Prusa I3 confusion December 31, 2015 07:50PM |
Re: Prusa I3 confusion December 31, 2015 09:40PM |
Re: Prusa I3 confusion January 01, 2016 03:18PM |
Re: Prusa I3 confusion January 04, 2016 09:48AM |
awdorrin
I checked the temperature readings this morning, the print head thermistor reads 23C, the heatbed 39C, so a replacement thermistor has been ordered.
Re: Prusa I3 confusion January 05, 2016 05:38AM |
Re: Prusa I3 confusion January 05, 2016 11:23PM |
Re: Prusa I3 confusion January 06, 2016 05:47AM |
Re: Prusa I3 confusion January 08, 2016 07:54PM |
Re: Prusa I3 confusion January 08, 2016 08:29PM |
Re: Prusa I3 confusion January 09, 2016 06:20AM |
Re: Prusa I3 confusion January 09, 2016 11:48AM |
Re: Prusa I3 confusion January 09, 2016 02:33PM |
Re: Prusa I3 confusion January 09, 2016 02:57PM |
Re: Prusa I3 confusion January 09, 2016 06:05PM |
FrontLeft: G0 X30 Y30 Z5 FrontRight: G0 X170 Y30 Z5 BackLeft: G0 X30 Y170 Z5 BackRight: G0 X170 Y170 Z5
Re: Prusa I3 confusion January 09, 2016 08:05PM |
Re: Prusa I3 confusion January 10, 2016 11:31AM |
Re: Prusa I3 confusion January 15, 2016 12:10AM |
Re: Prusa I3 confusion January 15, 2016 12:57PM |
Re: Prusa I3 confusion January 22, 2016 06:56PM |
Re: Prusa I3 confusion January 22, 2016 07:08PM |
Re: Prusa I3 confusion January 23, 2016 11:59AM |
Re: Prusa I3 confusion January 23, 2016 12:47PM |
Re: Prusa I3 confusion January 23, 2016 01:28PM |
Re: Prusa I3 confusion January 23, 2016 02:14PM |
That is the fun thing about this, learning what is causing things like this and then what to do to fix or work-around the issue.
Re: Prusa I3 confusion January 23, 2016 03:34PM |
Re: Prusa I3 confusion January 24, 2016 12:05PM |
Re: Prusa I3 confusion January 24, 2016 12:14PM |
Re: Prusa I3 confusion January 24, 2016 12:52PM |
awdorrin
James,
After a bit more research, and re-reading your post, I think I understand this more fully.
There was a very good write-up that I found here: Taxonomy of Z axis artifacts in extrusion-based 3d printing
So now I understand what you meannt about letting the Z-threaded rod float. I took a picture of my printer, and did a little editing in paint:
[attachment 70683 Z_top_end.png]
So, I figure I could either drill out the hole for the Z-threaded rod (the red circle) - or, I could cut the entire piece away (yellow lines); Or an even better solution would be if I could find a 3d model for these top-end brackets, modify it, and print some new brackets. I have spent a little time searching on Thingiverse, but have not had any luck finding a model yet.
-Al
Re: Prusa I3 confusion January 28, 2016 04:52PM |
Re: Prusa I3 confusion January 28, 2016 05:01PM |
