Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 12:12PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 12:20PM |
plexus
I know it might be a pain, but if you can measure the temp along the filament path from top to bottom, with the heatsink fan running etc as usual. use a thermocouple or thermistor based digital thermometer (not an IR thermometer as they are too inaccurate). what you are looking for is an sign that the path and heat break are getting to hot. if so this will soften and expand the filament prematurely and can cause a plug that can't be overcome with the extruder pressure. touch the sensor to the metal, away from air flow if possible so you are truly reading the temp of the metal. if you can, get the sensor as deep into the heat sink as possible (as close to the path of the filament). you will have to guestimate the temp the filament sees. if its not something very safe like <50C, then if it were me, i'd try getting the sensor down into the filament tube to measure the inside wall temp. just to rule this possibility out. i've had it happen to me E3D and Magma hot ends so I know... in the end I put a 50mm fan on the E3D to ensure it was cooled down enough to prevent the plug of death.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 12:50PM |
3DogNate
No pics handy... I reduced the dia of the top fin to about half, and tapped the top for M5 for a bowden connection... that fin doesn't even fit into the fan housing before I turned it down. Plus the bulldog fan blows there anyway. and yes wired straight to 12V, not the heater
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 01:04PM |
Yes, and I printed one Tuesday and am using it.Quote
tjb1
3DogNate
There is a fan shroud for the Bulldog that fits around the E3D that they released themselves.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 02:31PM |
3DogNate
tjb1
3DogNate
Wait... got a link? I want to make sure we are talking about the same thing..
I'm using the e3dholder.zip holder from this link... [forum.reprapdiscount.com]
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 02:40PM |
tjb1
I can't open that right now but I know the one they released had a bigger opening to clear the heatsink so why would you need to modify one of the slats?
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 03:03PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 03:08PM |
greenman100
3DogNate
that end of the heat sink is colder than the ambient temp in the room thanks to two fans blowing on the heat sink.,.. so it's irrelevant to my filament jamming up.
This is exciting, you have broken the laws of thermodynamics!
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 03:12PM |
3DogNate
greenman100
3DogNate
Huh??? are you saying that if you blow a fan on a room temperature block of aluminum that it is impossible to cool it to below the ambient temperature in the room?
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 03:22PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 04:07PM |
3DogNate
greenman100
3DogNate
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 04:09PM |
Admin Registered: 13 years ago Posts: 1,467 |
greenman100
3DogNate
greenman100
3DogNate
Yes. That's exactly what I'm saying. Well, myself and Isaac Newton. I guess we're both internet experts.
The one exception is if there's evaporation occurring, but I doubt you're spraying the heat sink with water.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 04:30PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 04:38PM |
Admin Registered: 10 years ago Posts: 1,063 |
3DogNate
Geezz.... I'm ashamed to be referred to as a geek sometimes.
Back to my hot end... If you have something to contribute to having a successful E3D implementation I'm happy to hear it... otherwise... don't waste the thread space.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 04:53PM |
thejollygrimreaper
3DogNate
are you running the bulldog XL or the bulldog lite? and which size of the filament?
if you are running the buldog XL how much current are you giving it?
exactly what is happening when it jams, is the stepper skipping steps or stripping the filament?
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 05:18PM |
3DogNate
thejollygrimreaper
3DogNate
I'm running the Bulldog Lite... 1.75mm filament. I'm running the Stepper Drive at 1.2A... the Extruder will strip the filament before it skips steps... (If I apply enough tension it will grind the filament in half before skipping steps.) When it jams, it's really simple... it stops extruding... the filament gets jammed and the extruder keeps trying to work but just ends up grinding at the filament until it no longer has tension on it. If I catch it before it grinds too far... I can pretty easily pull the jammed filament out of the hot end barrel (Heat brake)... Several examples of just the same thing in this thread. I generally run the bulldog with the tension screws backed off as even then there is plenty of power to move the filament under normal circumstances.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 05:31PM |
thejollygrimreaper
3DogNate
thejollygrimreaper
3DogNate
pla or abs? and what color?
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 05:37PM |
NewPerfection
thejollygrimreaper
3DogNate
thejollygrimreaper
3DogNate
And what supplier? Poor quality filament can jam up the best hot ends.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 05:57PM |
plexus
NewPerfection
thejollygrimreaper
3DogNate
thejollygrimreaper
3DogNate
I use what is often considered the poor quality ABS and PLA from repraper in china without any issues with the E3D with both 3mm and 1.75. FYI
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 07:24PM |
3DogNate
I took it apart and the barrel bent...
3DogNate
I put in an order last week for some replacement parts from Filastruder.com to rebuild the hot end.
I rebuilt the hot end yesterday
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 08:03PM |
A2
Correct me if I have misinterpreted you, but you were the cause of the first hot end failure (bent heat break), and the bent heat break caused the filament to jam, is this correct.
If this is the case, lets assume that you are the cause of the second failure, and conduct a test to determine if the heat break was bent again.
There is an assumption that the bore of the barrel should be straight enough for a filament to pass through without jamming.
I don't see a straightness call out on the blueprint, nor do I see a (do not exceed assembly/disassemble torque specification), so you are not entirely to blame.
In view that there is not a call out on the blueprint for straightness,
I'll make up a straightness specification for you to test, based on the barrel, and GD&T concentricity tolerance.
Note: I think that datum -A- would be better served if it was applied to the axis of the barrel bore, and not to the O.D of one end of the part.
Barrel diameter 2.0 mm (±0.05 mm).
Concentricity tolerance: 0.05 mm.
2.0 mm - 0.05 mm = 1.95 mm. Smallest barrel diameter.
1.95 mm - (0.05 mm /2) = 1.925 mm. This value represent the maximum diameter that should pass through the length of the heat break.
Use a pin gauge to check for straightness with a tolerance of ±0.0002", (0.00508 mm).
I would test for straightness with a diameter 1.925 mm pin gauge with a minimum length of 25.5 mm.
You need to measure, and validate that you are conducting your test with a part that is within blueprint specifications.
After you have verified that the replacement part is to a specification (yet to be determined), you can begin ruling out other variables.
In addition conduct all trouble shooting tests with natural (uncolored) filament.
GD&T Concentricity Definition
[www.emachineshop.com]
Filament tolerance
[bootsindustries.com]
E3D Online Limited, (ISS B )
[files.e3d-online.com]
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 08:11PM |
3DogNate
A2
Filament tolerance
I'm using Ultimaker PLA, 1.75mm, Black and Deltamaker PLA 1.75mm red (Good stuff, that all prints nicely with my other QU-BD extruder/Hot end)
You did misinterpret me... I could not get good results with my first attempt with the E3D... so I disassembled it to verify that I built it correctly, but when I went to remove the barrel it was REALLY stuck and bent when I removed it... That's why I had to re-order parts. (I'm a hobby machinist... I have a CNC mill retro-fit that I did, a lathe blah, blah... I'm actually a good fabricator. I'll get pics up when I get a chance..) I assembled it with no damage to the new parts. If I were to spin the heat break on the lathe it would spin true... I did inspect the new parts before assembling and with a caliper the new barrel was in spec and the interior was smooth.. (smoother than the first one I received)...
Lets assume that everything is in spec and assembled correctly... what should I start looking at? I've calibrated my extruder... ran PID autotune... My thermistor setting is correct in firmware, My retract is set at .5mm/60mm-sec...
Plexus.... what are your Slic3r setting for your PLA? I have some Zen ABS also to use... but If I can't do PLA then I'm not going to move on to other filament types... PLA is a good choice for so many things.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 06, 2014 08:47PM |
3DogNate
3DogNate
3DogNate
3DogNate
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 07, 2014 10:10AM |
A2
Did you disassembled the hot end while it was cold.
A2
That's interesting because bruce356 believes his filament jamming might be due to the finish on the bore of the barrel.
If you're able, take a picture of the barrel finish of both heat breaks, or try to quantify the surface finish roughness.
You could try to improve the finish of the barrel bore with a miniature flex hone, and some mineral oil.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 07, 2014 12:09PM |
3DogNate
No, I'll not go to that length... I need to be able to trust the people I buy from to handle any quality control issues... They should not be conducting business if they can't control a thing like that.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 07, 2014 12:38PM |
plexus
3DogNate
My personal feeling is that you should correspond with E3D exclusively and stop wasting our time on this forum since you are unwilling to try anything we suggest and ultimately are just not aligned to the spirit of this whole 3D printing escapade. Most of these "companies", like E3D, are producing these things for us because they feel they have a good idea that they can mass produce to some small degree and share the fruits of their labour and passion with the larger 3D printing community. Very few of these companies are big, usually just a few people trying to push the envelope. more often than not there is something we, the end user, needs to do in order to get these things to work. it's supposed to be part of the fun - its fun for a lot of people and for some its just something tolerated in order to get back to printing. regardless there is a spirit and a sense of co-operation and collaboration that appears to be lost with you. so if you dont mind, could you take your issues up with E3D. thanks.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 07, 2014 12:44PM |
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 07, 2014 01:08PM |
jzatopa
3DogNate I am in the middle of building a printer and plan on using the same combination of extruder and E3D except I will be using the bulldogXL. How did you account for the size mismatch between the e3D and bulldog mount? Did you use a metal shim or something else? I skimmed your posts and didn't see if you explained that yet.
I see you have quite a lot of fans on your print head. Have you tried pointing them all at the barrel while printing? This isn't a fix but it might help narrow down your problem to thermal or mechanical.
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 07, 2014 04:27PM |
3DogNate
I did get a response from E3D they asked about the filament path. Which with the bulldog there is no more than a mm or so anywhere that the filament is unsupported to allow for a flex or bind in the path...
Re: Update on the E3D All Metal Hotend (Now finally shipping!) ![]() March 07, 2014 06:00PM |
greenman100
3DogNate
Didn't you bore/tap the heatsink for a bowden connector? That would leave many millimeters unsupported.
