Do I need any driver?
November 16, 2016 01:45PM
I have reprap prusa i3 and RepetierHost. Is this enough or do I need to install some kind of driver also? Or is RepetierHost the driver?
Re: Do I need any driver?
November 16, 2016 02:04PM
You need the USB driver for your printer installed in Windows (if that's what you use). If the driver is installed you will see a COM port in device manager.
You should set the baud rate to match the printer and set the COM port to Auto so that it detects the COM port on the printer.
Edited 1 time(s). Last edit at 11/16/2016 02:06PM by Supermec.
November 16, 2016 02:11PM
No, sorry, I forgot to tell that I use Linux Mint 17.
Where do I find the driver and what is it called?
November 16, 2016 05:26PM
Install the arduino software, this will install the usb driver.
November 16, 2016 06:42PM
under linux just open up a consol and cat -f /var/log/messages (or syslog, what ever your distro uses)
Then plug in the usb cable, it will tell you what it does with it
It should create a serial device for you.
If not then you need to identify your electronics and what usb 2 serial chip it uses and go from there
