Prusa XI3
Connecting X-axiz and Z-axiz | Power and LCD assembly | Extruder assembly | Heating bed assembly
power switch and end stops assembly | Control Board assembly and wiring | Circuit Diagram
Prusa XI3
Description | Baced on prusa i3.
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | none
External Link |
Assembly instructions
- Bill of materials
- The main panel frame assembly
- Y-axis assembly
- X-axis assembly
- Z-axis assembly
- Connecting X-axiz and Z-axiz
- Power and LCD assembly
- Extruder assembly
- Heating bed assembly
- power switch and end stops assembly
- Control Board assembly and wiring
- Circuit Diagram
Product Specifications
Parameters | Description |
Structure | Acrylic Sheet(Transparent) |
Frame | Lead Screw |
Print Size(X Y Z) | 210×210×210mm |
Layer Resolution | 100 Microns |
Print Precision | 0.1-0.4mm |
XY Axis Positioning Accuracy | 0.012mm |
Z Axis Positioning Accuracy | 0.004mm |
LCD Screen | YES |
Nozzle Temperature | 210℃(MAX 260℃) |
Power Supply | DC 12v/250W |
Connection | SD Card or USB |
OS | Windows XP,Windows Vista,Windows 7,MAC OX |
Software | Repetier-Host,Cura,Slic3r |
Material Type | PLA,ABS,HIPS,Wood,PVA,Nylon,Flexiable PLA,Copper fill (metal) |
Material Specifications | 1.75mm |
Machine Size | 440×370×410mm |
Help and Support
- You can download the STL file from prusa xi3
- Prusa Mendel i3 EiNSTeiN VARIANT on Reprap.org
