Power and LCD assembly
Revision as of 06:20, 14 August 2015 by Qing (talk | contribs)
Bill of materials | The main panel frame assembly | Y-axis assembly | X-axis assembly | Z-axis assembly
Connecting X-axiz and Z-axiz | Power and LCD assembly | Extruder assembly | Heating bed assembly
power switch and end stops assembly | Control Board assembly and wiring | Circuit Diagram
Power supply assembly
Need parts:
  • 1×12v 250w supply
  • 3×M3*10 screw
  • 3×M3 flat gasket
The following two screws in the power supply , one on top of the screws and then tighten.
LCD assembly
Need parts:
  • 1×LCD
  • 4×M3*25 screw
  • 4×M3 nut
  • 4×M3 lock nut
  • 8×M3 flat gasket
  • 4×plastic gasket
Step 1
M3 * 25 screw and a M3 flat gasket insert acrylic sheet.
Step 2
Plus a flat gasket and use M3 lock nut tightening. then Coupled with a plastic pad.
Step 3
Inserted 4×M3*25 screw into four holes of LCD, and then tighten with M3 nuts.
