Re: Migbot Prusa i3 Unofficial Support Thread January 25, 2016 08:19PM |
Ax
IBaz
IBaz
HELP!!
I have had my Migbot for a while now and after many months of tweaking and modifying I have slowly been working it out and getting to grips with it.
The problem I have is that while I have the larger bed I have never been able to use this whole area. My printer seems to have only come with firmware for the smaller bed installed. In the beginning I had a real hard time getting it to connect to my PC but eventually worked it out. Since I have moved on from there I have not had the printer connected for some time as have been printing from the SD card. Having put it off due to the fact that I have really no idea what I am doing I decided to try and update to the larger bed firmware. The first problem arose when I could no longer connect the printer via USB. Again it was just not recognized. After what seemed like forever I managed to install the drivers and it seemed to be connecting. Although it connects in Repetier I cannot manually control the printer, nothing moves at all. In Cura when I tried to print via USB and even though it was again recognized it would not connect to the COM port and I would just get a 'closed' error when trying to open the serial port after pressing 'print with USB'
After I gave up with this I decided to try and update the firmware. Having no idea where to start I trolled the internet on how to perform this and finally got the guts up to give it a go. This is where my woes continue. I can load the firmware into Arduino and adjust the settings for my printer but when I try to load I just get a timeout error. After trying this multiple times I have given up and now ask for help.
Can anyone help explain as to why I cannot fully connect my printer even though it used to work properly. I assume this may also be why I cannot update the firmware.
This printer has now been working well after multiple upgrades and has been giving me some great prints. I really hope someone here can help with my connection problems.
Are you running Windows? If so, check device manager and see if there's any unrecognised devices. If so, it may be worth updating the driver from here. Also check the baud rate, it should be 115200.
Yes I'm running Windows 7
I have tried all the above and the printer is recognized in device manager. As stated it connects through Repetier and Cura but just wont talk to the PC so I cannot actually do anything. I have tried two different computers and have the same problem. I don't know what else to try. I just hope it's something I have overlooked as it used to work just fine in the past.
Re: Migbot Prusa i3 Unofficial Support Thread January 25, 2016 08:31PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 26, 2016 03:52AM |
IBaz
Using the original USB cable that came with printer. I did have a problem with another cable when I first got the machine together. This cable is the only one I have that will work with it.
I cannot get any errors in Repetier as it wont talk to it to receive anything. I can hit connect and it becomes connected but referring to the manual control screen it gets no information from the printer. It doesn't display temps or anything and will not respond to any commands.
It will and always has printed from the SD card. The only reason I want to connect to USB is to update the firmware for the larger bed however cannot connect through Arduino IDE either and just get a timeout error. Just trying to connect through Repetier or Cura first as a stepping stone to Auduino.
If this means anything when trying to print over USB from Cura I get the following;
Cura displays "Opening Serial Port"
The LCD display on printer resets
The blue "L" LED on board flashes twice followed by two flashes of the "Tx" LED
After a long pause the "Rx" LED flashes once, pauses then flashes a second time.
Cura then immediately displays "closed" in the window and nothing happens.
It's like its trying to communicate but something is wrong.
Is there any other program or something that I can use to test communication with the board?
Re: Migbot Prusa i3 Unofficial Support Thread January 26, 2016 06:21AM |
Ax
IBaz
Quick question, tried re-flashing the firmware?
Re: Migbot Prusa i3 Unofficial Support Thread January 26, 2016 07:46AM |
Re: Migbot Prusa i3 Unofficial Support Thread January 26, 2016 08:34AM |
IBaz
Re: Migbot Prusa i3 Unofficial Support Thread January 26, 2016 09:51AM |
IBaz
Ax
IBaz
Err, that's exactly the problem I am having and what I'm trying desperately to fix here. I CANNOT connect to the printer to be able to re-flash, update or do anything else with the firmware.
I found a thread with others having what sounds like exactly the same problem but still no solution is given.
I think I may have to try another board as this one sounds like it has clapped out.
veaceonee
Does anyone know if this will work for our printers to enlarge the bed? It attaches the same way, and is the same width as the standard bed, so it SHOULD work.
Re: Migbot Prusa i3 Unofficial Support Thread January 26, 2016 10:27AM |
veaceonee
Bed upgrade
Re: Migbot Prusa i3 Unofficial Support Thread January 26, 2016 10:42AM |
spinracing
Did a test print last night, and ran it at 50mm, 50 percent infill, and no skips now that things are lighter.
Gonna kick off another couple more complex prints and see what i get.
Re: Migbot Prusa i3 Unofficial Support Thread January 26, 2016 01:44PM |
spinracing
spinracing
Dont mean to be wierd quoting myself. I just wanted to have context to this print.
At 50MM I had ZERO skips.
Parameters.. printing PLA, 210C, bed 40C with walmart generic masking tape. (sticks well to the bed, but leaves no residue) (I get nicer initial few layer stick at 40C vs cold(house is 67F))
The print job in the picture is this one Swivel Filament Guide
First not so good print. My print
Couple issues.
1st I should have changed the orientation.. but it was late, so just plopped them down and kicked print.
2nd At 50mm I got some webbing between the parts, and some blobs off the sides. Im pretty sure if I did the 50MM print to a single object that would be an issue.
3rd As I had them both on thier sides, the fill everywhere setting ended up making a lot of extra fill. Which may have contributed to the fuzziness.
Print time IIRC was like 2.5 hours.
I will clean it up and then when I get home re-print it with the proper orientation for a cleaner result.
Re: Migbot Prusa i3 Unofficial Support Thread January 26, 2016 08:02PM |
spinracing
spinracing
Couple issues.
Re: Migbot Prusa i3 Unofficial Support Thread January 27, 2016 02:13AM |
Wes78
IBaz
have you tried a different baud -rate other then 115200? mine was default at 250000 since then Ive changed it to 115200 though
Re: Migbot Prusa i3 Unofficial Support Thread January 27, 2016 06:44AM |
Re: Migbot Prusa i3 Unofficial Support Thread January 27, 2016 12:29PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 27, 2016 01:09PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 27, 2016 01:40PM |
Wes78
Do you have an example of 2 parts, where one layer fan was run vs running with 2?
dose the fan shroud come down around the hotend or just stop right before?
Im trying to decide if i want to mess with putting 2 fans on.
The shroud im using actually goes around the tip and is almost to the edge on the heaterblock on the other side
Re: Migbot Prusa i3 Unofficial Support Thread January 27, 2016 02:19PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 27, 2016 02:26PM |
Wes78
Hmm interesting... thank you
I may just give that a try on the Openbeam printer build im doing right now, hopefully there is enough room with the carriage that i designed..
did you print that with ABS?
Re: Migbot Prusa i3 Unofficial Support Thread January 27, 2016 02:46PM |
Ax
Wes78
Er, one is a mix of ABS (Shroud) and ColorFabb NGEN (Vents) (Black), one is Colorfabb PLA/PHA (Shroud) and ColorFabb_XT (one vent) (doesn't actually get that hot) (Orange) and the other is ColorFabb NGEN (Blue). Doesn't really matter what you print it in, my preference would either be XT or NGEN, can stand heat and are a metric feckton easier to print than ABS.
Re: Migbot Prusa i3 Unofficial Support Thread January 28, 2016 02:10PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 28, 2016 02:21PM |
AccidentalWisdom
So, I've got my printer up and running (sort of), got my first two (semi)successful test prints out, along with a few failures.Printed this thing. Even the two that printed have the same problem as those that didn't - the piece is not adhering to the bed well. Most of the prints get to a few layers and then were pulled from position, dragged around with the nozzle
On the two that printed fully, the adhesion was just enough to withstand the printing, but the bottom of the piece is terrible and the edges all the way up are jagged (like a spinal cord effect), while the sides are actually quite impressively nice. When the print was done, I was able to pull it off the bed immediately with my fingers with almost no resistance.
Using Cura, all layers were at .2 mm. Used hairspray for one and Elmer's glue stick on the other, both seemed to work equally well. Initial layer speed at 15, then at 30 for other layers. Fan speed at 60 (weirdly, my nozzle fan doesn't seem to trigger until I manually spin it once with a finger).
I think the real problem is that the initial layer is printing too high. At .2 mm as the filament comes out it is suspended in the air and pulled down by gravity. When the nozzle turns a corner the filament gets dragged in that direction before laying on the bed, so instead of all 90 degree angle I'm getting some 75 degree angles, creating just a mess on the first couple layers. After the first couple layers, when there is a bed of PLA to stick to, the rest of the layers print nicely (aside from the spinal cord effect on the edges).
Question 1: Should I be setting the initial layer so that the filament is actually slightly squishing against the bed?
Question 2: When my printer begins printing, it does not print in the center of the bed (even though in Cura the item is centered). Both the X and Y Axises seem to think the bed size if 5" x 5", instead of 8" x 8". Last I looked at the firmware I believe I saw some offset lines, I understand that I can change those. Is that all I need to do on this - just try to find the perfect combination of offsets to tell it where center is?
Question 3: I want an auto-leveler! I have the Migbot Prusa i3 (obviously, since I am here, haha). Can I get suggestions on the best proximity sensor to use (I've seen two types: this and that)? What about Inductive vs Non-Inductive? And also, for the type you suggest, can you provide a link or STL for a mount that would work on my Migbot? I searched Thingiverse a bit but didn't find any mounts that seemed to look like they would fit.
Re: Migbot Prusa i3 Unofficial Support Thread January 28, 2016 02:43PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 28, 2016 03:04PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 28, 2016 03:12PM |
Wes78
AccidentalWisdom
I only have tine to answer your first qustion
Question 1. YES! defiantly. I run my initial layer 70-80% of the other layers., needs to be slightly squishing against the bed, this is key to sticking well
also ive had really good luck using watered down elemer;s gule (extra hold school glue) clean up with Windex
Im am worknig on a new x-carrage and sensor mount that ill be uploading to thingiverse hopefully by this weekend ill post it here see if its something you like
Re: Migbot Prusa i3 Unofficial Support Thread January 28, 2016 03:15PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 28, 2016 03:37PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 28, 2016 03:48PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 28, 2016 07:56PM |
AccidentalWisdom
Re: Migbot Prusa i3 Unofficial Support Thread January 28, 2016 10:38PM |
Re: Migbot Prusa i3 Unofficial Support Thread January 28, 2016 10:42PM |
