Smooth Bolts for Idler bearings's (instead of threaded screws) August 14, 2019 09:36AM |
Re: Smooth Bolts for Idler bearings's (instead of threaded screws) August 14, 2019 10:55AM |
Re: Smooth Bolts for Idler bearings's (instead of threaded screws) August 14, 2019 11:06AM |
Re: Smooth Bolts for Idler bearings's (instead of threaded screws) August 15, 2019 03:12AM |
Re: Smooth Bolts for Idler bearings's (instead of threaded screws) August 15, 2019 12:06PM |
Re: Smooth Bolts for Idler bearings's (instead of threaded screws) August 15, 2019 04:58PM |
Re: Smooth Bolts for Idler bearings's (instead of threaded screws) August 15, 2019 05:57PM |
Re: Smooth Bolts for Idler bearings's (instead of threaded screws) August 16, 2019 02:29AM |
Re: Smooth Bolts for Idler bearings's (instead of threaded screws) August 16, 2019 11:36AM |
Nice little Bearing Block pity about them screws.Quote
the_digital_dentist
I had a piece-o-junk from something I took apart years ago with two 1/4" bearings press fit into it. I needed to make an idler pulley for the Y axis in one of my printers and discovered that an off-the-shelf 20 tooth GT2 pulley fit perfectly between the bearings. IRIC, I put two small washers on either side of the pulley to ensure that it could only contact the inner rings of the bearings. I had a 1/4" shaft from some other piece of junk I took apart.
Re: Smooth Bolts for Idler bearings's (instead of threaded screws) August 16, 2019 02:07PM |
Re: Smooth Bolts for Idler bearings's (instead of threaded screws) August 17, 2019 12:42AM |
Re: Smooth Bolts for Idler bearings's (instead of threaded screws) August 17, 2019 02:55AM |
Re: Smooth Bolts for Idler bearings's (instead of threaded screws) August 17, 2019 03:27AM |
Diggrr
I was pondering last night about spring pins, using a close fitting clevis or yolk with the same size holes to contain the bearing and pin. They're basically a spring steel tube with tapered ends made to drive into a dowel hole, but hold with outward spring tension instead of adhesives or an interference fit.
Untried, but a thought none the less.
It doesn't take a great deal of force to insert a spring pin, so unlikely to damage the bearing.
Probably not useful for a one sided mount.
Re: Smooth Bolts for Idler bearings's (instead of threaded screws) August 17, 2019 05:42AM |
Re: Smooth Bolts for Idler bearings's (instead of threaded screws) August 17, 2019 04:32PM |
etfrench
Actually, shoulder bolts were not designed for bearings although many people use them for this. Most shoulder bolt shoulders are .002" to .004" undersized which makes for a very loose fit in a bearing. McMaster-Carr has precision shoulder bolts which are -.001" to 0" and would be a better choice.
Re: Smooth Bolts for Idler bearings's (instead of threaded screws) August 19, 2019 10:58AM |
cozmicray
etfrench
What were shoulder bolts designed for?
