Hangprinter version 3 October 20, 2017 06:44AM |
Infill October 21, 2017 06:44PM |
Re: Hangprinter version 3 October 22, 2017 10:06AM |
Re: Hangprinter version 3 October 25, 2017 01:51PM |
Re: Hangprinter version 3 October 26, 2017 05:58AM |
Re: Hangprinter version 3 October 29, 2017 08:48PM |
I followed your advice and it worked out just fine.Quote
tobben
I have not experienced problems with pulling gears back and forth along motor shafts, as long as shaft is supported and as long as I bend back with two flat screwdrivers at a time (not one).
Drilling out an already printed D-shaped press fit might mean trouble later since your drilled hole will most probably not be centered.
Default PID values were kept, which seems to work just fine.
Re: Hangprinter version 3 October 30, 2017 05:05AM |
Re: Hangprinter version 3 November 05, 2017 12:04AM |
Re: Hangprinter version 3 November 07, 2017 01:41PM |
Re: Hangprinter version 3 November 07, 2017 04:18PM |
Re: Hangprinter version 3 November 09, 2017 07:57AM |
Re: Hangprinter version 3 November 14, 2017 06:43AM |
Re: Hangprinter version 3 November 14, 2017 08:42AM |
Re: Hangprinter version 3 November 17, 2017 09:39AM |
Re: Hangprinter version 3 November 18, 2017 08:01PM |
Re: Hangprinter version 3 November 20, 2017 12:51PM |
Re: Hangprinter version 3 November 20, 2017 03:23PM |
Re: Hangprinter version 3 November 20, 2017 05:51PM |
Help with the kinematics support is available.|
Re: Hangprinter version 3 November 21, 2017 09:43AM |
Re: Hangprinter version 3 November 21, 2017 09:49AM |
Re: Hangprinter version 3 November 21, 2017 10:10AM |
Re: Hangprinter version 3 November 21, 2017 11:01AM |
Re: Hangprinter version 3 November 21, 2017 01:51PM |
Re: Hangprinter version 3 November 21, 2017 01:58PM |
Re: Hangprinter version 3 November 21, 2017 02:48PM |
Re: Hangprinter version 3 November 21, 2017 05:59PM |
Re: Hangprinter version 3 November 22, 2017 02:45AM |
Re: Hangprinter version 3 November 22, 2017 04:40AM |
tobben
Me too!
They're quite unique in using the more heavy duty TMC2660s. This could allow us to use stronger motors, which in turn could allow us to use heavier tool heads (like cheramics/pellet extruders), or just tighter lines. They also give features equivalent to PI+tmc2130, but are much easier to assemble and set up. They would be well worth the extra ca €50 it costs compared to a RAMPS+tmc2130+Pi setup for many users I think.
DuetWifi is on my wishlist, but I currently don't know when/if I will find the time to implement myself. Any HP3 builder who wants to go the DuetWifi/DuetEthernet route of course has my support as well
Re: Hangprinter version 3 November 22, 2017 07:17AM |
anchor_ABCD_xyz are calibration constants. carthesian[XYZ_AXIS] are absolute positions from G0/G1-command. Motor names are mapped like [X, Y, Z, E0, E1] <-> [A, B, C, D, E].
anchor_ABCD_xyz) without user interaction.|
Re: Hangprinter version 3 November 22, 2017 10:48AM |
