Please help a newbie in the US June 24, 2014 01:41AM |
Re: Please help a newbie in the US June 24, 2014 02:10PM |
Re: Please help a newbie in the US June 24, 2014 02:13PM |
Re: Please help a newbie in the US June 24, 2014 02:22PM |
Re: Please help a newbie in the US June 24, 2014 04:06PM |
Admin Registered: 11 years ago Posts: 3,096 |
MrDoctorDIV
I tried playing with a build using glue paper as the body and wooden dowels as rails. Even at that kind of cost cutting, on paper it was at least $250 [didn't finish planning it out, let alone build it, so I guarantee you it's more than $300 to build one from real materials]
Re: Please help a newbie in the US June 24, 2014 04:55PM |
Re: Please help a newbie in the US June 24, 2014 07:02PM |
MrDoctorDIV
My idea with the paper was to use it similar to wood; flat, cut pieces. Fitted together via duct tape.
I had a problem finding a suitable adhesive findable at Walmart, but I only tried a few before I put the project on the back burner. I've since seen one or two that would work better.
Re: Please help a newbie in the US June 24, 2014 11:03PM |
Re: Please help a newbie in the US June 25, 2014 06:47AM |
Re: Please help a newbie in the US June 25, 2014 10:43AM |
Re: Please help a newbie in the US June 25, 2014 01:03PM |
Re: Please help a newbie in the US June 25, 2014 01:51PM |
Re: Please help a newbie in the US June 25, 2014 01:53PM |
Re: Please help a newbie in the US June 25, 2014 02:50PM |
Re: Please help a newbie in the US June 25, 2014 03:58PM |
kellymc
If it's any help, here's my source list for my i3 Rework. It's my first printer and I'm currently building it.
I'm at a bit over $500 total after picking up various parts I missed like wire connectors and extra nuts and washers. But I was doing much better than that and decided to splurge on a few things like Misumi rods and the E3D hot end, so I think you could definitely get closer to $400 if you want to.
When I was deciding what to build I looked pretty hard at the SImple too. Looks like a great fast way to get started. In the end I felt like I would quickly want to make enough upgrades to push me over $500, so I decided to just start with the i3.
EDIT: Oh, I should mention that most of my vitamins came from Misumi during their $150 credit promo, so I saved a lot there. However, I think you could do as well with a cheaper source. Misumi seems pretty high end.
Re: Please help a newbie in the US June 25, 2014 04:47PM |
Re: Please help a newbie in the US June 25, 2014 05:16PM |
Kurzaa
I bought a Rostock Mini Pro kit from 3D Czar this spring, which is pretty much the limit of my experience. I will say that while I think it was easier to build then an i3, I am finding the calibration and such of the Rostock more difficult then what the i3 might have provided. So I am spending a lot more time on the "build" of the printer then on actually printing things.
As a result, I would suggest you take a moment to think about what you want. Do you want to learn about how 3D printers work or do you want to print 3D objects? I think an i3 would make a good intro to how printers work, and being your first project, you might consider just buying a kit. You won't be saving a lot of cash buying the parts individually, but you would be losing out on a possible source for help if you encounter issues.
On the otherhand, if you are more excited about printing stuff, consider a PrintrBot Simple. The wood kits are around $350 and can be expanded as your interest in the hobby expands. Wednesday nights, Adafruit offers a 10% off code, free shipping on orders over $200, and a free toy for orders over $99.
Re: Please help a newbie in the US June 25, 2014 05:25PM |
Re: Please help a newbie in the US June 25, 2014 07:20PM |
LittleMike
Quick question - why are the printed parts so expensive? It seems that's a big part of the cost.
LittleMike
@vegasloki - The Printrbot Jr - has that been renamed to the Simple kit? $350 isn't terrible, and that would be complete, correct? All I would have to do is assemble it, calibrate it, etc.?
All - does it matter which one I start with? I could always print out at least some of the parts for any other model once I have one up and running, right?
Re: Please help a newbie in the US June 25, 2014 07:34PM |
vreihen
LittleMike
Once you see how many hours it takes to print a complete set of printer parts, you will question why printed parts are so cheap! Figure 2-5 hours for every part, plus a few throwaways for failed prints.
LittleMike
If you decide that you want to build your own printer, having a working Printrbot to both makes parts and later scrounge components from might be a good idea. Otherwise, you can sell it as a name brand printer to someone else when you're done using it.....
Re: Please help a newbie in the US June 25, 2014 10:44PM |
Re: Please help a newbie in the US June 25, 2014 11:39PM |
vegasloki
In the sub $800 range you are pretty much limited to full or partial kit for the most features at the best value. In that price range you'll get the best bang for the buck by building. If you have the patience and ability to do so. It takes moderate technical skills but more than that the ability adapt and not get frustrated.
Print times vary but for me to print a set of Rework parts is just under 12 hours print time. I get about 3 sets from each kg of material so you can base the pricing on that. I use material that costs US$44/kg. A set of parts for a Rework or single pate i3 is around US$35 or so for good prints.
As for selling printers on your own it's going to take you a while before you are ready for that. The initial build and learning curve will likely be a couple of months and then some time after that to know printers well enough to be an informed seller. Not too long after you start printing you'll be able to print parts for your friends and to give away or use for yourself but it takes a bit to learn the ins and outs of getting good prints and finding the optimum configuration for each part.
Re: Please help a newbie in the US June 26, 2014 03:30AM |
Re: Please help a newbie in the US June 26, 2014 05:37AM |
LittleMike
What do you mean by selling it as a name brand? Is that what people are doing? Making their own and then selling them at a profit? I didn't realize you can get a return on investment like that.
Re: Please help a newbie in the US June 26, 2014 11:31AM |
vegasloki
Each set of Rework parts I use is about 260 gr so not quite four sets from a kilo under best case. As for your build, I suggest a Rework for the reasons listed above, availability and support from the community and potentially your vendor. There are other Repraps as well (like the Wilson) or the Printrbot. As for the BOM kellymc posted that's a standard build. That build used Misumi parts so it's going to be a fair bit more expensive than using more generic parts. Here's the Rework entry in the Wiki with BOM, instructions, etc. [reprap.org]
vreihen
LittleMike
Printrbot is enough of a name brand and has a large enough online support community that you can potentially resell the assembled printer when you are done using it to recover some of your investment. Or, if you are into philanthropy, you can donate it to a local library or school.....
Re: Please help a newbie in the US June 26, 2014 01:37PM |
Re: Please help a newbie in the US June 26, 2014 02:20PM |
Kurzaa
Interesting find on the i3 rework, though keep in mind that the shipping on a 10kg printer (does that include the filament?) is close to $170 for US shipping.
Personally, if I had to do everything over again, I think I would have gone with the PrintrBot simple. The wooden kit is unassembled, giving me an idea how everything works, and I could always scavenge it to build an i3 down the road for the larger print surface (which was why I didn't buy one originally). At least going that route I would be printing things (fingers crossed) rather than troubleshooting still.
It sounds like you should be happy with an i3 kit or self-sourced project though, I think there is a lot of help for i3's available online as it seems to be a common design.
Re: Please help a newbie in the US June 26, 2014 03:02PM |
Re: Please help a newbie in the US June 26, 2014 04:55PM |
Re: Please help a newbie in the US June 27, 2014 07:49AM |
vegasloki
They are able to offer that due to a couple of factors. First, the labor arbitrage, second, material and fab costs. There is a thread in the Prusa Mendel section of the forums with some users that bought the kit. The response seems to be positive.
Full disclosure, I've been selling mechanical kits (frames, rods, bearings, hardware, etc) for almost two years now. [stores.ebay.com] Recently I started on a full kit, quality components for around US$500 delivered. It's called the Baja (after one of our dogs) It's a mashup between an sgraber melamine frame changed to work with a Rework, the mrice Rework/Wilson extruder with herrringbone gears and a regular Rework i3. Heated bed, real hotends.com J Head, all US sourced material except the electronics. The electronics are what I'm waiting on now. Initially I was going to use a Brainwave but have since decided to use RAMPS instead. I got a sample from Shenzhen a few hours ago and will test in later today and burn it in for a few days on a machine. Fully documented with basic config files so someone can be up and printing in a short time. Open Hardware that complies with OHWA, sources on Github prior to the machine becoming available and the docs finalized. It will still be 3-4 weeks if all goes well with the electronics and I don't need to find another vendor. I've sold a lot of the frame kits and many have asked why I didn't provide a complete kit so this is a logical step.
In the meantime, the Replikeo looks like a good deal and if you are in the market now it could be a good option for you. My goal is to provide a better value, not necessarily a lower price in that there is support in the US from someone that has been printing for a few years now, quality components and easy to follow documentation.
Here's a pic of the wiring of the prototype. [flic.kr]
Dave
