New RepRapFirmware 1.11-ch April 08, 2016 04:54PM |
- Added LwIP and FatFs libraries back to RRF project
- Merged in M572 bug fix from dc42's fork (thanks dc42)
- Moved FileStore class to its own files to follow dc42's firmware structure
- Implemented TCP streaming mode for Telnet connections
- Changed OutputBuffer count and sizes (16 -> 32 instances with 256 -> 128 bytes)
- Platform class writes host messages as debug messages if debugging is enabled
- Added Diagnostics call to GCodeBuffer class
- Bug fix: File positions were not passed to Move class
- Bug fix: Roland class didn't pick up correct feedrate
- Bug fix: Fixed memory leak in Webserver for unauthorized HTTP connections
Arduino Duet Board 1.1.6
- Merged in latest changes from dc42's CoreDuet (not CoreNG - thanks dc42)
- Removed LwIP and FatFs libraries
RepRapFirmware 1.10-b7
- Network module provides new state to indicate when an IP address is being obtained
- Reuse same code for HTTP initialisation when the HTTP port is changed
- Added readingConnection member back to Webserver, because requests can be still parsed in multiple runs
- Bug fix: Connection error handler could be called for already closed connections
- Bug fix: Fixed bad condition in PrintMonitor:topParsing method
RepRapFirmware 1.10-b6
- Merged in SHA1 support and added slight improvements (thanks Shaywood)
- Merged in PowerShell build script improvements (thanks SleepyPrince)
RepRapFirmware 1.10-b5
- Merged in firmware retraction support from dc42's fork (thanks dc42)
- M207 reports values with units
- Updated Roland code for new MoveBuffer struct
- Bug fix: AllMovesAreFinished could cause movement to stall
- Bug fix: M206 didn't convert feedrate from mm/min to mm/sec
Arduino Duet board 1.1.5
- Implemented inInterrupt() function (thanks dc42)
- Moved FatFs code to dedicate library (thanks dc42)
RepRapFirmware 1.10-b4
- Bug fix: Allow FTP and Telnet requests that span more than one transaction
RepRapFirmware 1.10-b3
- Recompiled with updated Arduino board files
Arduino Duet board 1.1.4
- Bug fix: Didn't set the link up for static IPs when the LAN cable was
plugged in again
RepRapFirmware 1.10-b2
- Bug fix: Initialise mDNS responder after LwIP netif
RepRapFirmware 1.10-b1
- Network interface goes down when the LAN cable is unplugged
- Reduced webserver memory usage by 1.5KB
- rr_fileinfo/M36 won't return {err:2} any more
- Removed Webserver's ability to wait for incoming data
- Bug fix: DHCP address was sometimes not obtained
Arduino Duet board 1.1.3:
- Split ethernet init routines to address DHCP issues
- Added ethernet_link_established() function to check link state
- Bug fix: DHCP is stopped on demand when the IP address has changed
Re: New RepRapFirmware 1.11-ch April 09, 2016 12:00AM |
Re: New RepRapFirmware 1.11-ch April 09, 2016 05:37AM |
Re: New RepRapFirmware 1.11-ch April 09, 2016 08:38AM |
Re: New RepRapFirmware 1.11-ch April 09, 2016 11:47PM |
Re: New RepRapFirmware 1.11-ch April 10, 2016 08:09AM |
Re: New RepRapFirmware 1.11-ch May 09, 2016 11:50AM |
Re: New RepRapFirmware 1.11-ch May 20, 2016 12:22PM |
