Re: Setup Marlin on DIY printer - Mega2560 TCM2209 z-probe
November 25, 2020 03:46AM
Be very careful with endstops
3 pins, signal, gnd and vcc
If you wire this wrong you short vcc to gnd via teh switch and destroy the voltage regulator on the mega
November 26, 2020 05:32AM
Didn't have much time yesterday, so I only quick-checked heaters of hotends, and bed.
I had to swap cables on the hotends and now they seem to work properly - even with fans activated when hot smiling smiley
Heatbed becomed hot, too. But there seems to be problems with the sensor. It doesn't show the real temperature and after a while Marlin reports a failure. Im not sure if its the wrong type of sensor of if it's placed in a bad position.
And extruder steppers dont make any movement. Have to check the config, again.
Will endstops trigger while I'm moving the axis manually on the menu? Or is there any hidden endstop-test-menu?
My endstops have labeled the pinout on the outside, so I don't expect problems here:
Edited 2 time(s). Last edit at 11/26/2020 05:50AM by cysign.
November 26, 2020 08:01AM
Use the force, I mean gcode
M119 reports status of end stops as seen by the controller.
simple make sure no end stops are triggered and send a M119 All should report open
Then hold down a end stop switch with finger and send another M119, the end stop your are holding should now say triggered.
repeat for all endstops.
November 26, 2020 10:01AM
Thats exactly what I need. Can I send the commands using PlattformIO? Or Arduino serial monitor? Or do I have to use a GCode-sender (like Universal GCode Sender)?
//Edit: On PlattformIO I only got an error when trying to open serial monitor.
So hereS what ArduinoIDE says to M149:
Marlin 2.0.7.2
echo: Last Updated: 2020-10-15 | Author: CySign
echo:Compiled: Nov 26 2020
echo: Free Memory: 3586  PlannerBufferBytes: 1200
echo:Hardcoded Default Settings Loaded
echo:  G21    ; Units in mm (mm)
echo:  M149 C ; Units in Celsius
echo:; Filament settings: Disabled
echo:  M200 T0 D1.75
echo:  M200 T1 D1.75
echo:  M200 S0
echo:; Steps per unit:
echo: M92 X55.00 Y55.00 Z400.00
echo: M92 T0 E40.00
echo: M92 T1 E98.00
echo:; Maximum feedrates (units/s):
echo:  M203 X100.00 Y100.00 Z100.00
echo:  M203 T0 E100.00
echo:  M203 T1 E100.00
echo:; Maximum Acceleration (units/s2):
echo:  M201 X3000.00 Y3000.00 Z3000.00
echo:  M201 T0 E3000.00
echo:  M201 T1 E3000.00
echo:; Acceleration (units/s2): P R T
echo:  M204 P3000.00 R3000.00 T3000.00
echo:; Advanced: B S T J
echo:  M205 B20000.00 S0.00 T0.00 J0.01
echo:; Home offset:
echo:  M206 X0.00 Y0.00 Z0.00
echo:; Hotend offsets:
echo:  M218 T1 X0.00 Y0.00 Z0.000
echo:; Mesh Bed Leveling:
echo:  M420 S0 Z0.00
echo:; Material heatup parameters:
echo:  M145 S0 H180 B70
echo:  M145 S1 H240 B110
echo:; PID settings:
echo:  M301 P22.20 I1.08 D114.00
echo:; Filament load/unload lengths:
echo:  M603 T0 L0.00 U100.00
echo:  M603 T1 L0.00 U100.00
echo:; Tool-changing:
echo: Z2.00
echo:; Filament runout sensor:
echo:  M412 S1
echo:No SD card
Looks like I didn't activate endstops. And I wonder why there's only one runout sensor. Have to check config-file, again winking smiley
//Edit: Here's my current config:
digitalinventions.de/files/pics/3Dprinter/20201126_1653h_marlin_2072_config_IronBot.zip
What I like to do now:
I. check endstops (are they activated? why can't I see them on M119?)
II. move extruder-steppers (both don't seem to be alive - no movement here, maybe runoutsensors configured wrong? But this shouldn't impact manual movement, right?)
III. find out what to change to make headbed heating properly (change sensor type or change sensor position)
Edited 4 time(s). Last edit at 11/26/2020 11:42AM by cysign.
November 26, 2020 11:07AM
Well, find out I needed to enable CR in Arduino Serial for Marlin to react to Gcode commands.
So I found the solution for I. winking smiley
M119 reports:
Reporting endstop status
x_min: TRIGGERED
x_max: TRIGGERED
y_min: TRIGGERED
y_max: TRIGGERED
z_min: open
z_max: TRIGGERED
filament: open
filament 2: open
ok
//edit: Well, I removed the formerly attached 10K resistor from my endstop-switches and swapped ground/Vcc for proper triggering. Also I figured out I had to change X-min/-max for proper detection winking smiley
//edit2: Okay, I refined steps/unit to get proper movements. Also my 5 endstops work fine right now. It's time to check z-probe smiling smiley
//edit3:
Actually all 5 endstops work, but z-probe sucks:
M119
19:40:38.791 > Reporting endstop status
19:40:38.794 > x_min: TRIGGERED
19:40:38.794 > x_max: open
19:40:38.794 > y_min: TRIGGERED
19:40:38.794 > y_max: open
19:40:38.794 > z_min: TRIGGERED
19:40:38.826 > z_max: TRIGGERED
19:40:38.826 > filament: open
19:40:38.826 > filament 2: open
19:40:38.826 > ok
M119
19:42:19.127 > Reporting endstop status
19:42:19.127 > x_min: open
19:42:19.128 > x_max: open
19:42:19.128 > y_min: open
19:42:19.128 > y_max: open
19:42:19.136 > z_min: TRIGGERED
19:42:19.136 > z_max: open
19:42:19.136 > filament: open
19:42:19.136 > filament 2: open
19:42:19.136 > ok
I used a voltage devider by two resistors to get 5V-HIGH out of 12V output as far as I remember. But now high seems to be about 3V w/o voltage devider, while low is about 0.xV.
Have to check my z-probe before I go on...
//edit4: Took some time, but now, as I changed the cable, I do get 3,4V when z-probe is close to my bed. Good news: that's quite enough to trigger properly smiling smiley
M119
00:43:47.639 > Reporting endstop status
00:43:47.639 > x_min: open
00:43:47.647 > x_max: open
00:43:47.647 > y_min: open
00:43:47.647 > y_max: open
00:43:47.647 > z_min: TRIGGERED
00:43:47.647 > z_max: open
00:43:47.647 > filament: open
00:43:47.647 > filament 2: open
00:43:47.647 > ok
M119
00:43:54.903 > Reporting endstop status
00:43:54.903 > x_min: open
00:43:54.904 > x_max: open
00:43:54.904 > y_min: open
00:43:54.904 > y_max: open
00:43:54.911 > z_min: open
00:43:54.911 > z_max: open
00:43:54.911 > filament: open
00:43:54.911 > filament 2: open
00:43:54.911 > ok
It's time to check why my extruders don't move.
Edited 8 time(s). Last edit at 11/26/2020 06:54PM by cysign.
November 26, 2020 07:52PM
Still no idea, why my extruder-steppers and runout-sensors don't work.
 * RAMPS-based boards use SERVO3_PIN for the first runout sensor.
 * For other boards you may need to define FIL_RUNOUT_PIN, FIL_RUNOUT2_PIN, etc.
pins_Ramps.h line 65:
// Servos
#ifndef SERVO0_PIN
  #ifdef IS_RAMPS_13
    #define SERVO0_PIN                         7
  #else
    #define SERVO0_PIN                        11
  #endif
#endif
#ifndef SERVO1_PIN
  #define SERVO1_PIN                           4
#endif
#ifndef SERVO2_PIN
  #define SERVO2_PIN                           5
#endif
#ifndef SERVO3_PIN
  #define SERVO3_PIN                           6
#endif
pins_Ramps.h line 256:
// RAMPS 1.4 DIO 4 on the servos connector
#ifndef FIL_RUNOUT_PIN
  #define FIL_RUNOUT_PIN                       6
  #define FIL_RUNOUT2_PIN                      11
#endif
Here's my current code:
digitalinventions.de/files/pics/3Dprinter/20201127_0144h_IronBot_Marlin_2.0.7.2.zip
Though I configured Servo 3 pin, and #define FIL_RUNOUT_PIN I couldn't get any signals from runout sensors.
And I still can't get my extruder's steppers move from the manual move menu confused smiley
My extruder0 has a 0.3mm nozzle, whilst extruder1 has a 0.4mm nozzle. Where may I put this values?
Edited 3 time(s). Last edit at 11/26/2020 08:00PM by cysign.
November 27, 2020 10:28AM
Heatbed-sensor was floating in air below heatbed. Now it's attached properly.
Just got the bed-temp-error, again. It was supposed to be 71°C out of 80°C. Manual measurement says I got 91°C when the error occured. Probably I configurated the wrong sensor.
(observe the tape, without it temperature would be badly wrong because of IR reflections on aluminum...)
Still no progress on Filament steppers, runout sensors, and configuring nozzle sad smiley
//Edit:
Heatbed was set to 80°C.
#define TEMP_SENSOR_BED 1047
Here are shown and measured values:
Display/ir-thermometer
56/60 => difference: 4°C
59/62 => 3°C
62/69 => 7°C
63/79 => 16°C
64/80 => 16°C
65/81 => 16°C
69/86 => 17°C
70/89 => 19°C
71/88 => 17°C (maybe measurementfailure...)
73/91 => 18°C
when heating failed ir-thermometer shows: 90.1°C
Above 60°C the temperatures have a bigger and bigger difference.
//edit:
I guess I'll change the sensor of the bed. Heres what I have here, but I can't remember which type the yellow one is:
Maybe the PT2-100 might be the best choice, as the metal case of the other PT100s might include more delay in measuring.
//edit: Finally some progress on the runout-sensors. I didn't know I had to activate the servo-pins Vcc. It's a jumper that needs to be set (next to extruder0 stepper connectors).
And I figured out, one runout sensor has a broken cable. Time to fix it winking smiley
//edit: Yesssss! Runoutsensors do work smiling smiley
M119
21:49:47.711 > Reporting endstop status
21:49:47.711 > x_min: TRIGGERED
21:49:47.712 > x_max: open
21:49:47.712 > y_min: TRIGGERED
21:49:47.719 > y_max: open
21:49:47.719 > z_min: TRIGGERED
21:49:47.719 > z_max: TRIGGERED
21:49:47.719 > filament: TRIGGERED
21:49:47.719 > filament 2: open
21:49:47.719 > ok
M119
21:49:29.368 > Reporting endstop status
21:49:29.368 > x_min: TRIGGERED
21:49:29.369 > x_max: open
21:49:29.369 > y_min: TRIGGERED
21:49:29.377 > y_max: open
21:49:29.377 > z_min: TRIGGERED
21:49:29.377 > z_max: TRIGGERED
21:49:29.377 > filament: open
21:49:29.377 > filament 2: TRIGGERED
21:49:29.377 > ok
Edited 10 time(s). Last edit at 11/27/2020 04:07PM by cysign.
November 27, 2020 05:22PM
Well, I replaced the (maybe) PT1000 from the bed with one of the PT2-100 - but it showed 0°C at ambient temperature. I couldnt get it running properly. So I swapped back to the maybe PT1000. If there a coefficient I could adjust for getting the right temperature @100°C? Since I know ~78°C is 100°C it wouldn't be a big deal for me to work with it. But I'd like to get proper temperatures on my bed as soon as possible.
I figured out, the position of the sensor and a thermal conductive pad do a good job on the bed. But still there's a drift in high temperature...Which sensor should I buy to get accurate?
Now Im going to solve the extruder-stepper-problem.
Edited 1 time(s). Last edit at 11/27/2020 05:46PM by cysign.
November 28, 2020 07:15PM
Running a simple testing-sketch, I verified the drivers, steppers, and the Arduinoboard are working.
int E1_STEP_PIN=	36;
int E1_DIR_PIN=		34;
int E1_ENABLE_PIN=	30;
int E0_STEP_PIN=	26;
int E0_DIR_PIN=		28;
int E0_ENABLE_PIN=	24;
int Licht_PIN=		13;
void setup() {
	pinMode(E1_STEP_PIN, OUTPUT);
	pinMode(E1_DIR_PIN, OUTPUT);
	pinMode(E1_ENABLE_PIN, OUTPUT);
	pinMode(E0_STEP_PIN, OUTPUT);
	pinMode(E0_DIR_PIN, OUTPUT);
	pinMode(E0_ENABLE_PIN, OUTPUT);
	pinMode(Licht_PIN, OUTPUT);
	digitalWrite(E0_ENABLE_PIN, LOW);
	digitalWrite(E1_ENABLE_PIN, LOW);
	digitalWrite(E0_DIR_PIN, HIGH);
	digitalWrite(E1_DIR_PIN, HIGH);
void loop() {
	digitalWrite(Licht_PIN, HIGH);
	digitalWrite(E0_STEP_PIN, HIGH);
	digitalWrite(E1_STEP_PIN, HIGH);
	delayMicroseconds(250);
	digitalWrite(Licht_PIN, LOW);
	digitalWrite(E0_STEP_PIN, LOW);
	digitalWrite(E1_STEP_PIN, LOW);
Maybe I just don't understand how to move extruders?
=>motion =>move axis => extruder tells me extruder is too cold, but I can proceed and setup a distance in millimeters. Nothing happens. But display shows "Extruder Bed", which I couldn't figure out what it is.
=>motion =>move axis => extruder1/2 show only a distance like all other axis.
But still nothing happens.
Uploaded my updated config files:
digitalinventions.de/files/pics/3Dprinter/20201129_0112h_IronBot_Marlin_2.0.7.2.zip
//edit: Extruder steppers are working smiling smiley
Damn is it slow. I urgently need to adjust steps per unit. I guess prevent_cold_extrusion settings preventet it from moving (I put some filament in the sensors, so Marlin 'thinks' there's filament in...
Homing is x/y min and z max.
I noticed my homing position is (-52 | -15 | 0) and my travellimits have to be (244 | 190 | 222) to avoid crashing my clamps, spoken from the position of my probe.
I don't know which point would be my orientation on my X slider? I could either choose Nozzle1, probe or nozzle2?
//edit2:
Here's what I do understand:
// inductive z-probe turns LED on test-position: z:1,4mm
// both nozzles touch heatbed on same position: z:0,7mm
#define NOZZLE_TO_PROBE_OFFSET { 28.84, -2.8, 0.7 }
#define NOZZLE2_TO_PROBE_OFFSET { 28.89, -2.8, 0.7 }
Edited 5 time(s). Last edit at 11/28/2020 08:47PM by cysign.
November 29, 2020 04:31AM
you cannot move E without the hotend being hot, unless you turn that safety feature off.
M302 ; report current cold extrusion state
M302 P0 ; enable cold extrusion checking
M302 P1 ; disable cold extrusion checking
"Extruder Bed" is a lcd bug, Which I fixed 4 days ago... still only in bugfix.
[github.com]
"NOZZLE2_TO_PROBE_OFFSET" you can't just make up defines
Its always relative to first nozzle
December 01, 2020 05:01PM
So it has to be
#define NOZZLE_TO_NOZZLE2_OFFSET {54.25 , 0, 0 }
A new bed-temp sensor should arrive tomorrow. I ordered an "Thermistor NTC 3950 100k" - hope to get proper bed temperatures then to testprint, soon.
My bed heats up to ~120°C. So I guess I should build a housing for my printer to start with ABS?
For the moment I'm only interestes on ABS (for acetone-smoothing).
Thanks again for your support smiling smiley
December 03, 2020 04:19PM
Just mounted the new sensor, but I always do get bed temperature alerts like this, though temperature has only 2-4°C drift:
Any ideas on this?
Sensor is set to
#define TEMP_SENSOR_BED 13
Terminay says:
22:21:39.810 > Error:Heating failed, system stopped! Heater_ID: bed
22:21:41.925 > Errortongue sticking out smileyrinter halted. kill() called!
I thought my electronics-fan (for the stepper drivers) could provoke a temperature drop which is indicated by this message...but Im not quite sure sad smiley
I found this in configuration_adv.h:
#if ENABLED(THERMAL_PROTECTION_BED)
  #define THERMAL_PROTECTION_BED_PERIOD        20 // Seconds
  #define THERMAL_PROTECTION_BED_HYSTERESIS     4 // Degrees Celsius // stock value: 2
   * As described above, except for the bed (M140/M190/M303).
  #define WATCH_BED_TEMP_PERIOD                60 // Seconds
  #define WATCH_BED_TEMP_INCREASE               1 // Degrees Celsius   // stock value: 2
#endif
//edit: Defining nozzle-offset as
#define NOZZLE_TO_PROBE_OFFSET { 28.84, -2.7, 0 } // was 2.8
#define NOZZLE2_TO_PROBE_OFFSET { 54,19, 0, 0 } // was 2.8 // then -28.89
compiled well, but I have no clue how to check this.
Edited 3 time(s). Last edit at 12/03/2020 04:34PM by cysign.
December 17, 2020 07:00PM
Oh, I ment
#define NOZZLE_TO_PROBE_OFFSET...
#define NOZZLE_TO_NOZZLE2_OFFSET...
I filled in my filament and extruding works.
I wanted to start a bedleveling-testprint and adjust nozzle-height (z-offset between nozzle and probe) using babysteps. But Im still unable to print.
I use slic3r (or shall I better use cura?) and configured my printable area and set map to center (so print should start from middle of my bed).
When I open this gcode-file, my printer starts homing and then one of the motors exceeds limits (dont know which one, yet).
Might it any endstop?
Then theres an strange automatic filament-change. I guess this might depend on my gcode-file? But I'm not sure...
I have my config files and the printing file attached here:
[www.digitalinventions.de]
Here you can see what my printer is doing:
[youtu.be]
I was happy the filament was in my extruder...so I wouldn't never activate change filament on every print grinning smiley
Edited 1 time(s). Last edit at 12/17/2020 07:05PM by cysign.
December 17, 2020 10:21PM
Having 0,0 in center of bed will break 99.99% of tutorials and documents.. 0,0 is traditionally front left.
Set bed shape origin back to 0,0
December 18, 2020 02:05PM
Yes, seems like that's the trick winking smiley Set Origin to (0|0) and print starts like exspected - ~2-4mm above the printing bed. Also I adjusted z-axis speed.
Looks like it starts to print, but after the first line it has an automated filamentchange. I still have no idea how to disable this.
//Edit: I didn't find any M600 command in the gcode - so is it a marlin setting?
Edited 1 time(s). Last edit at 12/18/2020 02:06PM by cysign.
December 18, 2020 02:28PM
Also I tried babystepping: Adjusting z-offset while printing. But I couldnt see any change in distance. Im going to watch more z-offset clips on youtube now winking smiley
December 18, 2020 04:01PM
Most annoying about testprinting is the permanent filament-change... I urgently need to disable this...but Google didn't help sad smiley
December 18, 2020 06:24PM
No idea what happened, but this time I had no filament-change.
But printing ABS on Nozzle 240°C and Bed 103°C didnt work:
[youtu.be]
I even added some gluestick to my aluminium surface...but still no adhesion.
Edited 2 time(s). Last edit at 12/18/2020 10:34PM by cysign.
December 18, 2020 10:35PM
Well, adjusting z-offset and adding some tape to my bed did the job. Still a lot wraping, but making 150% flow nearly resolved all wraping on my first layer winking smiley
Edited 1 time(s). Last edit at 12/19/2020 02:00AM by cysign.
December 20, 2020 08:49AM
Woohoo, using some hairspray on my heatbed @50°C works perfect - gluestick was too uneven and had a lot of disadvantages which plopped my part off the bed. Spray a little bit hairspray, remove with some tissue whats too much...and the print sticks perfect:
To get this result I had to manually tweak while printing:
1st layer: 115% flow, 50% speed, use hairspray (and remove whats too much)
next layers: 75% speed, 100%flow, after some layers boosted speed to 100%.
Also I removed my second nozzle, to avoid it crashing my part (thought this was the problem - but now as my Print works fine, I should re-attach it...).
Now its time for even more finetuning:
Looks like my filament is too cold on the thin things on the top. SO I try to print at 50% there in my next test or I set my filament temperature 5°C hotter.
But it's not the right place to discuss this in the firmware-topic winking smiley
A friend sent me this quality guide: [www.simplify3d.com]
I'm working on all my issues first to get a proper and clean print, before I attach my second nozzle, again.
Thanks for all of your help to get this thing alive!
The last weeks have been frustrating when I got stuck on some problems I had no idea how to solve.
I figured out, there are a lot of videos about single problems, but in most cases you have to figure out they're using any setting, your machine doesn't have. They have other hardware or other firmware versions (please guys, always add the firmwareversion to your beautiful youtube videos!).
But then there's this beautiful forum that makes impossible things possible.
Thank you a lot!
Edited 1 time(s). Last edit at 12/20/2020 09:03AM by cysign.
December 24, 2020 01:51AM
I have a strange problem:
Some hours ago, I started a print. While the printer was homing, I double-presses the rotary encoder and since it wasn't printing gcode, it didnt show z-probe-offset, but z-level.
Since then I'm stuck on printing a perfect raft, followed by printing all other layers at 4.65mm. So my extruder grinds filament while there can't be attached more filament to this layer.
To assure its no gcode-problem I sliced another model and started to print it, but it shows the same behavior.
Is this a hidden Marlin feature or may I have found a bug?
//Edit:
M503
07:54:35.172 > echo:  G21    ; Units in mm (mm)
07:54:35.175 > echo:  M149 C ; Units in Celsius
07:54:35.175 >
07:54:35.175 > echo:; Filament settings: Disabled
07:54:35.176 > echo:  M200 T0 D1.75
07:54:35.176 > echo:  M200 T1 D1.75
07:54:35.178 > echo:  M200 S0
07:54:35.178 > echo:; Steps per unit:
07:54:35.179 > echo: M92 X80.00 Y80.00 Z400.00
07:54:35.183 > echo: M92 T0 E747.60
07:54:35.183 > echo: M92 T1 E98.00
07:54:35.183 > echo:; Maximum feedrates (units/s):
07:54:35.188 > echo:  M203 X70.00 Y70.00 Z7.00
07:54:35.188 > echo:  M203 T0 E20.00
07:54:35.188 > echo:  M203 T1 E10.00
07:54:35.188 > echo:; Maximum Acceleration (units/s2):
07:54:35.217 > echo:  M201 X3000.00 Y3000.00 Z3000.00
07:54:35.217 > echo:  M201 T0 E3000.00
07:54:35.217 > echo:  M201 T1 E3000.00
07:54:35.217 > echo:; Acceleration (units/s2): P R T
07:54:35.217 > echo:  M204 P2000.00 R2000.00 T2000.00
07:54:35.217 > echo:; Advanced: B S T J
07:54:35.217 > echo:  M205 B20000.00 S0.00 T0.00 J0.01
07:54:35.217 > echo:; Home offset:
07:54:35.217 > echo:  M206 X0.00 Y0.00 Z4.65
07:54:35.217 > echo:; Hotend offsets:
07:54:35.217 > echo:  M218 T1 X0.00 Y0.00 Z0.000
07:54:35.217 > echo:; Auto Bed Leveling:
07:54:35.217 > echo:  M420 S0 Z0.00
07:54:35.217 > echo:  G29 W I0 J0 Z2.57750
07:54:35.217 > echo:  G29 W I1 J0 Z2.63500
07:54:35.217 > echo:  G29 W I2 J0 Z2.66500
07:54:35.217 > echo:  G29 W I0 J1 Z2.49000
07:54:35.217 > echo:  G29 W I1 J1 Z2.56750
07:54:35.217 > echo:  G29 W I2 J1 Z2.59250
07:54:35.220 > echo:  G29 W I0 J2 Z2.26250
07:54:35.220 > echo:  G29 W I1 J2 Z2.38500
07:54:35.221 > echo:  G29 W I2 J2 Z2.40000
07:54:35.221 > echo:; Material heatup parameters:
07:54:35.223 > echo:  M145 S0 H180 B70
07:54:35.223 > echo:  M145 S1 H235 B110
07:54:35.224 > echo:; PID settings:
07:54:35.226 > echo:  M301 P22.20 I1.08 D114.00
07:54:35.240 > echo:  M301 P22.20 I1.08 D114.00
07:54:35.240 > echo:; Z-Probe Offset (mm):
07:54:35.240 > echo:  M851 X28.84 Y2.70 Z0.20
07:54:35.240 > echo:; Filament load/unload lengths:
07:54:35.240 > echo:  M603 T0 L500.00 U800.00
07:54:35.240 > echo:  M603 T1 L500.00 U800.00
07:54:35.240 > echo:; Tool-changing:
07:54:35.240 > echo: Z2.00
07:54:35.240 > echo:; Filament runout sensor:
07:54:35.240 > echo:  M412 S0 D37.00
07:54:35.240 > ok
Heres the gcode:
www.digitalinventions.de/files/pics/3Dprinter/CFFFP_TempCalTower240.gcode
Edited 2 time(s). Last edit at 12/24/2020 08:57PM by cysign.
December 24, 2020 08:07PM
I tried another object using Slic3r (previously I was using cura which I really liked for its modern interface and gcode viewer....after I started using Slic3r). But again: Im stuck on 4.65mm in my print. All other movements seem to be fine.
Axis and sensors do work fine (during homing + bed leveling).
Is there a "disable z-axis" setting in Marlin?
Or shall I report an issue on Github?
December 24, 2020 09:33PM
After reflashing Marlin didnt bring any progress, I now lowered the z-speed. As I was incrementing X/Y-speed the last days, maybe the z was too fast while printing so I lost steps? But I would have thought I woule have hear something like this... Waiting for the heatbed to warm up, again grinning smiley
December 24, 2020 10:12PM
Changing z-speed max doesnt help sad smiley
Still: First 2-3 layers look pretty well, then the z-movement is missing (means I can see z-movements in regard to bed level, but the z-level isn't increasing and my extruder is grinding the filament).
Edited 3 time(s). Last edit at 12/24/2020 10:18PM by cysign.
December 25, 2020 11:49PM
After another couple of testprints, I can see it moves it's height - but at a much too slow rate.
So theres too much filament.
What could cause such behavior?
December 26, 2020 08:13PM
Looks like I found out whats wrong: After rafting, the bottom of my model fails, as my height is about 4,65mm, where it starts to print.
Anyhow I must have a wrong setting. I would exspect the printer to set Z=0 after rafting or to move the object up to not cut away the bottom:
So it has to be a cura-setting?
//edit: the picture on the bottom shows the part moved to z = -4,x. This is what the printed result looks like.
Edited 2 time(s). Last edit at 12/27/2020 05:09PM by cysign.
December 28, 2020 08:45AM
I just recorded a small video of the printer's behavior:
https://youtu.be/vQkE3Z16EZI
Also I uploaded an archive:
http://www.digitalinventions.de/files/temp/IronBot_Cura_Marlin_Problem_first_4.65mm.zip
This file contains:
-Marlin-config
-Marlin-config_adv
-screenshot cura-settings for printer (like start/end gcode)
-3d object I sliced and printed
-M503 marlin printer status
-3mf cura-project-file
-gcode-file
Swapping G28 (homing) and G29 (bed leveling) didn't help.
It was recommended here: [community.ultimaker.com]
Might the z-height of my printer in the config-file be the problem? When probing, you can see the values on the display. But I couldn't see 4.65mm anywhere except the M503 status home-offset (see M503 file).
What else could I do?
//edit: In the cura forum I added the M503 output after powering on, after homing, after bedleveling and after homing, again. Maybe this helps?
On the video you can see the display is really, really long showing 4.65mm. Extruder _is_ working, but filamentflow is blocked by nozzle touching raft. To avoid too much filament grinding, I set flow to 70%. I will change this later, wenn the 4.65mm problem is solved.
Edited 2 time(s). Last edit at 12/28/2020 10:33AM by cysign.
December 28, 2020 06:19PM
I finally started a bug report on github: [github.com]
December 28, 2020 07:38PM
Homing on my machine is z-max, x-min, y-min. Maybe I should change this to Z-min? So I have to auto bed level it and then do a homing?
January 22, 2021 03:31PM
Looks like the bugfis-branch has solved my problems - printing right now winking smiley
