a curve to the sides:
So, I need to try and straighten the bed out manually (bending it over something) or by fixing the height of the sides and using pressure in the center to attempt to force the bed back into shape while attached to the printer.
Re: Cast tooling plate print bed flatness December 05, 2016 05:24PM |
dc42
If you print PLA on PEI then you may find that it sticks too well. I sometimes have to put the bed + print in the freezer to separate them. PrintBite may be a better option for printing PLA on if your print bed will be non-removable.
Re: Cast tooling plate print bed flatness December 05, 2016 07:37PM |
Re: Cast tooling plate print bed flatness December 05, 2016 08:09PM |
Re: Cast tooling plate print bed flatness December 06, 2016 01:58AM |
simspeed
dc42
Thanks for the info dc42.....do you heat the bed when using PLA? I've read accounts that some do and some don't. MY printer will be fully enclosed so I could heat the inside separately from the bed heater using heat strips down either side of the Z gantry rails. I'm just planning to experiment to see what works best but certainly I could use smaller sheets of glass for PLA prints if necessary. I'm hoping to be able to print almost everything on the big plate with the PEI sheet coating. Has anyone tried using a thick sheet of PEI rather than the thin film sheets? I was at Colorado Plastics today getting some 6mm PVC sheet for my frame skirt and noticed they have Ulterm/PEI in large sheets and thicknesses. Damn pricey of course so there'd have to be some serious advantages to go that route.
