Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() April 01, 2014 09:21PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() April 05, 2014 06:15PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() April 05, 2014 07:18PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() April 07, 2014 05:35PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() April 17, 2014 06:50PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() April 17, 2014 07:22PM |
turutk
Your heatsink design seems thin due to shape.
Can I combine 2 of your hotends and use them with a single 4cm fan?
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() April 17, 2014 08:29PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() April 20, 2014 11:33AM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() April 20, 2014 03:37PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() April 20, 2014 04:02PM |
RoyAvery
Can you post more pictures and possible video of prints using rapid retracts? The X carriage was your only good example.
We have found that jams basically every all metal hotends tested to date.
Jeremie Francois
it is easy to check that you did it right by printing an object that requires heavy retraction, such as those voronoi objects with fractal holes everywhere.
many retractions are a good test to check the filament flow reliability.
Probably the best kind of object to test retraction (design by richrap)
Still, my print is quite dirty, but at least I got no single plug,
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() April 20, 2014 10:06PM |
RoyAvery
Here is 1 example [www.thingiverse.com]
turutk
I was actually planning to use a high cfw fan from one end because my delta hub has a fan mount on it.
Here is my setup with E3D:
[drive.google.com]
There is no way I can fit 2 E3D hotends. I thought maybe two prometheuses can fit to the same hub.
I don't want to place the hotend under the hub.
By the way It would be great if this hotend had a bowden version where pfte tube goes inside the heatsink.
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() April 23, 2014 06:55PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() August 12, 2014 06:26PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() August 12, 2014 06:59PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() August 12, 2014 07:25PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() August 12, 2014 08:33PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() August 13, 2014 12:36PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() August 13, 2014 08:02PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() August 15, 2014 06:06AM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() August 15, 2014 08:33AM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() September 02, 2014 08:13PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() September 05, 2014 11:28PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() November 02, 2014 11:15PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() December 10, 2014 06:27PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() January 11, 2015 12:50PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() January 11, 2015 01:08PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() March 07, 2015 05:47PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() March 07, 2015 05:55PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() March 07, 2015 06:01PM |
Re: “Prometheus Hot End”: New Customizable All-Metal Hot End! ![]() August 06, 2015 07:16PM |
