Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 17, 2014 06:19PM |
Re: Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 17, 2014 10:20PM |
Through self sustaining actions comes freedom
Re: Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 18, 2014 07:06AM |
Can u suggest me the best choice form me? My ideal building area is 25x25x20 (x,y,z). Obviously if there is more area it's better! I'm looking for this iron 3d 12*12*14,bit i hadn't find nothing on the web.Quote
diytechshop
Most RepRap printers can actually do 50-100 microns, though I would suggest somthing with a small leadscrew pitch to keep it tight.
Re: Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 18, 2014 03:39PM |
Re: Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 18, 2014 09:09PM |
pierpaolo9600
diytechshop
Can u help me?
Re: Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 19, 2014 08:55AM |
Re: Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 19, 2014 11:57AM |
Re: Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 19, 2014 12:40PM |
Nice site but i'm searching experiences from users and a full manual for build the reprap. I'm not searching a list of all reprap in the world.
Re: Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 19, 2014 12:50PM |
Admin Registered: 15 years ago Posts: 1,470 |
pierpaolo9600
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 19, 2014 01:16PM |
I'm in love with mendel max 2.0 and iron 3d but i'm not able to find anything online, about building...can you help me ?Quote
NewPerfection
pierpaolo9600
That list is fairly short, and includes only RepRap machines as defined by the RepRap project. Feel free to do some looking yourself to see which designs have good documentation.
Re: Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 19, 2014 01:30PM |
pierpaolo9600
Re: Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 19, 2014 02:44PM |
I just saw this link [reprap.org] and there are a lot of information but not enough to build the mendel maxQuote
NewPerfection
pierpaolo9600
The MendelMax 2.0 is well documented (read here), but has parts that are not easy to make at home (stamped and bent steel sheets).
I can't find much information about the Iron 3D, it doesn't seem to have sources released or documentation available anywhere.
Re: Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 19, 2014 04:55PM |
Re: Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 19, 2014 08:43PM |
Re: Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 19, 2014 08:50PM |
Re: Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 20, 2014 05:17AM |
Thanks for answer! I have yet a mill so i can cut all 2d parts and i can buy at 25 usd all 3d printed parts. I'm doing a lot of research...Quote
vegasloki
The Wiki here and the Mendelmax site along with Maker's Tool Works have more than enough info to build an MM2 including a few detailed manuals. Maxbots has a dropbox in addition to the Gitrhub repo that contains up to date information. They aren't difficult to build but if one has never used a printer I would suggest something a bit less ambitious. As stated the difficult parts to build in a home shop or garage are the basic frame plates/brackets but they are available from a few sources. MTW or searching ebay will return some results. If you have access to a waterjet or mill you can cut your own parts from the comprehensive source files. The bed clips and Maxstruder frame require a radius bend of aluminum but the extruder is available from MTW. You can also fit something like a Greg's if you make an adapter.
Re: Which 3d printer for 50-100 micron resolution? Mendel Max 2.0? March 20, 2014 02:24PM |
