Extruder assembly
Revision as of 06:18, 14 August 2015 by Qing (talk | contribs)
Bill of materials | The main panel frame assembly | Y-axis assembly | X-axis assembly | Z-axis assembly
Connecting X-axiz and Z-axiz | Power and LCD assembly | Extruder assembly | Heating bed assembly
power switch and end stops assembly | Control Board assembly and wiring | Circuit Diagram
Extruder assembly
Need Parts
  • 1. 1×MK8A Parts
  • 2. 1×40*40*11heat sink
  • 3. 1×12V Cooling fan
  • 4. 1×NEMA17 motor
  • 5. 1×Feed filament wheel
  • 6. 1×M6 nut
  • 7. 2×M3*4 screw
  • 8. 1×Bilateral groove bearing
  • 9. 1×M4 gasket
  • 10,11 2×7*10 plastic gasket
  • 12. 1×M4*8 screw
  • 13. 1×M5*8screw
  • 14. 1×M4*18 scew
  • 15. 1×M3*16 screw
  • 16. 1×stainless steel spring
  • 17,18 2×M3*40 scew
  • 19. 1×MK8B parts
  • 20. Nozzle(1 set)
Assembly steps
Step 1
You need 1,7,4 accessories, Insert two M3 * 4 nuts in their positions .
M3*4 screw 2pcs,MK8A parts,NEMA17 motor 1pc
Step 2
You need 13, 16 parts, assembled according to pictures.
stainless steel spring 1pc,M5*8screw 1pc
Step 3
You need 14, 15,19 parts, assembled according to pictures.
MK8 parts,M3*16 screw 1pc,M4*18 scew 1pc
Step 4
You need 8, 9,12 parts,put the M4 flat pad placed below the bearing, then tighten M4 screws.
M4*8 screw 1pc,M4 gasket 1pc ,Bilateral groove bearing 1pc
Step 5
Please install both according to the picture.
Step 6
You need the 5 parts,Please install feed filament wheel.
Feed filament wheel 1pc
Step 7
Under pressure with your finger release bearing, insert feeding wheel, adjust the position and releaseyourfinger.
Step 8
Please tighten support screw.
Step 9
You need 2,3,10,11,17,18 parts,fix the fan and heat sink.
Step 10
You need 6,20 parts,before installing the nozzle, you need to tighten nozzle and metal feed pipe, avoid leakage material.
Nozzle 1set,M6 screw nur 1pc
Before installing the nozzle,you need to tighten nozzle and metal feed pipe, avoid leakage material.
Connecting to X-axis
Need Parts:
  • Complete assembled extruder and hot end 1 se
  • L type aluminum profile 1pc
  • M3*20 flat headscrew 2pcs
  • M3*10 screw 1pc
  • M3 lock nut 2pcs
  • M3 flat gasket 2pcs
Assembly steps
Step 1
You need M3*20 flat head screw(2),M3 lock nut(2),M3 flat gasket(2).Please install L type aluminum profileX axis to the plastic parts
M3*20 flat head screw 2pcs,M3 lock nut 2pcs, M3 flat gasket 2pcs
Step 2
You need M3*10 scew.
The hot end insert L-type aluminum groove
M3*10 scew
Tighten the nuts with a wrench.
