128x64 lcd does not work with mks tinybee!
Posted by Enzo-B
Re: 128x64 lcd does not work with mks tinybee!
August 04, 2022 12:59PM
Long shot - remove the USB power jumper J18. Maybe the +5V on the TinyBee is fighting the +5V on the PC.
August 04, 2022 02:58PM
thanks bro
I tested that but the Issue still exist!
August 04, 2022 02:59PM
Does anybody run 128x64 reprap discount smart controller with mks tinybee?
August 04, 2022 05:49PM
Until you solve it, you cannot tell.
But im 99.9% positive its is a hardware issue
August 05, 2022 02:24AM
The issue fixed
I said It's not a hardware issue because there was 2 boards with same issue
I just remove this part of wire with cutter and turn It 180 degree and It worked!
thanks of all who tried to help me.
open | download - 77.jpeg (28.5 KB)
VDX
August 05, 2022 04:17AM
... so it was hardware! - there are some "rules" to connect and mark the cables, to make it easier to check for eventual failures ... for this are the "red" wires at the cables sides.
If it's not proper documented and/or installed wrong, then its still a hardware failure smoking smiley
Viktor
August 05, 2022 12:25PM
Did you cut a wire or did you remove the keying tab on the connector so that you could rotate the connector 180 degrees?
August 06, 2022 01:18AM
Yeah bro I remove the keying tab on the connector as you see in the picture of my previous comment
Now both LCD and SD card work perfect
Edited 1 time(s). Last edit at 08/06/2022 01:19AM by Enzo-B.
