3d printer fried stuff July 09, 2019 04:49AM |
Re: 3d printer fried stuff July 09, 2019 04:58AM |
Admin Registered: 13 years ago Posts: 7,012 |
Re: 3d printer fried stuff July 09, 2019 05:18AM |
Admin Registered: 16 years ago Posts: 13,905 |
Re: 3d printer fried stuff July 09, 2019 07:40AM |
Re: 3d printer fried stuff July 09, 2019 07:45AM |
Re: 3d printer fried stuff July 09, 2019 08:34AM |
Admin Registered: 11 years ago Posts: 3,096 |
timur
thanks,
how could this be possible? I mean the endstops have a place to fit in and I think it fits like in the picture.
is there a way i miss something ?
Re: 3d printer fried stuff July 09, 2019 08:57AM |
Re: 3d printer fried stuff July 09, 2019 09:07AM |
timur
yes it is.
Re: 3d printer fried stuff July 09, 2019 10:03AM |
timur
thanks,
Re: 3d printer fried stuff July 11, 2019 07:22AM |
Re: 3d printer fried stuff July 11, 2019 07:36AM |
timur
Thanks,
But I am using an end-stop with 3 wires and PCB
Re: 3d printer fried stuff July 11, 2019 07:46AM |
Re: 3d printer fried stuff July 11, 2019 01:06PM |
Re: 3d printer fried stuff July 14, 2019 02:53PM |
Re: 3d printer fried stuff July 14, 2019 03:10PM |
timur
In Case of a short circuit due to endstop plugging in wrong direction, does the 3d printer works some time or burns immediately.
In my case, the printer worked for few minutes and then I pressed the heat option for bed and nozzle then a few seconds later, it started to smoke and burnt. (I dont know the reason, so I am trying to figure it out)
Thanks
Re: 3d printer fried stuff July 15, 2019 04:40PM |
Re: 3d printer fried stuff July 15, 2019 06:09PM |
Re: 3d printer fried stuff July 15, 2019 08:15PM |
timur
Thanks
Re: 3d printer fried stuff July 16, 2019 03:21AM |
Re: 3d printer fried stuff July 16, 2019 12:11PM |
Roberts_Clif
timur
Thanks
When I plugged in my end-stop backwards it did not die quickly, as I just tapped the the switch blade to test using M119, it ran for a while then the LCD displayed garbage then it died completely.
After replacing the AMS1117 it started running, until I again went brain dead and shorted it out again this time making voltage measurements while adjusting the Stepper motor V-Ref.
I found this adjustable voltage
I finally replaced the Ramps D1 with a 12volt 3amp Dc-Dc step down converter so I could power the Ramps using 24VDC and the Dc-Dc step down converter would supply the Arduino.
Then I replaced the 5 volt AMS1117 regulator with the same regulator this time set to 5volt 3amp to replace the AMS1117-5.0
The AMS1117-5.0 dies with a simple quick short this part is extremely fragile.
Re: 3d printer fried stuff July 16, 2019 01:25PM |
Re: 3d printer fried stuff July 16, 2019 04:05PM |
Roberts_Clif
Believe me this was not my first choice either, with bills getting higher and wadges lower it was my only choice, if I wanted a new MPCNC maybe later a better board could be acquired.
Even with repairs using the AMS1117-5.0 and then the DC-DC Step Down Buck Converter still much cheaper. An now the inadequacies of this cheaper controller are upgraded forever.
Roberts_Clif
Re: 3d printer fried stuff July 16, 2019 07:45PM |
Re: 3d printer fried stuff July 18, 2019 05:11AM |
yeah it is kind of look like that but it doesnt.Quote
Dust
The image of your controller seems to show that your bed thermistor is straddling one pin of T0 and one pin of T1
