Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 25, 2016 05:13PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 31, 2016 01:24PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 31, 2016 08:33PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 31, 2016 08:50PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) August 31, 2016 09:47PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 01, 2016 07:28PM |
WilberMaker
Why all the crickets? Were did everyone go?
@iamquestar - What parts did you use for the V-slot on your X?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 02, 2016 10:46AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 04, 2016 12:49PM |
sethmo
I am trying to setup BLTouch with Marlin 1.1.0 RC7 and am having some issues.
[pastebin.com]
My setup has the X endstop on the right side.
The issue is when I do a G28, it moves the Z-axis up 10mm then homes X and Y, then moves X & Y to the safe home position(No issues so far). When it starts to home the Z axis it is moving up away from the bed.
If I invert the Z axis, it homes down, but it also moves Z down towards the bed at the start of G28.
What am I missing? I honestly don't care if it moves the Z axis away from the bed before it homes X or Y, how do I disable that?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 04, 2016 12:53PM |
WilberMaker
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 04, 2016 01:57PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 05, 2016 03:50PM |
markts
Sounds like fun. . Got a link to the Facebook group?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 09, 2016 12:10PM |
Consistent under-extrusion on stock Folgertech hot-end September 10, 2016 11:51AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 10, 2016 07:21PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 10, 2016 09:05PM |
crumb4life
Just built my i3 got it printing today. After I borrowed a ramps board from a friend, mine is bad. I am printing a test print now which is working. But I can't seem to get the X Axis to home.
I hit home in Repetier and it doesn't move to the right where the end stop is. Any suggestions I can try?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 10, 2016 09:07PM |
Mach
Make sure your X axis endstop is plugged in one spot over from the right on your ramps board. Manually press the X axis endstop, and type m119 into the gcode bar under manual controls. What does to command log say when you do this? Can you copy and paste your config.h file in pastbin and give a link to it. Also, can you take a screen snippet of you printer shape setting in repetier. This is a very common problem that has come up in many times in this thread, and is usually caused by improper endstop pullup defines in firmware. If I can see those settings, I should be able to give you a quick fix.
Re: Consistent under-extrusion on stock Folgertech hot-end September 10, 2016 09:34PM |
lemgandi
I am unable to print from my Folgertech 2020 Prusa Mendel right now because not enough plastic is coming out of my (stock Folgertech) extruder. I'm printing in ABS at 240 degrees using Repetier Host from a linux box. This machine has printed fine in the past but I left it for a while to work on other things. The symptom appears to be skipped steps on the extruder motor. When I disconnect the hot end from the motor, my calibration is exactly right. I can make a mark 5mm above the extruder and ask for 50 mm of filament on the manual control and it will go just to the mark, both on the fast setting and the slow setting. I can also manually push filament through the heated hot-end with little effort. But if I assemble the extruder, the calibration no longer holds, and I get anywhere from 20% to 40% shortages in the filament going in. I've tried fiddling the potentiometers on the extruder driver board but that doesn't seem to change the behavior. From my crude examinations of the motor, it appears to be pushing filament with enough force to go through the extruder. I don't see excess plastic in the driver gear teeth, and my filament doesn't appear to have a notch where the driver has ground it. I am seeing a slight swelling at the bottom of the filament when I pull it out of the heated block. I see slight leakage from the hot end, but not enough to cause the symptoms I'm having.
Anyone have some ideas I could check? I'm a little reluctant to disassemble the hot end, 'specially as it appears to be working fine. Has anyone measured the force it takes to actually push plastic through it?
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 10, 2016 09:39PM |
ForceFedDSM
I just finished building my 2020 i3 and I am having an issue when trying to home Z. Everything I tested up to this point has worked great. Basically when I connect using pronterface and home the Z axis the motors hum and seem to have a hard time moving. When I press the end stop while it is trying to home z, the printer moves like expected. Jogging the printer also works like expected. I am using the marlin RC7 release branch with all the edits I need for the FT, I made a video of the issue, this is with the driver tuned to 0.932. Any ideas?
[www.youtube.com]
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 10, 2016 11:54PM |
crumb4life
Mach
I don't know why this worked but I put the end stop on the left side and flipped the home vaule in the config to -1 and this works. for whatever reason it would not work on the right side strange but something tells me that is common.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 10, 2016 11:58PM |
tjnamtiw
crumb4life
Mach
When it was on the right, it was X MAX not MIN. Also in Reptier, you had to tell the printer setup that it was MAX.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 11, 2016 11:46AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 11, 2016 01:47PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 11, 2016 03:10PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2016 09:52AM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2016 01:10PM |
mfisch
New 2020 i3 Build- the short and long of it.
The short It's Alive!, needs tweaking. When all else fails threaten to sell it....
Now just tweeks remain!
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2016 07:10PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2016 07:39PM |
tjnamtiw
Is anyone else having problems getting the latest version of Repetier to work with the FT-5? Manually, it all works but when I slice and try to print, the bed heats up SLOWLY OF COURSE, and then alarms out.
On the advice of a friend, I'm going to try Pronterface and Cura. I might also try an older version of Repetier.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2016 08:41PM |
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 12, 2016 09:07PM |
mfisch
I had lots of the line number errors along with unknown command errors.I was printing a filament holder side/end. Sl3cr was looking ok but I think the filament bound up ad caused missed steps shifting layers bay about .25". Cura didn't even put holes in the print. Don't want to deal with it during the weekl, I only ge 5.5 hrs sleep as it is.
Re: Folger Tech 2020 i3 Printer Kit (Official Thread) September 13, 2016 04:22AM |
