Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 06, 2015 08:02AM |
I recently got a RepRapDiscount Smart Controller board, and it kind of works. The info screen when first powering it on works fine, but after scrolling up and down bunch of weird symbols pop up on the screen.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 06, 2015 03:10PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 06, 2015 03:57PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 06, 2015 04:39PM |
elkayem
Brand new Folger Tech 2020 online, and runs like a champ. It's very first print is on the heatbed in the photo below. Transparent PLA print of "cuddling cats" (my daughter's choice!), 0% infill and no supports, printed at 190 degC.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 06, 2015 04:56PM |
// 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup) // 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup) WAS: #define TEMP_SENSOR_0 6 IS: #define TEMP_SENSOR_0 1
WAS: //#define THERMAL_RUNAWAY_PROTECTION_PERIOD 40 //in seconds //#define THERMAL_RUNAWAY_PROTECTION_HYSTERESIS 4 // in degree Celsius IS: #define THERMAL_RUNAWAY_PROTECTION_PERIOD 40 //in seconds #define THERMAL_RUNAWAY_PROTECTION_HYSTERESIS 4 // in degree Celsius
WAS: //#define THERMAL_RUNAWAY_PROTECTION_BED_PERIOD 20 //in seconds //#define THERMAL_RUNAWAY_PROTECTION_BED_HYSTERESIS 2 // in degree Celsius IS: #define THERMAL_RUNAWAY_PROTECTION_BED_PERIOD 20 //in seconds #define THERMAL_RUNAWAY_PROTECTION_BED_HYSTERESIS 2 // in degree Celsius
#ifdef ENDSTOPPULLUPS WAS: // #define ENDSTOPPULLUP_XMAX // #define ENDSTOPPULLUP_YMAX // #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX
WAS: #define X_HOME_DIR 1 IS: #define X_HOME_DIR -1
WAS: #define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,90} // default steps per unit for ultimaker {78.7402,78.7402,200*8/3,760*1.1}920 IS: #define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,100} // default steps per unit for ultimaker {78.7402,78.7402,200*8/3,760*1.1}920
WAS: //#define EEPROM_SETTINGS //#define EEPROM_CHITCHAT //#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER IS: #define EEPROM_SETTINGS #define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER #define EEPROM_CHITCHAT
#define ENCODER_PULSES_PER_STEP 4 #define ENCODER_STEPS_PER_MENU_ITEM 1
#ifdef REPRAP_DISCOUNT_SMART_CONTROLLER WAS: #define BEEPER 37 #define BTN_EN1 31 #define BTN_EN2 33 IS: #define BEEPER -1 // 37 #define BTN_EN1 33 #define BTN_EN2 31
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 06, 2015 05:15PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 06, 2015 05:18PM |
tjnamtiw
Congrats!!!! That's great! I see you mastered the 'higher end' LCD screen. I also see you put the X stop on the left and Z on the right. I'll do that on my second one! I don't see any reason right now to change wiring since everything is working great for me too. KNOCK ON WOOD.
Good job. That little girl will keep you busy making things for her.Next comes a dangle for her book bag! Actually, take those kittens and using TinkerCad, put a loop on top! Easy as pie.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 06, 2015 05:52PM |
therippa
Uncertainty
Hi all,
Last time I posted on this thread I was probably on page 10 or so. I had built the printer successfully and then didn't really use it.
I hooked everything back up a couple days ago and started printing a whole bunch of tests and cubes.
I notice that my print surface gets rough and has some gaps on the infill. I could be wrong but it seems to do this when the machine is getting hot.
The x-motor is hot but not scolding.
The y and z motors are cool.
The extruder motor is piping hot. I'm not sure if this is because the hot end is touching the motor or not.
All my motor driver voltages are around 0.35v, with the y motor being at 0.6v
What gives?
Thanks,
U
I feel like the motors/drivers are very picky about a lot of build variables, and you need to adjust them all to your specific setup so the motors don't run too hot. Yes, everyone says "X-axis motor should be at Nvolts", but that doesn't take into account the tension on the drive belt, which can affect how hard the motor has to work. Best thing I've found for dialing in motors is to print a big calibration piece (like, one that takes 60 minute print time), and after 10 minutes, feel the motors. If one is hot, use the ceramic screwdriver and turn down the voltage a tiny bit (like a 1/12 of a turn, think of the dial on the driver as a clock). Wait about 10 minutes, see if the heat go down. Keep turning it down until the motor is pretty much room temperature. If the motor starts skipping, turn it up 1/12 again. It's a trial and error process, and will be different on everyone's build.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 06, 2015 06:29PM |
Neverdone
has anyone here tried to print transparent ABS? I picked up a spool to try and see how it goes. With the RC parts I have been making I thought some of it would be pretty cool to run transparent. When I tried to print it though it turned out more white than clear and the parts were very fragile like I did not have good adhesion between layers. I think that it was probably because of not running enough heat on the extruder. Can anyone comment?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 06, 2015 08:32PM |
elkayem
tjnamtiw
Thanks tj! If you can believe it, my daughter is the one who prompted the purchase. She's been begging me for a 3D printer ever since she saw some of them at our work about a year ago. This isn't the first trinket I've printed for her, just the first one on our very own printer. She was also a very enthusiastic helper during the build, and we built the bulk of it together. Once we got to the electronics, I took over, but she was there by my side turning the allen wrench for most of the structure. I would say this is an excellent kit for an adult to do along with an 10 year old. My only advice is to read ahead in the instructions and have all the parts and tools ready ahead of time for the steps you intend to do together.
Regarding the LCD, I think this is definitely the way to go. The larger 12864 screen is only a few dollars extra over the 2004, and worked for me without any issues. I prefer to do my slicing in Cura, then transfer the file to an SD card. The LCD/SD card reader allows me to run the printer without connecting it to a computer, which is nice.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 06, 2015 10:05PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 07, 2015 03:43AM |
elkayem
Second print off the printer. My daughter was over the moon when she saw it. I only have two datapoints, but already I would say the prints off of my $270 FolgerTech printer rival the quality of prints I get from the $2500 Ultimaker 2 we have at the office.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 07, 2015 09:03AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 07, 2015 11:09AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 07, 2015 11:32AM |
twigtree
Something is wrong with the bed on my printer. I can't level it. One side of the bed is too high up, even while the screws are all the way tightened. The other side is too low even while the screws are not tightened at all. I have no clue what could be the problem. My x-axis is leveled. I'm using a glass sheet on top of the heater.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 07, 2015 11:34AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 07, 2015 02:37PM |
elkayem
I have to say, I've learned a lot from this thread. Scanning a large number of comments has really saved a lot of time getting things up and running. One way I can give back is to summarize the major differences between the build guide and what I really did (mostly based on tips from this thread).
The printer went together fairly easily. The only issues were missing SK8s (Folger sent them out right away after I emailed them), and failed connectors on the endstops. Out of the four endstops I was sent, two had bad connectors on the RAMPS side of the signal line. Easily fixed with a new connector I had lying around, but a good note to others to check the wires with a multimeter if the endstops aren't working.
I put the printer together exactly as the build guide stated, with the exception of the following:
* I placed X endstop on the left side instead of the right, as this appears to be the prefered location for Prusa i3 variants
* I reversed the extruder stepper motor (red wire on left instead of right), since the direction the extruder motor moved was wrong.
* I added a 12864 LCD, picked up for cheap on eBay.
* Note, I did not reverse the X stepper motor, nor did I move the endstop connector , as I have seen others have done on this thread. I left things as they are in the build manual.
I downloaded therippa's Marlin branch (latest Release branch as of 10/23/2015). I made the following changes:
I changed the extruder temperature sensor from #6 to #1. The configuration file states #1 is the best for EPCOS 100k, and says that #6 is not as good as #1, so I can't see why #6 is the default. Anyway, I changed it as below:
Next, I uncommented the lines for thermal runaway protection. I figure I don't want my house burning down because of my new toy, and can't see that this extra logic would hurt.
I did the same thing for the heater bed:
Next, I uncommented the lines for the MAX ENDSTOP pullup resistors. This was needed for my printer to work. Otherwise, the stepper motors would only move left, because Marlin thought the right endstops were tripped. I mentioned this on the previous page of this thread. I don't know why my setup would be different than anyone elses, but if I experienced this problem, I'm sure there is someone else out there in the world who also did.
Next, I had to change the home direction, since my X endstop is now on the left:
The calibration was pretty good, but the extruder did need an adjustment. I changed the following entry after running calibration:
To get the LCD working, I had to add the u8glib Arduino library. Fortunately, this is included in the Marlin build, in directory: Marlin\ArduinoAddons\Arduino_1.5.x\hardware\marlin\avr\libraries\U8glib.
The following changes were made for LCD 12864 support:
A few more lines were added to make the LCD a little more useable, based on a suggestion from one of Tom Sanladerer's YouTube videos:
Finally, Tom's video also suggested a few changes to pins.h, which really help. This disables the LCD beeper, and fixes the LCD encoder polarity:
I hope someone else out there finds this useful!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 07, 2015 07:15PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 07, 2015 07:50PM |
Yelloow-Snow
Few things.
1. I received my auto leveling sensor. Tried to build the circuit that was posted here but failed. Instead I used what Tom recommended with 2 resistors. Not as good but works.
2. Had to use Therippa's personal settings to get auto leveling to work even after using Notepad++ to compare everything. I then took his config and put in all my settings.
3. Moved x to the left side. Moved the X stop on the ramps board over so everything has a space.
4. Reversed the Z endstop. "const bool Z_MIN_ENDSTOP_INVERTING = false;"
5. Designed the sensor mount to go on the right instead of the left. That way it can home to true 0,0. Well that was my thinking
6. The new X end stop that was posted here needs to be reworked. I think someone is doing it. I had to bend the endstop metal a lot so they didn't touch.
Questions
1. Why is everyone going to the lead screws? I got mine in but its less steps and higher angle?
2. G28 goes to the middle. Well sorta. Not sure what setting Therippa had to cause that.
3. Everything is printing off center. Cant figure out how to make it center again. The sensor is directly right of the heat sink.
#define X_PROBE_OFFSET_FROM_EXTRUDER 37 // was 37
#define Y_PROBE_OFFSET_FROM_EXTRUDER 13 // was 13
4. Anyone able to get the printer to auto level while its heating up in Simplify 3D? I tried different google commands but its not working.
5. Does anyone use "M82 ; use absolute distances for extruder" I set it in simplify and it wouldn't extrude. Seems the code works but not the check box. Whats the point of that command? I understand it but should we/I use it?
Anyone want the STL for the sensor mount? I'm a noob so its pretty basic.
FYI: There is an IRC channel thats 25% active. #folgertech on freenode. Wish more people would hang out there.
[webchat.freenode.net]
Anyways.... printer is working pretty good for the end of week 1. I still don't understand some thing and why the middle of the bed does not level when I use the screws. Not sure whats causing it not to descend.
yeaaaaaaa I have spent a week worth of research and adjusting and my ABS prints are still not as good as others. blah. Wonder if its ABS and PLA is that much easier. Getting some PETG next.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 07, 2015 09:02PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 07, 2015 10:48PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 07, 2015 10:53PM |
amishboy
After getting my printer setup and dialed in and after several prints from SD card i decided to print the auto level parts and get it hooked up. Everything went fine until i plugged in the USB cable to the Mega to test and poof smoke from the arduino. This is my 3rd arduino and second ramps, and i thought everything was great until this, now i wait for another Mega. Any pointers on what i should look at?
Update: The printer is still working via SD card apparently just the USB port is burnt on the Arduino.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 07, 2015 11:12PM |
Mrfus
wow... there are so many nice looking prints!!!!!! I have being doing some work on a bracket to put a cooling fan in front of the extruder and make pla cool faster to reduce problems with the areas where there are overhang, and I have played a little with the support material setting on Slic3r without too much success, the supports that the software generate are too hard to remove and there is a big chance to damaged the print on the process... I know that Meshmixer can generate supports (tree like looking ones!) so I want to see if that ones are more easy to remove than the generated by Slic3r.
I got the basic parts of the fan holder and I'm using some blue painters tape to cover the sides and front to obtain the correct configuration in order to low the air to the right point (my first attempt was a mess because the fan keep cooling the hot end and the printer was not able to reach 190 degrees!) I will post some pictures of the prototype later when I get it working as it should be and looking more presentable!
I have nothing really complex being printed beyond some cubes, the fan bracket and a couple of small feet that slide on the 2020 frame so I can put the printer on a larger table without damaging the finish (almost got the dinning table at home busted!)... I think that I got almost all the settings on my slic3r set for my particular hardware and I got the bed calibration almost dominated, probably I will try tomorrow a more complex print and see how it end up!!!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 07, 2015 11:14PM |
Mach
amishboy
Sounds like you blew you voltage regulator on your arduino. Not sure how you wired your inductive sensor (if you are using one), but I am thinking of the possibility of you having shorted the connection between the Vcc pin and the ground pin at the endstop connections....maybe?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 08, 2015 12:03AM |
Mach
Mrfus
You could trying using cura. I have heard that the supports in slic3r are not as good as those of cura, which I can confirm are really good
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 08, 2015 12:58AM |
Mrfus
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 08, 2015 01:18AM |
Yelloow-Snow
Mrfus
Care to share the feet for the printer?
Mrfus
Mach
Mrfus
On the M3D software the support material it's generated as small pillars, so when I saw the option on slic3r was like BOOOMM!
The disappointment was bad when I found that there supports look more like small horizontal platforms under the overhangs, and there are hard to remove (I almost got my finger cut and end up damaging the uper layers when I use small snips to cut the base, maybe with some small manicure scissors I can cut the bases?
I was going to give it a try to Cura, how good is when it comes to small overhangs?
Yelloow-Snow
Mrfus
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) November 08, 2015 02:40PM |
It sure does look like you know what you're doing, with a custom LCD graphic inside a 3D printed housing! And love the My Little Pony looking around the corner. I probably shouldn't know that that is Applejack, but that just shows the type of entertainment common in our house.Quote
IWantToBeAPrincess
Thanks! that was super helpful to setting up the display I printed out a housing too.
I feel like I almost know what I'm doing!
