Howto reconfigure driver for extruder motor
October 24, 2018 01:04PM
My extruder went total dead after 4 years of service. After troubeshooting I defined that the motor driver on board is bad. So I need to use my left over free motor drive.
How can I make my Prusa use this free motor drive instead of my default one, once I move connector and motor chip.
Like you can see in attached file I want to move from red arrow location to black arrow location.
Edited 1 time(s). Last edit at 10/24/2018 01:19PM by sidhabo.
Prusa i3 Reworked, Delivered March 28 2014, RAMPS 1.4
Göteborg, Sweden
open | download - PrusaBoard.jpg (213.8 KB)
Re: Howto reconfigure driver for extruder motor
October 24, 2018 03:35PM
I figured it out eventually.
Found my motherboard type in Configuration.h (33)
Then in pins.h I located the pins def for my motherboard.
So I just exchanged the pin numbers for extruder 1 and 2 there
#define E0_STEP_PIN 36
#define E0_DIR_PIN 34
#define E0_ENABLE_PIN 30
#define E1_STEP_PIN 26
#define E1_DIR_PIN 28
#define E1_ENABLE_PIN 24
Didn't work at first sad smiley
But then I got aware, moving my motorchip and connector , I missed out on also moving the 3 jumpers that is located under the motor chip smoking smiley
All this done I realized I could instead just have defined Extruder 2 in Repetier and used that ... not messing with the pins.h , recompile/reload.
See if I can run another 4 years without board failures he he
Göteborg, Sweden
October 27, 2018 04:22PM
Or just swap the step sticks...
Kind regards
Imqqmi
NFAN CoreXY printer:
[reprap.org]
October 27, 2018 06:15PM
imqqmi
I don't understand step sticks. Can you clarify.
Göteborg, Sweden
October 28, 2018 06:39AM
What you call motor driver is also known as a step stick. You can move them to other locations, or replace them if they fail.
Kind regards
Imqqmi
[reprap.org]
October 28, 2018 07:19AM
imqqmi
Ok, thanks for explaining. Well my conclusion is that my step stick and motor is ok. I just moved the step stick to the free location on RAMPS board. So problem was that old location on RAMPS board is failing. Seems like that free location is pre programmed for second extruder .... at least in Repetier.
Göteborg, Sweden
October 28, 2018 10:34AM
Ah, so maybe a trace is blown, or a solder joint has gone bad?
Kind regards
Imqqmi
[reprap.org]
October 28, 2018 01:57PM
Yes. At the moment I won't bother to take it apart and investigate. Just happy I have it working on the free location.
Göteborg, Sweden
