Help with Configuration IDEX machine Marlin 2.0.9.1 September 15, 2021 10:50AM |
Re: Help with Configuration IDEX machine Marlin 2.0.9.1 September 15, 2021 07:57PM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Help with Configuration IDEX machine Marlin 2.0.9.1 October 08, 2021 05:15PM |
/** * Dual X Carriage * * This setup has two X carriages that can move independently, each with its own hotend. * The carriages can be used to print an object with two colors or materials, or in * "duplication mode" it can print two identical or X-mirrored objects simultaneously. * The inactive carriage is parked automatically to prevent oozing. * X1 is the left carriage, X2 the right. They park and home at opposite ends of the X axis. * By default the X2 stepper is assigned to the first unused E plug on the board. * * The following Dual X Carriage modes can be selected with M605 S: * * 0 : (FULL_CONTROL) The slicer has full control over both X-carriages and can achieve optimal travel * results as long as it supports dual X-carriages. (M605 S0) * * 1 : (AUTO_PARK) The firmware automatically parks and unparks the X-carriages on tool-change so * that additional slicer support is not required. (M605 S1) * * 2 : (DUPLICATION) The firmware moves the second X-carriage and extruder in synchronization with * the first X-carriage and extruder, to print 2 copies of the same object at the same time. * Set the constant X-offset and temperature differential with M605 S2 X[offs] R[deg] and * follow with M605 S2 to initiate duplicated movement. * * 3 : (MIRRORED) Formbot/Vivedino-inspired mirrored mode in which the second extruder duplicates * the movement of the first except the second extruder is reversed in the X axis. * Set the initial X offset and temperature differential with M605 S2 X[offs] R[deg] and * follow with M605 S3 to initiate mirrored movement. */ #define DUAL_X_CARRIAGE #if ENABLED(DUAL_X_CARRIAGE) #define X1_MIN_POS X_MIN_POS // Set to X_MIN_POS #define X1_MAX_POS X_BED_SIZE // Set a maximum so the first X-carriage can't hit the parked second X-carriage #define X2_MIN_POS 80 // Set a minimum to ensure the second X-carriage can't hit the parked first X-carriage #define X2_MAX_POS 353 // Set this to the distance between toolheads when both heads are homed #define X2_HOME_DIR 1 // Set to 1. The second X-carriage always homes to the maximum endstop position #define X2_HOME_POS X2_MAX_POS // Default X2 home position. Set to X2_MAX_POS. // However: In this mode the HOTEND_OFFSET_X value for the second extruder provides a software // override for X2_HOME_POS. This also allow recalibration of the distance between the two endstops // without modifying the firmware (through the "M218 T1 X???" command). // Remember: you should set the second extruder x-offset to 0 in your slicer. // This is the default power-up mode which can be later using M605. #define DEFAULT_DUAL_X_CARRIAGE_MODE DXC_AUTO_PARK_MODE // Default x offset in duplication mode (typically set to half print bed width) #define DEFAULT_DUPLICATION_X_OFFSET 100 // Default action to execute following M605 mode change commands. Typically G28X to apply new mode. //#define EVENT_GCODE_IDEX_AFTER_MODECHANGE "G28X" #endif
