Re: RepRap Guru i3 Printer Kit (Official Thread) August 31, 2017 11:20PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) August 31, 2017 11:24PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) August 31, 2017 11:36PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) August 31, 2017 11:37PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) September 14, 2017 09:30AM |
Re: RepRap Guru i3 Printer Kit (Official Thread) September 15, 2017 03:26PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) September 15, 2017 05:24PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) September 17, 2017 11:31AM |
Re: RepRap Guru i3 Printer Kit (Official Thread) September 17, 2017 11:39AM |
Re: RepRap Guru i3 Printer Kit (Official Thread) October 02, 2017 05:37PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) October 02, 2017 11:32PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) October 11, 2017 01:41PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) October 11, 2017 01:59PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) October 13, 2017 09:18AM |
Tyborg
ajlewis3008: When you buy the kit, they give you the link to a Google Drive that has the v2 instructions manual. The v2 has updated instructions. A slip of paper with the link is actually found in the box first thing when you open it.
If you end up buying the kit, have fun!
Re: RepRap Guru i3 Printer Kit (Official Thread) October 13, 2017 12:12PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) October 28, 2017 09:04PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) October 30, 2017 02:54PM |
mfmellone
Hello everyone - I just recently bought a Prusa i3 V2 from the RepRapGuru online store and completed the mechanical assembly without any major issues so far.
I have several extra parts: 2 metal springs, one 125mm threaded rod and two acrylic pieces. I'm assuming that the acrylic pieces are for a spool holder? If so, how does the spool holder attach to the frame?
I would appreciate it If anyone could tell me what the springs and rod are used for.
Thanks in advance for your help and I'm really looking forward to my first print.
Re: RepRap Guru i3 Printer Kit (Official Thread) October 30, 2017 02:56PM |
danmc
Here is an example of one of the things I'm trying to figure out where there are inconsistencies. In the file "RRG Build Manual V1.4.pdf" from the web site on p. 19 it says "No washer are to be used here". Yet hardware bag #4 has 4 washers and the video shows the use of washers. In addition, the motor in the picture is rotated 180 degrees from the video. A good comparison point is the picture at the top of p. 21 which shows the motor at the right of the X mount having the connector coming off the top. Build video #17 at 0:09 has a nice shot of that section and the connector is on the bottom not the top.
Any tips on which works better (washers or no washers, connector on top/connector on bottom) would be appreciated.
In a related note, is there a distinguishing feature I can look at to verify that this is indeed a v2 kit which is what I ordered?
Thanks
-Dan
Re: RepRap Guru i3 Printer Kit (Official Thread) December 06, 2017 10:48PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) December 06, 2017 10:59PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) December 06, 2017 11:01PM |
wafflejock
The part cooling fan can be plugged into the fan port on the ramps board since it can vary the speed on that one so the part sticks to the bed without the fan on at first and it kicks on to help cool layers after the first few, or in other scenarios you might want to adjust the part cooling fan speed.
Edited snippet
[forums.reprap.org]
For 12V power source ^^
Regarding a computer deciding to go rogue mid print I recommend getting a Raspberry Pi 3 with wifi and downloading the OctoPi image. Basically you download the image, put it on an SD card, load it in the raspberry pi, follow some steps to get it on your network and then you have a wifi network connected printer you can queue up jobs on from any computer on your network. If you add a pi camera to it you can also get timelapses and a live web view of the printer which is handy if you want to stuff it in a corner somewhere far away from where you sleep and/or work.
[octopi.octoprint.org]
Re: RepRap Guru i3 Printer Kit (Official Thread) December 06, 2017 11:04PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) December 06, 2017 11:10PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) February 18, 2018 09:22AM |
Re: RepRap Guru i3 Printer Kit (Official Thread) February 18, 2018 10:11AM |
Re: RepRap Guru i3 Printer Kit (Official Thread) February 18, 2018 12:48PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) February 19, 2018 10:40AM |
Re: RepRap Guru i3 Printer Kit (Official Thread) February 20, 2018 04:00AM |
Re: RepRap Guru i3 Printer Kit (Official Thread) February 21, 2018 02:40PM |
Re: RepRap Guru i3 Printer Kit (Official Thread) February 25, 2018 06:10PM |
