Is Geeetech i3 Pro compatible with Marlin 2.1 October 01, 2023 11:23PM |
Re: Is Geeetech i3 Pro compatible with Marlin 2.1 October 02, 2023 12:26AM |
Admin Registered: 13 years ago Posts: 7,012 |
Re: Is Geeetech i3 Pro compatible with Marlin 2.1 October 02, 2023 01:13AM |
Re: Is Geeetech i3 Pro compatible with Marlin 2.1 October 04, 2023 11:10AM |
Re: Is Geeetech i3 Pro compatible with Marlin 2.1 October 04, 2023 03:09PM |
Re: Is Geeetech i3 Pro compatible with Marlin 2.1 October 04, 2023 11:07PM |
Re: Is Geeetech i3 Pro compatible with Marlin 2.1 October 05, 2023 01:15AM |
Re: Is Geeetech i3 Pro compatible with Marlin 2.1 October 05, 2023 03:21AM |
Re: Is Geeetech i3 Pro compatible with Marlin 2.1 October 06, 2023 04:49PM |
The only changes made to the configuration file was to put the BL Touch sensor on the Z-MIN endstop, as that is how it was setup for Marlin v1.1.9 which is what version it had on when I got the printer.Quote
[email protected]
I expect a comparison between the working and failing configuration.h files will show a difference in option settings that will explain why the newest Marlin didn't work.
Re: Is Geeetech i3 Pro compatible with Marlin 2.1 October 06, 2023 07:26PM |
Re: Is Geeetech i3 Pro compatible with Marlin 2.1 October 07, 2023 07:53AM |
I found it, it's the fourth item down from the top [github.com]
