ERR:MINTEMP triggered by X-motor October 12, 2016 03:36AM |
Re: ERR:MINTEMP triggered by X-motor October 12, 2016 06:53AM |
Re: ERR:MINTEMP triggered by X-motor October 12, 2016 02:54PM |
Re: ERR:MINTEMP triggered by X-motor October 12, 2016 04:17PM |
Re: ERR:MINTEMP triggered by X-motor October 13, 2016 08:18AM |
Re: ERR:MINTEMP triggered by X-motor October 16, 2016 05:10AM |
Re: ERR:MINTEMP triggered by X-motor October 16, 2016 07:59AM |
Re: ERR:MINTEMP triggered by X-motor October 16, 2016 08:45AM |
Le_Nya
@orictosh I am very embarrassed to admit it, but I didn't really got the test you described. Did you meant trying to pull off plug marked 1 on a picture and connecting it to the place marked 2? This one I already tried, that's how I learned that motor itself is working OK. Can I ask you, please, to explain in a bit more details?
Re: ERR:MINTEMP triggered by X-motor November 20, 2016 05:29PM |
Re: ERR:MINTEMP triggered by X-motor November 20, 2016 10:09PM |
Re: ERR:MINTEMP triggered by X-motor November 21, 2016 11:33AM |
Re: ERR:MINTEMP triggered by X-motor November 21, 2016 11:44AM |
Lymphomaniac1
Denuk:
You say that you are using a Mega2560 board with a RAMPS 1.4 Board and your version of Marlin is
version 1.0.2 Make sure you edit the configuration.h file in Marlin. To see how this is done see [www.youtube.com]. Your board in version 1.0.2 should be #define BOARD_RAMPS_13_EFB . (Yes RAMPS_13 is right since it covers both RAMPS 1.3 and RAMPS 1.4.) The default in version 1.0.2 is for the Ultimaker board. If you have the wrong board defined here anything can happen since the pinout is different with different boards. On one board pin xx may control the temperature while on another it may control a motor. Go through the entire youtube video and do ALL the changes necessary as explained by Tom. If you do this your board should work.
Re: ERR:MINTEMP triggered by X-motor November 21, 2016 11:55AM |
Re: ERR:MINTEMP triggered by X-motor November 21, 2016 12:17PM |
Re: ERR:MINTEMP triggered by X-motor November 21, 2016 01:58PM |
Re: ERR:MINTEMP triggered by X-motor November 23, 2016 09:58AM |
Re: ERR:MINTEMP triggered by X-motor November 24, 2016 03:43AM |
Re: ERR:MINTEMP triggered by X-motor November 24, 2016 09:13AM |
Re: ERR:MINTEMP triggered by X-motor November 24, 2016 01:22PM |
Re: ERR:MINTEMP triggered by X-motor November 24, 2016 02:13PM |
Re: ERR:MINTEMP triggered by X-motor November 24, 2016 02:16PM |
Re: ERR:MINTEMP triggered by X-motor November 24, 2016 05:57PM |
Le_Nya
Hi everyone.
Well CreateBot Tech's support officially confirmed that this most probably is a short circuit or some kind of internal fault inside the stepper driver. Obviously they claim that this isn't covered by a guarantee (such a surprise xD )
Since the driver is integrated into board and cannot be replaced separately, I will order a new board. Thinking about classic Arduino with RAMPS 1.4 and removable a4988 stepper drivers.
As soon as I will get a new board I will update this thread if everything is working, or problem still persists.
Re: ERR:MINTEMP triggered by X-motor November 25, 2016 02:41AM |
Re: ERR:MINTEMP triggered by X-motor November 25, 2016 02:21PM |
Re: ERR:MINTEMP triggered by X-motor November 27, 2016 08:03PM |
Re: ERR:MINTEMP triggered by X-motor December 10, 2016 06:23PM |
Re: ERR:MINTEMP triggered by X-motor September 27, 2017 03:04PM |
