There are current 4 very different versions of this display. (that we know of, so far)
marlin.crc.id.au]
The DACAI does use the directory called private. The file are in a very different format to the files in DWIN_SET
Unfortunately there is absolutely nothing known about this display, other that it emulates a DWIN command set, the files in private are generated from the files in DWIN_SET files using a utility.
Edited 1 time(s). Last edit at 01/19/2023 10:18PM by Dust.
