Prusa XI3
Revision as of 06:03, 14 August 2015 by Qing (talk | contribs)
Bill of materials | The main panel frame assembly | Y-axis assembly | X-axis assembly | Z-axis assembly
Connecting X-axiz and Z-axiz | Power and LCD assembly | Extruder assembly | Heating bed assembly
power switch and end stops assembly | Control Board assembly and wiring | Circuit Diagram
Prusa XI3
Baced on prusa i3.
none
Assembly instructions
  1. Bill of materials
  2. The main panel frame assembly
  3. Y-axis assembly
  4. X-axis assembly
  5. Z-axis assembly
  6. Connecting X-axiz and Z-axiz
  7. Power and LCD assembly
  8. Extruder assembly
  9. Heated bed assembly
  10. power switch and end stops assembly
  11. Control Board assembly and wiring
  12. Circuit Diagram
Product Specifications
Parameters Description
Structure Acrylic Sheet(Transparent)
Frame Lead Screw
Print Size(X Y Z) 210×210×210mm
Layer Resolution 100 Microns
Print Precision 0.1-0.4mm
XY Axis Positioning Accuracy 0.012mm
Z Axis Positioning Accuracy 0.004mm
LCD Screen YES
Nozzle Temperature 210℃(MAX 260℃)
Power Supply DC 12v/250W
Connection SD Card or USB
OS Windows XP,Windows Vista,Windows 7,MAC OX
Software Repetier-Host,Cura,Slic3r
Material Type PLA,ABS,HIPS,Wood,PVA,Nylon,Flexiable PLA,Copper fill (metal)
Material Specifications 1.75mm
Machine Size 440×370×410mm
Help and Support
Photos
