Re: Hangprinter version 3 June 22, 2019 09:10PM |
Re: Hangprinter version 3 June 26, 2019 03:16PM |
Moderator Registered: 13 years ago Posts: 401 |
Re: Hangprinter version 3 July 01, 2019 12:59AM |
Re: Hangprinter version 3 July 25, 2019 05:38AM |
Re: Hangprinter version 3 July 29, 2019 09:47AM |
Re: Hangprinter version 3 August 03, 2019 01:47PM |
Re: Hangprinter version 3 August 06, 2019 04:03AM |
Re: Hangprinter version 3 September 03, 2019 02:24PM |
Re: Hangprinter version 3 September 04, 2019 01:34PM |
Re: Hangprinter version 3 October 12, 2019 04:47AM |
Re: Hangprinter version 3 October 12, 2019 06:25AM |
Re: Hangprinter version 3 October 12, 2019 07:00AM |
Re: Hangprinter version 3 October 12, 2019 11:14AM |
Re: Hangprinter version 3 October 12, 2019 12:37PM |
Re: Hangprinter version 3 October 13, 2019 05:28AM |
Be aware that your ODrive configuration will affect the movements. Max acceleration, max speed, step size etc needs to be configured correctly in the ODrive firmware. There's an example that matches my specific motors here: [gitlab.com] Follow the official ODrive documentation to find numbers that match your motors.|
Re: Hangprinter version 3 October 13, 2019 05:35AM |
Re: Hangprinter version 3 November 20, 2019 08:21PM |
Re: Hangprinter version 3 November 21, 2019 07:26AM |
Re: Hangprinter version 3 January 21, 2020 09:17AM |
Re: Hangprinter version 3 January 21, 2020 02:19PM |
Re: Hangprinter version 3 January 22, 2020 01:01AM |
Re: Hangprinter version 3 January 24, 2020 10:36AM |
Re: Hangprinter version 3 March 10, 2020 05:59PM |
atmark
Centralized documentation would be needed and I was already planning to setup up one on Dozuki, but it is a really time consuming task. Time that I currently don't have...
I have though a lot of images I made during the build process, those might help a lot. Hangprinter Google Photos
But then, there's also a lot undocumented stuff, that you learn once you've build the printer and have operated it for a while. I'm still in the process of learning.
It would be wise to document that knowledge as well, but a day (still) has only 24 hours... If you like, I can give you access to the Dozuki site, so we can work together on the documentation
Re: Hangprinter version 3 March 12, 2020 01:23AM |
pvsfa
Also open to develop this further in different platforms if you got some ideas and a bit of time.
Re: Hangprinter version 3 July 20, 2020 12:48PM |
Re: Hangprinter version 3 July 20, 2020 03:26PM |
Admin Registered: 18 years ago Posts: 14,183 |
Re: Hangprinter version 3 August 10, 2020 05:17PM |
atmark
pvsfa
Ok, so the Hangprinter documentation could be maintained here [hangprinter.dozuki.com]
Personally, I like the style Prusa and e3d-online are doing. Lots of images, each and every step is documented, simple and plain instructions.
I have also the complete frame and the Hangprinter motion unit modeled in Fusion 360, which make it easy to do blueprint-like renders (á la e3d-online)
Let me know what do you think.
Re: Hangprinter version 3 August 10, 2020 05:19PM |
leyghis
Hi all,
after doing a lot of testings and work i finally put my docs for Hangprinter online -> [wiki.fablabchemnitz.de]
and some video sources: [videos.stadtfabrikanten.org]
Re: Hangprinter version 3 August 13, 2020 01:21AM |
