Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 25, 2020 03:46AM |
Admin Registered: 13 years ago Posts: 7,012 |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 26, 2020 05:32AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 26, 2020 08:01AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 26, 2020 10:01AM |
Marlin 2.0.7.2 echo: Last Updated: 2020-10-15 | Author: CySign echo:Compiled: Nov 26 2020 echo: Free Memory: 3586 PlannerBufferBytes: 1200 echo:Hardcoded Default Settings Loaded echo: G21 ; Units in mm (mm) echo: M149 C ; Units in Celsius echo:; Filament settings: Disabled echo: M200 T0 D1.75 echo: M200 T1 D1.75 echo: M200 S0 echo:; Steps per unit: echo: M92 X55.00 Y55.00 Z400.00 echo: M92 T0 E40.00 echo: M92 T1 E98.00 echo:; Maximum feedrates (units/s): echo: M203 X100.00 Y100.00 Z100.00 echo: M203 T0 E100.00 echo: M203 T1 E100.00 echo:; Maximum Acceleration (units/s2): echo: M201 X3000.00 Y3000.00 Z3000.00 echo: M201 T0 E3000.00 echo: M201 T1 E3000.00 echo:; Acceleration (units/s2): P R T echo: M204 P3000.00 R3000.00 T3000.00 echo:; Advanced: B S T J echo: M205 B20000.00 S0.00 T0.00 J0.01 echo:; Home offset: echo: M206 X0.00 Y0.00 Z0.00 echo:; Hotend offsets: echo: M218 T1 X0.00 Y0.00 Z0.000 echo:; Mesh Bed Leveling: echo: M420 S0 Z0.00 echo:; Material heatup parameters: echo: M145 S0 H180 B70 echo: M145 S1 H240 B110 echo:; PID settings: echo: M301 P22.20 I1.08 D114.00 echo: M301 P22.20 I1.08 D114.00 echo:; Filament load/unload lengths: echo: M603 T0 L0.00 U100.00 echo: M603 T1 L0.00 U100.00 echo:; Tool-changing: echo: Z2.00 echo:; Filament runout sensor: echo: M412 S1 echo:No SD card
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 26, 2020 11:07AM |
Reporting endstop status x_min: TRIGGERED x_max: TRIGGERED y_min: TRIGGERED y_max: TRIGGERED z_min: open z_max: TRIGGERED filament: open filament 2: open ok
M119 19:40:38.791 > Reporting endstop status 19:40:38.794 > x_min: TRIGGERED 19:40:38.794 > x_max: open 19:40:38.794 > y_min: TRIGGERED 19:40:38.794 > y_max: open 19:40:38.794 > z_min: TRIGGERED 19:40:38.826 > z_max: TRIGGERED 19:40:38.826 > filament: open 19:40:38.826 > filament 2: open 19:40:38.826 > ok M119 19:42:19.127 > Reporting endstop status 19:42:19.127 > x_min: open 19:42:19.128 > x_max: open 19:42:19.128 > y_min: open 19:42:19.128 > y_max: open 19:42:19.136 > z_min: TRIGGERED 19:42:19.136 > z_max: open 19:42:19.136 > filament: open 19:42:19.136 > filament 2: open 19:42:19.136 > ok
M119 00:43:47.639 > Reporting endstop status 00:43:47.639 > x_min: open 00:43:47.647 > x_max: open 00:43:47.647 > y_min: open 00:43:47.647 > y_max: open 00:43:47.647 > z_min: TRIGGERED 00:43:47.647 > z_max: open 00:43:47.647 > filament: open 00:43:47.647 > filament 2: open 00:43:47.647 > ok M119 00:43:54.903 > Reporting endstop status 00:43:54.903 > x_min: open 00:43:54.904 > x_max: open 00:43:54.904 > y_min: open 00:43:54.904 > y_max: open 00:43:54.911 > z_min: open 00:43:54.911 > z_max: open 00:43:54.911 > filament: open 00:43:54.911 > filament 2: open 00:43:54.911 > ok
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 26, 2020 07:52PM |
* RAMPS-based boards use SERVO3_PIN for the first runout sensor. * For other boards you may need to define FIL_RUNOUT_PIN, FIL_RUNOUT2_PIN, etc.
// // Servos // #ifndef SERVO0_PIN #ifdef IS_RAMPS_13 #define SERVO0_PIN 7 #else #define SERVO0_PIN 11 #endif #endif #ifndef SERVO1_PIN #define SERVO1_PIN 4 #endif #ifndef SERVO2_PIN #define SERVO2_PIN 5 #endif #ifndef SERVO3_PIN #define SERVO3_PIN 6 #endif
// RAMPS 1.4 DIO 4 on the servos connector #ifndef FIL_RUNOUT_PIN #define FIL_RUNOUT_PIN 6 #define FIL_RUNOUT2_PIN 11 #endif
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 27, 2020 10:28AM |
M119 21:49:47.711 > Reporting endstop status 21:49:47.711 > x_min: TRIGGERED 21:49:47.712 > x_max: open 21:49:47.712 > y_min: TRIGGERED 21:49:47.719 > y_max: open 21:49:47.719 > z_min: TRIGGERED 21:49:47.719 > z_max: TRIGGERED 21:49:47.719 > filament: TRIGGERED 21:49:47.719 > filament 2: open 21:49:47.719 > ok M119 21:49:29.368 > Reporting endstop status 21:49:29.368 > x_min: TRIGGERED 21:49:29.369 > x_max: open 21:49:29.369 > y_min: TRIGGERED 21:49:29.377 > y_max: open 21:49:29.377 > z_min: TRIGGERED 21:49:29.377 > z_max: TRIGGERED 21:49:29.377 > filament: open 21:49:29.377 > filament 2: TRIGGERED 21:49:29.377 > ok
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 27, 2020 05:22PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 28, 2020 07:15PM |
int E1_STEP_PIN= 36; int E1_DIR_PIN= 34; int E1_ENABLE_PIN= 30; int E0_STEP_PIN= 26; int E0_DIR_PIN= 28; int E0_ENABLE_PIN= 24; int Licht_PIN= 13; void setup() { pinMode(E1_STEP_PIN, OUTPUT); pinMode(E1_DIR_PIN, OUTPUT); pinMode(E1_ENABLE_PIN, OUTPUT); pinMode(E0_STEP_PIN, OUTPUT); pinMode(E0_DIR_PIN, OUTPUT); pinMode(E0_ENABLE_PIN, OUTPUT); pinMode(Licht_PIN, OUTPUT); digitalWrite(E0_ENABLE_PIN, LOW); digitalWrite(E1_ENABLE_PIN, LOW); digitalWrite(E0_DIR_PIN, HIGH); digitalWrite(E1_DIR_PIN, HIGH); } void loop() { digitalWrite(Licht_PIN, HIGH); digitalWrite(E0_STEP_PIN, HIGH); digitalWrite(E1_STEP_PIN, HIGH); delayMicroseconds(250); digitalWrite(Licht_PIN, LOW); digitalWrite(E0_STEP_PIN, LOW); digitalWrite(E1_STEP_PIN, LOW); delayMicroseconds(250); }
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe November 29, 2020 04:31AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 01, 2020 05:01PM |
#define NOZZLE_TO_PROBE_OFFSET { 28.84, -2.8, 0.7 } #define NOZZLE_TO_NOZZLE2_OFFSET {54.25 , 0, 0 }?
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 03, 2020 04:19PM |
#define TEMP_SENSOR_BED 13
22:21:39.810 > Error:Heating failed, system stopped! Heater_ID: bed 22:21:41.925 > Errorrinter halted. kill() called!
#if ENABLED(THERMAL_PROTECTION_BED) #define THERMAL_PROTECTION_BED_PERIOD 20 // Seconds #define THERMAL_PROTECTION_BED_HYSTERESIS 4 // Degrees Celsius // stock value: 2
/** * As described above, except for the bed (M140/M190/M303). */ #define WATCH_BED_TEMP_PERIOD 60 // Seconds #define WATCH_BED_TEMP_INCREASE 1 // Degrees Celsius // stock value: 2 #endif
#define NOZZLE_TO_PROBE_OFFSET { 28.84, -2.7, 0 } // was 2.8 #define NOZZLE2_TO_PROBE_OFFSET { 54,19, 0, 0 } // was 2.8 // then -28.89compiled well, but I have no clue how to check this.
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 17, 2020 07:00PM |
#define NOZZLE_TO_PROBE_OFFSET... #define NOZZLE_TO_NOZZLE2_OFFSET...
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 17, 2020 10:21PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 18, 2020 02:05PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 18, 2020 02:28PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 18, 2020 04:01PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 18, 2020 06:24PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 18, 2020 10:35PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 20, 2020 08:49AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 24, 2020 01:51AM |
M503 07:54:35.172 > echo: G21 ; Units in mm (mm) 07:54:35.175 > echo: M149 C ; Units in Celsius 07:54:35.175 > 07:54:35.175 > echo:; Filament settings: Disabled 07:54:35.176 > echo: M200 T0 D1.75 07:54:35.176 > echo: M200 T1 D1.75 07:54:35.178 > echo: M200 S0 07:54:35.178 > echo:; Steps per unit: 07:54:35.179 > echo: M92 X80.00 Y80.00 Z400.00 07:54:35.183 > echo: M92 T0 E747.60 07:54:35.183 > echo: M92 T1 E98.00 07:54:35.183 > echo:; Maximum feedrates (units/s): 07:54:35.188 > echo: M203 X70.00 Y70.00 Z7.00 07:54:35.188 > echo: M203 T0 E20.00 07:54:35.188 > echo: M203 T1 E10.00 07:54:35.188 > echo:; Maximum Acceleration (units/s2): 07:54:35.217 > echo: M201 X3000.00 Y3000.00 Z3000.00 07:54:35.217 > echo: M201 T0 E3000.00 07:54:35.217 > echo: M201 T1 E3000.00 07:54:35.217 > echo:; Acceleration (units/s2): P R T 07:54:35.217 > echo: M204 P2000.00 R2000.00 T2000.00 07:54:35.217 > echo:; Advanced: B S T J 07:54:35.217 > echo: M205 B20000.00 S0.00 T0.00 J0.01 07:54:35.217 > echo:; Home offset: 07:54:35.217 > echo: M206 X0.00 Y0.00 Z4.65 07:54:35.217 > echo:; Hotend offsets: 07:54:35.217 > echo: M218 T1 X0.00 Y0.00 Z0.000 07:54:35.217 > echo:; Auto Bed Leveling: 07:54:35.217 > echo: M420 S0 Z0.00 07:54:35.217 > echo: G29 W I0 J0 Z2.57750 07:54:35.217 > echo: G29 W I1 J0 Z2.63500 07:54:35.217 > echo: G29 W I2 J0 Z2.66500 07:54:35.217 > echo: G29 W I0 J1 Z2.49000 07:54:35.217 > echo: G29 W I1 J1 Z2.56750 07:54:35.217 > echo: G29 W I2 J1 Z2.59250 07:54:35.220 > echo: G29 W I0 J2 Z2.26250 07:54:35.220 > echo: G29 W I1 J2 Z2.38500 07:54:35.221 > echo: G29 W I2 J2 Z2.40000 07:54:35.221 > echo:; Material heatup parameters: 07:54:35.223 > echo: M145 S0 H180 B70 07:54:35.223 > echo: M145 S1 H235 B110 07:54:35.224 > echo:; PID settings: 07:54:35.226 > echo: M301 P22.20 I1.08 D114.00 07:54:35.240 > echo: M301 P22.20 I1.08 D114.00 07:54:35.240 > echo:; Z-Probe Offset (mm): 07:54:35.240 > echo: M851 X28.84 Y2.70 Z0.20 07:54:35.240 > echo:; Filament load/unload lengths: 07:54:35.240 > echo: M603 T0 L500.00 U800.00 07:54:35.240 > echo: M603 T1 L500.00 U800.00 07:54:35.240 > echo:; Tool-changing: 07:54:35.240 > echo: Z2.00 07:54:35.240 > echo:; Filament runout sensor: 07:54:35.240 > echo: M412 S0 D37.00 07:54:35.240 > ok
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 24, 2020 08:07PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 24, 2020 09:33PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 24, 2020 10:12PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 25, 2020 11:49PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 26, 2020 08:13PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 28, 2020 08:45AM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 28, 2020 06:19PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe December 28, 2020 07:38PM |
Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe January 22, 2021 03:31PM |
