Re: Migbot Prusa i3 Unofficial Support Thread November 30, 2015 10:10PM |
Re: Migbot Prusa i3 Unofficial Support Thread December 01, 2015 04:39AM |
Re: Migbot Prusa i3 Unofficial Support Thread December 01, 2015 10:03PM |
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 12:37AM |
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 12:41AM |
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 03:42AM |
Wes78
Hello everyone as I am new to the thread and new to the 3d printing world, and I am to one of the suckers that bought the Electron 3D - Sixth Generation Prusa i3 from the worst place on the planet..... www.3dprintersonlinestore.com
Link to the one I bought [www.3dprintersonlinestore.com]
How I wish I found this thread 3 days ago before I purchased it, they tell me its too late to cancel so I'm pretty much stuck with it.
I decided to step into this hobby due to my other hobby which consists of building and flying multirotors, now that the winter months are upon me it seems like it would be a good time to invest into 3d printing. As I plan on designing and building mounts and various types of micro multi-rotors,
I am a CNC Machinist by trade so this in the same territory of the machines that I run.With being a CNC mill machinist I already see me upgrading the printed parts with billet aluminum, as I see many of the problems that I've read in this forum is badly printed printer parts
Anyway to the matter at hand..
I have not yet received my printer so I'm not 100% sure on what all the obstacles that I'm going to encounter, I have spent the hole day reading through this entire thread, there's lots of good information and I have definitely appreciate finding this thread as I would have had a headache trying to figure it out by my onesies.
My first question.. is there anyone actually running this on to 220 vs 110? (I live in the usa)
And is there any advantages to running on 220 perhaps more efficient power consumption wise?
I'm going to be running the printer on a dedicated breaker so it wouldn't be too hard for me to wire it for 220.
My next question would be is it even worth messing with the FM that actually came on the SD card( if it isn't corrupted) or should I just go ahead and flash it with Marlin?
next question, Is there any real advantages over using CuraEngine over Repetier-Host? (I assume this has something to do with witch FM I run?)
I have a flash things with the Arduino before.. But I'm the type of person that likes to have a good guide before i get started I like to fully understand something before I actually do it, it is likely flashing the Marlin filmware will be like flashing anything else, but with that said does anyone have a link to a guide on how to flash to this particular board?
Once my printer gets here I will document everything here, what troubles that I ran into in the modifications that I've done, this thread has been invaluable and I want to keep it going.
Thanks for your advice and wonderful information that this thread has offered
Wes.
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 03:51AM |
veaceonee
gwc2795
veaceonee
Any idea why the LCD goes all fritzy during prints? Does it every time about 5 minutes into the print. Still prints ok.
When it does it measure the 5V line to make sure you are not having a voltage drop.
forgive the noobness, which one is that?
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 04:16AM |
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 04:19AM |
Marty77
@ Wes78
I purchased the same one about 3 weeks ago - had the same questions
Let me tell you - the support of this company - I bought it via EBay isnt really that good - but I have to say with a few mods the printer is for that price quite decent.
Ive seen much more worse products coming out of china ;-)
- Powersupply - use what you have - if you just have 110 - -use it
- defenitely a better cable (bigger diameter) froom the PSU to the Mainboard - also upgraded the cable froom the Manboard to the heatingbed
- regarding FW: I was asking the company that they would please send me a copy of the FW that is ACTUALLY on the board when they sell it - that if I mess around I still could go back to original - no luck - no response
there is also no easy way of "backing up" the FW installed
I played around anyway - the steps where total off for example - printed not the right sizes
- I use Slic3r - as standalone or even more often now in Repetier Host - I got very used to it now and it does a decent job - if the settings are right ;-)
Like I said - its for me also my first 3D printer - and I think for that price quite ok and really does some nice decent prints - I expected a lot worse
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 04:24AM |
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 04:51AM |
Marty77
Ax - thanks - thats good to know - in case of a needed backup ;-) but then they have there 3 different versions - or at least 2 of each kind
whats the best having my autolevel kicked out - 1.0.2 or the stable or the one just labeled "Marlin" ?
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 05:07AM |
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 05:43AM |
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 06:53AM |
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 09:32AM |
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 09:42AM |
Wes78
Thanks guys for the reply's and good advice
Ax- I totally forgot about mentioning what options I bought.
Unfortunately... I didn't know at the time I could add them later for much cheaper.
I had got the "pro" mk8 and self leveling.
Since I have self leveling were you referring that I need to flash the firmware?
Setting the Z off that I think was mentioned more than once in the form I'll read back again as a reference. reading everything in one day kinda mushe'd it together so I need to go back and reread
Thanks again
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 11:05AM |
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 12:31PM |
Marty77
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 12:42PM |
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 12:43PM |
gatorNic
Marty77
Exactly. First 3d printer, expected worse, but pleasantly surprised it works pretty well. The biggest thing for me we just making sure you diligently calibrate all the axis. Most important the z-axis and the extruder steps. Next up was having a level, unwarped print surface. I just went ahead and got a glass surface and gave up on the cheap aluminum sheet. Saves a lot of pain in the long run. Other than that I have had very good results, atleast to what I was expecting.
Seems most of the trouble I have seen people have has been from a faulty/underpowered power supply. Mine seemed ok out of the box. Powers fine, I can reach 110 degree bed in about 10mins.
Wes78
Awesome thank you sir!
I haven't had a chance to look the wiki page over but I will when I can.
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 12:51PM |
Ax
Yeah, both mine have issues hitting 80 rapidly, 24v supplies are the next on the list along with replacing the crappy LM8UU and SC8UU bearings on the first one. Glass plates are the way to go, even with auto levelling. You can just use metal contact points on the plate to level off, I'm using copper tapes
Re: Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 01:04PM |
CrackinX
Well I have been working on my rework for well over a month now and think I have it pretty good. Everything is solid, I have it bridging really well at 30mm, haven't tested much more than that but I think it will do double that fine.
I will post a link to my STLs here but it is also in the migbot wiki if you need it in the future without digging through here.
DISCLAIMER: I can not take credit for a good portion of items here as most I got from thingverse and reworked to fit the Migbot. However a good chunk I did design from scratch
[drive.google.com]
I am still working on the under carriage cable management and will add things as I finish them.
All parts are printed from PLA but I have my hotend insulated with a silicon self fusing tape I got from home depot for $6, It's good up to 500F (260C) which should be good for anything up to nylon. It keeps the heat in real well I can touch the hotend for a few seconds before it gets too hot to touch but does not radiate heat.
Hope this helps somebody!! As always if you guys have any questions feel free to ask.
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 01:19PM |
Wes78
Ax
Well that brings me to two more questions lol
Where is the best place to be replacement parts such as the bearings.
And I know there's different types of glass. And there are better types to use. Can you recommend one for me and a link if you can spare the time.
As always thank you
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 01:30PM |
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 01:35PM |
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 01:37PM |
Wes78
What mods did you do to your bed?
I've seen a few on here such as change to a bigger gauge wire and insulating underside of the bed
Wes78
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 01:46PM |
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 01:53PM |
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 02:03PM |
Re: Migbot Prusa i3 Unofficial Support Thread December 02, 2015 02:27PM |
gatorNic
So you haven't even gotten the printer yet? Why don't you just try it with the current hotend? I mean the mk8 is no e3d but its not bad either. I get fine results with it.
If I was going to get a e3d a would probably just get the full one. If I am doing an upgrade like that I would want to be able to use hotter temperatures for different materials. Plus to make the e3d work you need to print new brackets...but if you don't already have a working printer how would you do it?
