Re: Geeetech-Aluminum-Prusa-I3 March 14, 2016 08:07PM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 March 15, 2016 04:43AM |
bernbout
Looking at the photo posted I had a good laugh. Such un-necessary complications.
Why not leave the single Z motor in its mount below and connect the belt as shown?
After all this is a simple 3D printer, not a car.
http://forums.reprap.org/read.php?4,560469,560469
Re: Geeetech-Aluminum-Prusa-I3 March 17, 2016 02:49AM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 March 22, 2016 11:58AM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 March 24, 2016 05:12AM |
Re: Geeetech-Aluminum-Prusa-I3 March 25, 2016 10:41AM |
Re: Geeetech-Aluminum-Prusa-I3 March 25, 2016 03:26PM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 March 30, 2016 01:19AM |
stratosonic
So I printed out bernbout's Z axis anti-wobble brackets. This totally eliminated the small Z-wobble that I was getting in my prints. Thanks bernbout!
Z Axis brackets
I had read a lot about eliminating Z-wobble but hadn't yet determined how I wanted to address it. This bracket fixed it for me. I know, there are probably backlash issues, etc, but the walls of prints are now amazingly smooth.
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 March 30, 2016 01:36AM |
osnwt
Few comments:
- talking about the ABL, don't forget that Repetier Firmware (at least) now supports also the Distortion Correction. It measures a grid and creates height map. Then it follows it for the first layers and slowly decreases the correction. Just FYI.
- using two Z motors in series I see no issue while they are on. As soon as they are released, the X carriage under own weight may go down on any side, and it depends on the X position it stays, and even on did you touch the head by hand or not. Just try and see that it is a real problem. To fight with that I put markers on couplers to make them oriented in the same direction. If I see them diverted, I had to move them by hand. Quite annoying.
Re: Geeetech-Aluminum-Prusa-I3 March 30, 2016 03:19PM |
stratosonic
Z Axis brackets
Re: Geeetech-Aluminum-Prusa-I3 March 30, 2016 03:27PM |
MKSA
stratosonic
Z Axis brackets
An other example of what I mentioned, add something to hide a problem instead of simply getting rid of the problem by a proper design/build
The link you gave shows exactly how one can build things the wrong way.
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 March 31, 2016 11:25AM |
bernbout
MKSA
stratosonic
Z Axis brackets
Sorry your expensive and complicated mods did not produce the desired result.
I am happy that I have completely eliminated Z banding and am able to produce smoooooooth prints while yours still look terrible.
Anyway lets see some prints that you have done after your mods. After all the proof of the pudding is in the eating and so far there is nothing to see other than this example:
[attachment 75641 Image1.jpg]
Re: Geeetech-Aluminum-Prusa-I3 March 31, 2016 12:01PM |
Re: Geeetech-Aluminum-Prusa-I3 April 02, 2016 09:19PM |
Re: Geeetech-Aluminum-Prusa-I3 April 04, 2016 12:21AM |
stratosonic
... I know, there are probably backlash issues, etc, but the walls of prints are now amazingly smooth.
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 April 15, 2016 05:20AM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 April 17, 2016 09:39AM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 April 26, 2016 12:03PM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 April 29, 2016 02:42AM |
Re: Geeetech-Aluminum-Prusa-I3 May 03, 2016 12:23AM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 May 03, 2016 06:34AM |
F91W
I am having an issue where it seems my x-axis is curling as the z-axis goes up.
It is very slight but noticeable.
I am using bernbout mod for z banding so I am think my threaded rod is still hitting my x-axis carriage.
I'll upload a picture later of a print and my setup later as I am at work.
Does anyone have some steps I could go through to troubleshoot the issue?
Re: Geeetech-Aluminum-Prusa-I3 May 03, 2016 07:48AM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 May 03, 2016 09:16AM |
Re: Geeetech-Aluminum-Prusa-I3 May 03, 2016 12:27PM |
Re: Geeetech-Aluminum-Prusa-I3 May 03, 2016 08:22PM |
Anonymous User
Re: Geeetech-Aluminum-Prusa-I3 May 04, 2016 03:46AM |
F91W
Thank you for your replies MKSA and bernbout.
Just as an FYI this is my first RepRap printer and I am fairly new to the community.
To answer your questions bernbout:
1. This is what I have printed - [www.thingiverse.com]
2. I have the Geeetech Full Aluminum - v2 I think as there is only one printed part.
3. I'll do this once I am home.
4. Well both. The yellow was what I was concerned with first as the red I think is caused by vibrations from the threaded rod clipping the holder.
I did purchase a new threaded rod set from the local hardware store as the ones that came with the printer where bent. Now that I know about the lead screws that is looking like a good option. Is it safe to buy them from china or is it worth the extra money to buy them local?
From what you have said bernbout, I have not followed the correct procedure on coupler. I tightened the large screw first but I did not alternate with the small screw as I got tighter to prevent bending of the coupler. I did lift the rod about 2mm before tightening though.
Re: Geeetech-Aluminum-Prusa-I3 May 04, 2016 08:12AM |
Re: Geeetech-Aluminum-Prusa-I3 May 21, 2016 06:55PM |
Re: Geeetech-Aluminum-Prusa-I3 May 09, 2017 10:00PM |
Re: Geeetech-Aluminum-Prusa-I3 May 10, 2017 12:13AM |
