Re: P802M Prusa i3 Unofficial Support Thread May 17, 2016 04:36AM |
phisik
price00
Thank you phisik, i can't update the firmware from update utility you've provided.
I need to upload the bootloader first? i've a melzi 2/B
Please check if you have set everything as on the picture below. Check if you have all drivers installed and COM port detected correctly. Try different baud rates (-b57600 or -b115200). Try power cycling/resetting the board right before pressing "Write-Erase" button. It should do the trick. If not - take ISP programmer and reflash the boot loader that comes with Arduino IDE package.
[attachment 77645 flashingviaavrdude.png]
JimsFlight
I think the Melzi board is pretty bricked
Can it be a EEPROM bug? Try executing the following commands in series M502 (Revert to the default "factory settings."), M500 (Store parameters in EEPROM). Try to upload HEX file (Arduino IDE places it in your Windows temp directory in build.xxxx sub-folder) with arvdude with full Write-Erase and Verify it afterwards. Once firmware is OK and EEPROM is cleared it should work, otherwise it is hardware problem.
Re: P802M Prusa i3 Unofficial Support Thread May 17, 2016 11:49AM |
Re: P802M Prusa i3 Unofficial Support Thread May 19, 2016 01:36PM |
Re: P802M Prusa i3 Unofficial Support Thread May 19, 2016 08:39PM |
phisik
I used there online config tool and just selected Zonestar 5 ADC button keypad and analog pin 1 on "User interface page".
Re: P802M Prusa i3 Unofficial Support Thread May 20, 2016 02:38AM |
Re: P802M Prusa i3 Unofficial Support Thread May 20, 2016 06:13AM |
mindstorm88
I don't understand what's going on !!!
Re: P802M Prusa i3 Unofficial Support Thread May 20, 2016 09:37AM |
phisik
I compiled Repetier with autolevel, keypad was ok. I used there online config tool and just selected Zonestar 5 ADC button keypad and analog pin 1 on "User interface page". Be careful setting up autolevel with Repetier, as opposed to Marlin it not have "safe autolevel" function and things may go wrong if you z-home when probe is out of the bed.
Re: P802M Prusa i3 Unofficial Support Thread May 20, 2016 12:28PM |
Re: P802M Prusa i3 Unofficial Support Thread May 22, 2016 12:46PM |
funkyp
can anyone the configuration
Re: P802M Prusa i3 Unofficial Support Thread May 31, 2016 09:42PM |
I have added the Marlin firmware to the Google Drive June 05, 2016 06:08AM |
Re: P802M Prusa i3 Unofficial Support Thread June 07, 2016 09:21AM |
Re: P802M Prusa i3 Unofficial Support Thread June 10, 2016 11:45AM |
Re: P802M Prusa i3 Unofficial Support Thread June 15, 2016 06:11AM |
Re: I have added the Marlin firmware to the Google Drive June 15, 2016 01:29PM |
gwc2795
I have added the latest version of Marlin firmware to the [drive.google.com].
It is a zip file located in the firmware > marlin folder
This is the latest version that supports 5 button display, SD card and auto leveling on the P802MA
enjoy
Re: I have added the Marlin firmware to the Google Drive June 15, 2016 03:11PM |
Re: P802M Prusa i3 Unofficial Support Thread June 16, 2016 05:05AM |
Re: P802M Prusa i3 Unofficial Support Thread June 17, 2016 05:48PM |
miro_mar
Finally I've ordered a new Melzi board. 3D printing is working fine now. So it seems that the problem was due to the old Melzi.
Once I'll have some free time, I will change the Atmega1284P in the old Melzi, burn bootloader with suggested fuses, load firmware and test to see if the root cause was in the 1284P processor or not
Re: P802M Prusa i3 Unofficial Support Thread June 18, 2016 05:10PM |
Re: P802M Prusa i3 Unofficial Support Thread June 19, 2016 04:26PM |
Re: P802M Prusa i3 Unofficial Support Thread June 20, 2016 05:42AM |
Re: P802M Prusa i3 Unofficial Support Thread June 20, 2016 12:50PM |
Re: P802M Prusa i3 Unofficial Support Thread June 20, 2016 05:39PM |
Re: P802M Prusa i3 Unofficial Support Thread June 20, 2016 10:06PM |
faroutmm
Have a new Prusa anet a8 i3. Starts up and temp sensors read 24c on extruder and -51c on hotbed for just a second then they both read def. printer seems to be stuck in dry run mode and cannot be switched out. I've tripled check connections, checked voltages, and hit the reset button on board. Any ideas? Please help!
Re: P802M Prusa i3 Unofficial Support Thread June 25, 2016 03:37PM |
Re: P802M Prusa i3 Unofficial Support Thread June 26, 2016 09:07AM |
Re: P802M Prusa i3 Unofficial Support Thread June 27, 2016 01:59PM |
Re: P802M Prusa i3 Unofficial Support Thread June 27, 2016 10:02PM |
Re: P802M Prusa i3 Unofficial Support Thread June 29, 2016 12:45PM |
Re: P802M Prusa i3 Unofficial Support Thread July 02, 2016 09:34AM |
phisik
I have adjusted the Marlin RC5 code to run on P802M with 5-button ADC keypad. I like it more than Repetier 0.92. It is configured already to use inductor sensor instead of Zmin endstop (I used LJ12A3-4-Z). You are to adjust Z_PROBE_OFFSET_FROM_EXTRUDER which is a distance from bed to nozzle tip at the point where sensor switches. Or you may set it later by M851 z-1.23 command (replace 1.23 with your offset in mm). If you don't have auto bed leveling you will have to disable it in Configuration.h and select proper endstop pullups. Just in case I have attached my sensor mount which is a remix from here.
To enable keypad support ADC_KEYPAD should be defined. Configuration.h file also introduces a type 501 100K thermistor B3950 which comes with Zonestar, disable it if you don't need ones.
I have attached a path to official RC5 version, so it should be easier to adapt future Marlin releases.
PS Most credits go to "jfd" from here for ideas and Marlin support for our keypad. However I had some problems with his firmware and Repetier-Host (since it was older Marlin version) and had to move to the latest RC.
