Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 18, 2016 05:57PM |
Bert3D
buffcleb
Did anyone have to cut the length of there BLTouch probe? If I use the adjuster to bring the probe high enough to clear the bottom of the nozzle in the raise position it is not able to lift itself... I am running off a 5v adjustable power supply for the BLTouch. I adjusted it for 5.4 volts to see if that helps... it did not...
I used this mount to mount the BLTouch : [www.thingiverse.com]
I order to get it to clear I removed some plastic from the extruder as I was not able to get it to mount... I'm thinking about making a new mount the raises it up as this one just does not work well... unless people cut the tip of the probe...
I raised the mount by scaling it at 300% along the Z axis in Slic3r before printing it. Was a lot quicker than making a new one.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 18, 2016 06:05PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 18, 2016 06:12PM |
buffcleb
Bert3D
buffcleb
you didn't run into clearance issues where it mounts to the hotend?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 18, 2016 07:24PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 18, 2016 07:33PM |
100% stock other than a lcd display... And I do have bearing's for the plastic spool... Not sure if I did that before or after I printed the boat?Quote
markts
UltiFix
First abs print! Wahoo!
The abs is green, and the clearish is glow in the dark pla.
Those do look great! Stock setup?
I'm jealous of you guys with the great overhangs.I printed and have been using a fan duct (separate fan) and even still, overhangs still come out "janky" (as my son puts it). At the moment I'm using a stock printer/hot end (though the E3DV6-lite is ready to go!), PLA at 175. With the fan running, is there anything else I should be looking to adjust? I've read you want the extrusion multiplier to be less than 100%, and the speed greater than 100% (I think I'm using 80%/150% ?) in order to "stretch" the plastic across the bridge. Is that the right approach? Any suggestions for S3D settings?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 18, 2016 07:34PM |
yea, the spool is working great now! No unrollingQuote
flatlander
UltiFix
I took the extra bearing's and upgraded the spool holder, it's so smooth the spool is unrolling itself! Maybe that because I had to unwind some of it to get it off... Not sure.
I made some bearing-spool rings too. That glow-in-the-dark boat is really cool!
I took apart the hotend block and applied PTFE tape to all threads; the oozing of PLA from the top of the heat block is gone. FYI: I took it apart while applying heat (200 C) in the manual settings of Repetier-Host and got all the threads cleaned up while hot. I left the the heat-brake bloc attached so had a place to grab while placing the heat block into my wrenches.
Printing defect February 18, 2016 08:42PM |
Re: Printing defect February 18, 2016 08:54PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 18, 2016 09:27PM |
UltiFix
markts
UltiFix
Im using cura, i like it.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 18, 2016 10:08PM |
UltiFix
Well, I have been printing like crazy and been having a ton of fun! Here are some pics... Planning to attach a 40mm fan to the extruder once it arrives.
Oh yeah, how are you guys attaching the glass to the bed? I have ran my hotend into those stupid black clamps.
[imgur.com]
Thanks so much for sharing that!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 18, 2016 10:56PM |
Actually these setting's are from another kind person hereQuote
markts
UltiFix
markts
UltiFix
Would you mind sharing your settings?
So I can't take the credit
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 18, 2016 10:58PM |
Some ebay pla plastic... I have since moved on and am using hatchbox, although I still have a bit left. I even used supports with the 12mm sensor mount D: Maybe I should try printing it agian with some higher quality plastic.Quote
jhitesma
UltiFix
[imgur.com]
Hey neat, that's the first one of my inductive sensor mounts I've seen printed other than the ones I madeThanks so much for sharing that!
I really should update the 12mm version with the revisions I made to the 18mm one.....
What material did you print those in? Your funnel came out better than my first try at one, but your sensor mount is a lot rougher on the overhangs than any of mine came out. I've only printed them in ABS and PETG. Since it's right next to the hot end I don't trust PLA for it. But I tend to get better bridging/overhangs with PLA than PETG. ABS is sometimes better sometimes worse...still trying to figure out what's going on with bridging
Re: Printing defect February 18, 2016 11:13PM |
JustAGuy
Was wanderings if you guys could take a look at this and give me an idea where to start to fix it.
Print is a 20mm square X 100mm tall, single shell print in PLA. This one is at 200 degrees and a known good extrusion rate.
filament is Matterhackers.
Printer is a folger 2020 i3
That roughness is found on all 4 sides but is worse on the side nearest the x axis drive motor.
Any Ideas?
[imgur.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 18, 2016 11:21PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 19, 2016 09:06AM |
Bert3D
buffcleb
Bert3D
buffcleb
Nope. It fit fine on my printer scaled taller. I just used longer screws on the extruder side. The ones that come with the BLTouch are very long, so no issues on that side.
You might want to check and make sure your heat break block is turned the right way.
Not a good shot, but you can see it here:
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 19, 2016 09:34AM |
UltiFix
markts
UltiFix
markts
UltiFix
Would you mind sharing your settings?So I can't take the credit
Here ya go!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 19, 2016 12:57PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 19, 2016 01:58PM |
MuckYu
I have another small problem. I was trying to print a small button. After about 10 minutes the part is sticking to the extruder and the extruder is moving it around. Any reason for this to happen? I am printing with brim by the way
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 19, 2016 02:01PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 19, 2016 02:56PM |
iamquestar
MuckYu
There are two things that I'm aware of that could cause this. First, it could be an adhesion issue. What material are you printing, and what are you printing on? Bare/glued glass? Heated or not? What temps on the bed and nozzle?
Second, if you are over-extruding, then the nozzle can knock into the top of the part. Adding a little z-hop (< .5mm), and the printer will lift the nozzle on travel moves, and may prevent this. For small parts, a little z-hop will not add much time, or wear on the threaded rods. Also, turning down your extrusion multiplier may help too.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 19, 2016 04:08PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 19, 2016 04:51PM |
Im having an issue like this ever since I changed filament, may be over extruding...Quote
MuckYu
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 19, 2016 04:52PM |
ihaveworms
What kind of extrusion multiplier are you all using? I am using 0.7 right now that seems really low, almost like I am doing something wrong.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 19, 2016 05:25PM |
tjnamtiw
Have you calibrated your extruder? It sounds like you are putting out too much material and it is oozing up around the nozzle. Each layer of over extrusion will compound the problem. Calibrate! Don't use extrusion multiplier as a crutch to hide the real problem of poor calibration.
mel0n
markts
mel0n
This had been exactly my experience up until I took the time to work through all the possible settings in slic3r, and print a lot of calibration/test shapes, and single extrusion width cubes to super fine tune my extrusion multiplier. (not measuring a 20mmx20mm cube as Tom points out is wrong)
I think Slic3r may be more susceptible to mechanical issues than Cura which is why I couldn't get slic3r to work well after I finished my build, but now that the vast majority of my mechanical issues are ironed out, I am getting better prints with slic3r than Cura. Especially since I understand a lot more about the entire process, and all the settings in the slicer/ how they affect the print.
Good to know! I'm up for learning about the process, just gotta make time for it.![]()
When you say, "not measuring a 20mmx20mm cube as Tom points out is wrong", are you saying that you're making a mistake NOT measuring the 20x20 cube? Or Tom is wrong by suggesting that? (I think I can find the video you're referring to, but do you have a link handy? Is it just his extrusion calibration video?)
Sure! I am fine tuning my extrusion using methods such as these :
[www.youtube.com]
[www.youtube.com]
Here is Tom's video explaining why measuring a 20x20 cube is wrong:
[www.youtube.com]
So I am fine tuning the width of a single extrusion, not the width of a cube. And once you have been printing/playing enough you should have a pretty good grasp on how your slicer settings affect your print, and if not, EXPERIMENT!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 19, 2016 06:00PM |
About 5 years ago a library near me would have 3d printing class, we designed stuff in sketchup and then the teacher converted it in some other program... The printer had a crapload of blue tape on the bed and they always had adhesion issues, if my memory serves me correctly the printer cost about 2k.Quote
iamquestar
tjnamtiw
Steps per mm is only part of the extruder calibration equation. Because different filaments can have some variance in diameter (or even shape), you generally will modify the extrusion multiplier for different filaments. I recently read this post and watched the videos linked there (this from way back on page 24!). There is some good info there:
mel0n
markts
mel0n
[www.youtube.com]
[www.youtube.com]
[www.youtube.com]
Another thing to try with small parts: Blue tape. I know, I know, the glass bed is often preferable with its smooth finish, but if the parts small, there's little time wasted of you don't like it, but it may work.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 19, 2016 06:02PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 19, 2016 06:21PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 19, 2016 06:42PM |
ihaveworms
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 19, 2016 06:45PM |
UltiFix
I was reading about our folger tech printers and somebody said that if you replace the hotend it would be a much better printer, do you guys agree?
These printers ARE a tinkerer's dream so to each his own but there are a lot of people who are perfectly happy with the original hotend.|
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) February 19, 2016 06:50PM |
MuckYu
iamquestar
MuckYu
Material: PLA
Surface: Bare glass + heated bed (cleaned with alcohol)
Extruder temp = 185° and heated bed = 60°
I only have this exact problem with small parts ("button size").
Bigger parts didn't have big problems so far. Only sometimes the corners warp. (I can print the same part 5 times and 2 of them would have the warping).
