Re: Geeetech-Aluminum-Prusa-I3 May 10, 2017 09:23PM |
Wildkata
New guy on the list. Retired electronics and manufacturing engineering tech.
Could someone tell me the length of the lead screws please. I'm considering buying the aluminum model and would like to order proper lead screws at the same time.
Ray
Re: Geeetech-Aluminum-Prusa-I3 May 11, 2017 09:36PM |
Wildkata
1. I hope to bypass the z band problem from the git-go.
2. that might even almost pass scrutiny by anonymous
Wild
Re: Geeetech-Aluminum-Prusa-I3 May 12, 2017 05:10AM |
bernbout
Wildkata
Wild
Also no one at home has the equipment to ensure that every thing in a DIY printer is perfectly square. Hence there is bound to be some banding. All we can do is reduce it to the max extent possible. So using straight lead screws instead of threaded rods that are more prone to bending, properly coupling it to the motor etc. will certainly reduce banding. But to reduce it even further, you MUST decouple the Z Axis from the X axis, a tried and tested method I have used and linked to earlier in this post.
Hope you have every success with your new printer.
Re: Geeetech-Aluminum-Prusa-I3 May 12, 2017 09:34AM |
Re: Geeetech-Aluminum-Prusa-I3 May 12, 2017 10:39AM |
Re: Geeetech-Aluminum-Prusa-I3 May 12, 2017 12:46PM |
Re: Geeetech-Aluminum-Prusa-I3 May 12, 2017 01:19PM |
Re: Geeetech-Aluminum-Prusa-I3 May 15, 2017 01:03AM |
Re: Geeetech-Aluminum-Prusa-I3 May 15, 2017 02:02AM |
Re: Geeetech-Aluminum-Prusa-I3 May 17, 2017 01:28AM |
Re: Geeetech-Aluminum-Prusa-I3 May 17, 2017 02:20AM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: Geeetech-Aluminum-Prusa-I3 May 17, 2017 04:43AM |
Dust
"H ave to second the comment that you need a 3D printer to make a 3D printer. Been puttering for five years.."
nah see repstrap...
it just makes it far easier! (and yes I did it this way, but cheated on the extruder, but could have used wood)
Re: Geeetech-Aluminum-Prusa-I3 May 17, 2017 05:14AM |
Re: Geeetech-Aluminum-Prusa-I3 May 17, 2017 05:27AM |
Dust
That's just repstraps... see [reprap.org] for prusa
"How much change do you have to make to justify giving it your own name?" a significant contribution, or a really big ego!
Prusa basically designed the basic outline of most of the current machines,
Re: Geeetech-Aluminum-Prusa-I3 May 17, 2017 07:51AM |
Re: Geeetech-Aluminum-Prusa-I3 May 17, 2017 07:20PM |
Re: Geeetech-Aluminum-Prusa-I3 May 21, 2017 04:04AM |
Wildkata
I guess they heard you guys - mine arrived with lead screws for the Z axis. The smooth rods are not near as smooth as the G6 rods I bought. I will be miking them this evening, likely will be using the G6.
Wild
