Re: thermistor location? power cable connections? August 07, 2015 09:06AM |
therippa
Steve_in_NJ
wderoxas
Steve_in_NJ
Greetings all,
Here's my first msg here. I have gone through a lot of the thread - tons of great info!
I have two questions, both related to my build which is 90% complete.
1) The tape holding the thermistor to the heatbed let go so I need to re-do it. While I am at it I should ask - where precisely should the bulb-tip be placed? I had it right in the hole in the middle of the heatbed, essentially filling it level with the surface. Is that best?
Yes, it should be inside the hole. Its best if you can make the bulb-tip to be in contact with whatever build plate your going to use on top of the heated bed (glass or aluminum bed).
Uh, WHAT build plate on top of the heated bed? I didn't know there needed to be another plate on top of the red bed. What is appropriate/typical? Can one not print directly on the red bed?
You can, but you probably won't be happy with the results. The Folgertech website tells you you will need a 8x8 piece of glass ( [folgertech.com] ), you can get them on Amazon for ~$13 [www.amazon.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 07, 2015 10:12AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 07, 2015 10:57AM |
Re: thermistor location? power cable connections? August 07, 2015 11:41AM |
mel0n
therippa
Steve_in_NJ
wderoxas
Steve_in_NJ
Greetings all,
lolwut, you can get the same thing not tempered at lowes for $2...... I have been using the same piece of glass since I built my printer and have never had an issue or broken piece of glass.... and I print primarily in ABS with the bed at 100C
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 07, 2015 11:46AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 07, 2015 12:01PM |
Blackbird
My X, Y and Z are colliding with my endstops but they keep moving. The led is triggering on the endstops. I'm using Repetier-Host.
Is there a way to see if my endstops are functioning properly? I'm 100% new to any of this.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 07, 2015 01:38PM |
TimJC
Before I place an order with FT, are there any spare/extra parts that you guys would recommend adding to the order? I already have the graphical LCD coming from BangGood, so I am thinking more along the lined of stuff like extra nozzles, thermistor, heater cartridges, fans, etc.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 07, 2015 01:54PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 07, 2015 03:12PM |
TimJC
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 07, 2015 03:15PM |
Nargousias
Mark,
As far as glass was concerned I went to lowes and purchased one piece of 24" x 26" 3/32" thickness clear replacement glass for $8.36. I had them cut it into 8x8x8 squares and ended up with nine pieces. They charge for cuts after the first two but the cost is minimal something like 20₵ per cut. It took three cuts and cost less than $9 for nine pieces (not counting taxes). There was two inches of waste but they threw it in their recycle bin and wrapped my nine pieces. I did it this way so I did not have to clean the glass immediately before printing again.
The cut pattern Looks like this:
Red represents the cuts made.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 07, 2015 10:21PM |
It does help! A lot! Thanks!Quote
rrowan327
Blackbird
Hi Blackbird,
In repetier-host, click on the manual tab and where is shows G-Code. Enter M119 then click send.
If your extruder is away from the end stops (ie: center of the table) none of the end stops should be triggered.
Next hold down with your hand one of the end stops and use M119 command again, It should now show that end stop triggered.
Continue to test each end stop that way. If one or none of them seem to work check the wire for the end stop and connector to the board. There has been issues with poor quality connection between the wire and wire connectors. Also be sure you have plugged them into the correct spot on the ramps board. Each end stop has two position settings on the board (min, max) and the values in the firmware should match. Otherwise the Arduino board has no idea where the start and stop points are for each axis (x, y, z)
I hope that helps
Rick
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 07, 2015 10:38PM |
RedneckGeek
blank64
Hi all,
I recently got one of these kits and am mostly done putting it together.
Something that has me worried is that one of my stepper motors seems to have no hold (I can turn it by hand with no effort while the others put up a lot of resistance), the back area where the cords plug in also seems kind of loose compared to the others. Does this mean it is broken? Is it safe to test it out in my ramps board?
The motors are spin freely until they get voltage through them from the controller, then you can't move them. This is normal. You can probably feel the ratcheting from the magnets when you turn the shaft by hand.
What part is loose? You may just need to tighten the screws.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 08, 2015 07:20AM |
Blackbird
rrowan327
Blackbird
Hi Blackbird,
I hope that helps
Rick
I believe my RAMPS board is defective. I was having problems with my X endstop not triggering properly. I was adjusted the configuration.h settings (I was having the typical shifty x-asix movement) and reflashed the board and my Y axis suddenly went haywire and pushed past the endstop and crashed down onto the bed. Since then the Y axis hasn't moved well and is squeaking and none of the endstops work. They all light up red when the switch is pushed but they're showing triggered when I m119 regardless of what I've done. I've changed the settings in configuration.h to false and true but nothing makes any difference.
So I've ordered a replacement RAMPS (the more expensive one animoose posted) and replacement endstops just in case. Should hopefully be here by the middle of next week. I suspect a lot of the problems I've been having are due to a poor quality RAMPS. My adjustments in Marlin were simply changing the x_home from 1 to -1. I didn't do anything to cause the endstops to suddenly stop triggering.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 09, 2015 08:02PM |
kn4ud
I have also noticed in all my prints at the end it seems to not completely finish.
M400 ; wait for buffer to clear M104 S0 ; turn off temperature G28 X0 ; home X axis M84 ; disable motors
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 09, 2015 08:25PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 09, 2015 08:52PM |
[email protected]
I'm working on modifying the x-carriage design by wderoxas, I'm trying to add a adjustable z-endstop screw. I'm having a hell of time since I have never used any type of 3d modeling programming. I will keep plugging away at it but no clue what I'm doing yet!!!
[dl.dropboxusercontent.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 09, 2015 09:00PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 09, 2015 09:46PM |
Mach
[email protected]
Did you import the model as a STL. If you did, remember to try to remove as many unnecessary lines as possible. It will make working with the model much easier.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 09, 2015 10:21PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 09, 2015 11:14PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 10, 2015 01:58AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 10, 2015 02:40AM |
Are you sure the bearing with teeth on the motor isn't puched too close to the motor body? If it sits right against the motor housing and you have the set screws tightened, it won't spin properly. Easy thing to overlook while putting everything together.Quote
blank64
So I have now finished the build, but am now having some problems trying it out with repetier: (I tried both the marlin included in the drive folder, and the one posted a few pages back)
My y-axis motor doesn't seem to be able to turn the belt (it either barely turns, or skips the belt entirely while turning), I used one of the included belt tensioners so it's pretty tight.
My x-axis motor doesn't seem to be working at all (Although it gets a bit warm after a couple of minutes)
Only one of my z-axis motors is actually turning (the one which I can turn by hand while off), I tried switching where the 2 motors are plugged in, but in each case the same one turns.
Has anyone experienced any of these problems?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 10, 2015 04:16AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 10, 2015 06:12AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 10, 2015 09:01AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 10, 2015 09:51AM |
corry
Biggest issue: to those who say they got the kit assembled in 4 hours are you *SURE* you have those t nuts rotated in the slots 90 degrees? All of them? They're awful. I know misumi's preinstall t nuts cost a bit, but those (m4) post install t nuts are absolute garbage. Spent hours on single bolts sometimes. Was ready to go to the garage make some thermite just to burn those witchlike t nuts. They've gotta go. Pissed me off something fierce!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 10, 2015 10:05AM |
corry
They are pretty awful (frankly I would have preferred regular pre-assembly nuts and some planning) but there is kind of a trick. If you have tweezers you can rotate them into place and as long as you don't try to back out the screw during assembly they should stay in place.
Also the earlier kits used internal corner brackets (with set-screws) so you only needed like 6 or 8 of the m4 nuts.
The instructions could use work, and I'm pretty sure with proper design they could have really cut down on the number of different fastener types used.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 10, 2015 10:13AM |
mel0n
corry
Actually, the T-nuts aren't that bad once you figure out the technique. I figured it out about half way through my printer. APPLY FORCE. Basically, just pop the nut in, orientation doesn't matter, line up your screw, and push down on the screw with a good amount of force as you tighten it. I can't really explain how it works, but at least 9/10 times it pulls the t-nut up and rotates itself into place with a good amount of bite.
So next time you use a T-nut, push on it really hard as you screw into it and I promise you will be amazed how well/easily it works.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 10, 2015 10:45AM |
zarnold16
So here is my first problem that I have received in a while except for some user error with printing. I went to click start on my print via the SD card and my screen blacked out then came back on like this. Now everytime I turn off my printer and turn it back on it comes back when I turn the dial. [imgur.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 10, 2015 10:47AM |
zarnold16
zarnold16
Okay I still have not figured this out. I just broke a blade on my extruder fan, Am I able to run the printer without this while I wait for replacement?
