Re: New print surface material? March 29, 2016 10:11AM |
Re: New print surface material? April 03, 2016 11:16AM |
Re: New print surface material? April 03, 2016 11:46AM |
Re: New print surface material? April 05, 2016 04:22AM |
Re: New print surface material? April 05, 2016 01:16PM |
Re: New print surface material? April 05, 2016 01:27PM |
Re: New print surface material? April 05, 2016 03:14PM |
Re: New print surface material? April 05, 2016 03:35PM |
Re: New print surface material? April 06, 2016 02:07PM |
Re: New print surface material? April 06, 2016 08:49PM |
Re: New print surface material? April 09, 2016 09:54AM |
Re: New print surface material? April 09, 2016 10:32AM |
Re: New print surface material? April 09, 2016 04:04PM |
Re: New print surface material? April 09, 2016 04:09PM |
Re: New print surface material? April 09, 2016 05:23PM |
Re: New print surface material? April 09, 2016 09:38PM |
Re: New print surface material? April 10, 2016 10:03AM |
Mutley3D
Edit: IF after the above you still have issues with your ABS you can seed the bed with a very very weak ABS/Acetone solution, paint it on when cold, then clean the bed again with just acetone and clean cloth/kitchen towel. OR wet a kitchen towel with acetone, drop a short piece of skirt onto the bed and wipe around, and then clean again with just acetone kitchen towel. This should sort you out good and proper. Note that you will only have to do this once! This will greatly increase adhesion with ABS and parts will still self release if not straight away, after the first couple of prints/heat cycles
Re: New print surface material? April 10, 2016 10:34AM |
Re: New print surface material? April 10, 2016 10:39PM |
Mutley3D
When you get ABS adhered correctly it cannot be removed until the bed has cooled off at least a bit.
Re: New print surface material? April 11, 2016 12:41AM |
nebbian
Mutley3D
Interesting. This was (and is) not the case with me, the print could be easily pulled off the bed while hot. I'll play around some more with different temperatures of nozzle and heatbed.
I have many different brands and colours of ABS available to me, I've already tried three on that bed but will try some more.
Thanks for the ideas.
Re: New print surface material? April 11, 2016 06:57AM |
Mutley3D
Thermistor attached underside is going to read higher than your true top surface temp. hence 120c.
Re: New print surface material? April 12, 2016 04:50AM |
Re: New print surface material? April 12, 2016 06:16AM |
nebbian
Can anyone give me some good temperature settings for PLA?
Strangely enough the Printbite PDF doesn't have any suggestions for bed temperatures for common filament types.
Thanks in advance
Re: New print surface material? April 12, 2016 07:42AM |
Re: New print surface material? April 12, 2016 08:08AM |
Re: New print surface material? April 12, 2016 08:57AM |
Re: New print surface material? April 12, 2016 09:05AM |
Mutley3D
Some examples are listed below to guide you.
ABS: Bed 115-125c Nozzle 240-250
PLA: Bed 60-80c Nozzle 220-230
Nylons: Bed 60-100c Nozzle 245-270
PET: Bed 60-90c Nozzle 235-255
PCTPE: Bed 70-90c Nozzle 240-260
Bridge/Alloy910: Bed 65-85c Nozzle 250-270
etc.
Some flexible filaments are an exception to this rule and should be used with slightly cooler bed temps to aid removal as they may adhere a little more than usual.
Re: New print surface material? April 12, 2016 12:57PM |
Re: New print surface material? April 12, 2016 01:22PM |
Re: New print surface material? April 12, 2016 03:48PM |
