Heating bed assembly
Revision as of 06:14, 14 August 2015 by Qing (talk | contribs)
Bill of materials | The main panel frame assembly | Y-axis assembly | X-axis assembly | Z-axis assembly
Connecting X-axiz and Z-axiz | Power and LCD assembly | Extruder assembly | Heating bed assembly
power switch and end stops assembly | Control Board assembly and wiring | Circuit Diagram
Need parts:
  • 1×Heated bed mount(23 part)
  • 1×Y-axis belt holder(26 part)
  • 4×SCS8UU linear bearings
  • 1×Belt(650mm)
  • 16×M4 * 10 screws
  • 4×M3 nut
  • 2×M3 * 16 screws
  • 2×M3 * 20 screw
  • 10×M3 flat gasket
  • 4×M3 * 25 countersunk screws
  • 4×8 * 6 spring
SCS8UU linear bearings assembly
Loosen the smooth rod fixing plate of Y-axis, out smooth rod 10cm, then put on SCS8UU,at the end reset smooth bar fixing plate, and tighten.
Y-axis belt holder assembly
Step 1
Insert the M3*20 screw,then tighten with M3 nuts.
Step 2
Put the M3 nut into 26 part.
Step 3
Screw toward the hexagonal hole.
Step 4
With the two pieces M3 * 16 screws to tight the plate.
Step 5
This hexagonal hole of the plate on the same side with the Y-axis motor, then tighten the screws with the M4 * 10.
M4*10 screw
Belt assembly
Need parts:
  • 4×Ties
  • 1×belt 650mm
Step 1
With tie fastened at the 2cm position of belt.
The wheel of the Y-axis motor
Step 2
Install the belt onto the screws. (This screw is the which is the near the Y-axis motor )
Step 3
Loosen the M4 * 30 screws of belt mounting plate, and then the other end of the belt from two single bearing wear to the next step.
Step 4
Tie the other end of the belt with the above manner.
Step 5
After tight , then set in the belt fixing plate screws.
Step 6
You can adjust the tension of the belt use the wrench(3mm).
Need parts:
  • 1× Welded heating bed
  • 4×M3 lock nut
  • 4×8 * 6 spring
Step 1
Place the heated bed, then fixing with M3 * 25 screws and M3 lock nut.(Exposed screw lock nut 2mm to 3mm it is easy to adjust heating bed.)
