Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 24, 2015 10:52PM |
LancelotL
Everything is looking really good on my calibration cube after the belt tensioner and extruder calibration. Having a tough time getting the top layer smooth though. It's kind of saggy in places. Is that a temperature issue?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 24, 2015 11:17PM |
LancelotL
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 25, 2015 12:03AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 25, 2015 01:21AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 25, 2015 09:33AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 25, 2015 12:02PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 25, 2015 12:49PM |
woodknack
animoose
My hot tip of the week: if your heat bed takes a long time to come up to temperature, try placing a paperback book on it. My second hot tip: remove the book before the printing starts.
LMAO
Tip 2 YES very important......
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 25, 2015 12:58PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 25, 2015 01:50PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 25, 2015 06:42PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 25, 2015 11:50PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 26, 2015 06:14AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 26, 2015 08:15AM |
Neverdone
I updated my slic3r to the latest version they have on their website, 1.2.9 Stable, and have been able to print again. But still some things are not printing the software will slice then immediately say stopped working, and if I try to put multiple items on the bed to print, it will freeze and crash the software. Is anyone else experiencing this?
I also ran in to another issue. I started the printer watched the first few layers then walked away from the printer. I came back and found that the print looked like crap and that towards the end of the print you can see that the x-axis started to shift to the left. I releveled the bed, made sure the belts were still tight, made sure the grub screws on the pulley were tight and started the print over. It did the same thing, but in a different spot. I think that it looks like there is too much plastic extruding out, this is causing the rough looking layer on the top of the print, then I noticed that as the printer is traveling it catches on these rough spots and I think that is what is causing it to shift the print. Has anyone seen this before? I am running the same settings that I had on black ABS, just swapped to green, but I would think the settings would stay the same. Can anyone help with this?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 26, 2015 08:16AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 26, 2015 08:18AM |
tjnamtiw
LancelotL
I used the honeycomb infill on the right and made some other refinements - mich nicer finish than the one on the left.
Absolutely! That was the ticket! How did they measure?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 26, 2015 08:49AM |
LancelotL
Neverdone
I found that you need to do several things to get a nice smooth top layer. First, go into the slic3r settings and adjust the speed for the top layers. I used 20%. Then, make sure your temperature is not to high. Finally, make sure the infill is more than just a few lines (I used the honeycomb at 40% infill). Oh and one more thing, make sure the settings you are modifiying are actually being used by Slicer. The first couple times I ran it I couldn't figure out why my changes wouldn't take. The I realize slic3r wasn't using the printer settings file I was adjusting. Bed leveling will also be a huge help. I found that i first had to level my x rails because one end was higher than the other. I eyeballed that first and then made minor adjustments using the grub screws.
Oh and make sure you calibrate the feed rate. Read back a few posts to figure that out.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 26, 2015 10:57AM |
Neverdone
LancelotL
Neverdone
I think that you misunderstood what I said, by top layer I wasn't actually meaning the top of the piece, more the last row printed. In the picture you can see what happened to the print. Towards the top of the part you can see how it shifted over during the print. Notice how the sides are rough, and the top layer in the print ended up kind of bubbly. This is what happened when I tried to rerun the print. When I noticed that I killed the print until I can figure out what is causing it.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 26, 2015 11:20AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 26, 2015 12:15PM |
Neverdone
I did not realize that it would be different from color to color. Does anyone have base numbers to use to start on these for different colors? I think that my flow rate might be too high and that might be causing my biggest issue. I would think that temps would pretty well stay the same no?
How do you enable supports? I have been wondering about that. I didn't know if I would have to draw them in or not......
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 26, 2015 06:54PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 26, 2015 07:32PM |
tjnamtiw
Tenny
Ok I got it fixed.
So if you keep the cables wired as they are in the manual this will fix it:
Change the following in configuration.h
- #define INVERT_X_DIR true to #define INVERT_X_DIR false
- #define X_HOME_DIR -1 to #define X_HOME_DIR 1
- With the printer off PHYSICALLY move the x-axis stopper to the left one set of pins (this makes it so it's the x max instead of x-min)
Now if you are using rep host, you need to go to printer settings > printer shape and change home X: from min to Max.
In Octoprint it looks like nothing is needed.
Now there are ways of changing pins.h so you don't have to do #3 but I prefer to do it this way.
EDIT: Ok, yes this fixed the problem. The error i was having after this was another change I set that I forgot about.
Thanks go out to Tenny for this one! This set up completely solved my X axis problems! So darn simple too. One key was to move the X end stop plug from the right most set of pins to the set just to the left of that one. Those are for X axis MAX. Also in Repetier, by choosing home X to Max, it eliminates the red numbers over 200 that I was seeing.
Got my bed leveled and, since I'm using those black clips to hold down my glass, I squeezed in my max dimensions to 180 by 180 and moved my end stops to clear the clips. Now all I need is a thermistor for my hotend and I can set up the extruder. I moved the bed thermistor lead over to the hotend plug so I could work the motions.
Can't wait! Thank heavens that you all are here!
[www.google.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 26, 2015 08:18PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 27, 2015 08:30AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 27, 2015 09:05AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 27, 2015 01:16PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 27, 2015 08:17PM |
tjnamtiw
[attachment 63052 filament_spacer1.jpg][attachment 63051 filament_spacer.jpg]I got tired of wrestling with the filament roll on the side of my FT 2020 and wondering how it was affecting the extruder drive and making it slip sometimes. I made a PVC stand for the time being but I didn't like the filament dragging over my LCD panel that I have mounted on the top. I used Sketchup to design this simple standoff. >> [www.thingiverse.com]
I have Rhino, Alibre, Blender and OpenSCAD but not enough time to master any of them. I've used 2D AutoCad ever since it first came out in the DOS version but never got my head around 3D. Rhino is pretty cool but OpenSCAD defies my imagination. It's like programming all over again rather than a pure CAD program.
Anyway, maybe this standoff will help someone. I'm still madly printing away trying to keep up with the wife's honey--do list of goodies. I do hear one Y axis bearing starting to get 'ballsy'. grrrrrrrrrrrr. I probably already have 100 hours on it.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 27, 2015 08:37PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 27, 2015 09:37PM |
therippa
I would really recommend moving your x-axis to where it should be, on the left side, while you're doing this upgrade. It will solve a bunch of problems, some of which are being able to run G28 (it homes differently after autolevel is configured) and G29 successfully. If you need any pointers you can view the diffs on the branch I actually use for my setup (I use inductive autolevel, but the settings are similar) - [github.com]
Also, as soon as Marlin 1.1 is officially released, I'll put out a new release with the folgertech settings
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 28, 2015 02:09PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 28, 2015 04:30PM |
Mach
Hey tjnamtiw, have you tried the full graphics controller? If you did, could you get it to work properly?
