Re: New print surface material? April 13, 2016 12:49AM |
Re: New print surface material? April 13, 2016 10:04AM |
Re: New print surface material? April 13, 2016 10:46AM |
Re: New print surface material? April 13, 2016 10:49AM |
Re: New print surface material? April 13, 2016 10:56AM |
Mutley3D
IF after the above you still have issues with your ABS you can seed the bed with a very very weak ABS/Acetone solution, paint it on when cold, then clean the bed again with just acetone and clean cloth/kitchen towel. OR wet a kitchen towel with acetone, drop a short piece of skirt onto the bed and wipe around, and then clean again with just acetone kitchen towel. This should sort you out good and proper. Note that you will only have to do this once! This will greatly increase adhesion with ABS and parts will still self release if not straight away, after the first couple of prints/heat cycles
Re: New print surface material? April 13, 2016 11:07AM |
Re: New print surface material? April 13, 2016 11:55AM |
makerparts
Mutley3D
this confuses me, you basically suggesting a ABS Slury to give adhesion. well you dont need printbite to use a slurry
if this is whats required for abs then forget the printbite, put slurry on glass.. and be done with it. sorry not trying to sound negative but this product is meant to aid in print adhesion
if you need to add another product to make it work. then it doesnt work as intended.
Re: New print surface material? April 13, 2016 12:16PM |
Re: New print surface material? April 13, 2016 12:36PM |
makerparts
if this is something that only needs to happen once and never again. and could affect users. might be something that you should apply to each product before it ships
just incase users do not have a strong enough heat bed.
Re: New print surface material? April 13, 2016 02:46PM |
Re: New print surface material? April 13, 2016 03:05PM |
Re: New print surface material? April 13, 2016 05:06PM |
Mutley3D
WZ9V
Mutley3D, can this be used on printers that probe the bed with a nozzle heated to print temps?
If you are talking about FSR style bed probing, ie hot nozzle hitting bed and registering on a force sensor located somewhere, the answer is Yes it can
Re: New print surface material? April 13, 2016 05:57PM |
Re: New print surface material? April 13, 2016 06:11PM |
Re: New print surface material? April 13, 2016 07:55PM |
Treito
Most reports I have read so far where about a PEI coating on an aluminium surface and I got warned about a nozzle crash. If the nozzle is hot the coating would be seriously damaged. So I never considered PEI and I never will consider it. Not for that price model.
Re: New print surface material? April 13, 2016 08:06PM |
Re: New print surface material? April 13, 2016 08:12PM |
Re: New print surface material? April 13, 2016 08:56PM |
DauerdruckplatteQuote
makerparts
never heard of a pei coating on aluminum, I have a piece of PEI plastic 1/32" thick mounted onto Boro Glass
Re: New print surface material? April 14, 2016 03:37AM |
Re: New print surface material? April 22, 2016 07:59PM |
Re: New print surface material? April 23, 2016 03:25AM |
Re: New print surface material? April 23, 2016 05:32AM |
Re: New print surface material? April 23, 2016 08:06PM |
Re: New print surface material? April 23, 2016 08:37PM |
MightyMouth
I just recieved and installed my Printbite surface. I attached it to my Glass as per the installation PDF and started calibrating as I am using DC42's IR sensor and suspected it would trigger differently.
So I got is all dialled in, ran a test print and the ABS didn't stick at all, just wound up in a nest stuck to the nozzle. My Bed was at 120c verified by laser thermometer and my nozzle at 210c. Tried again and noticed the nozzle was too high so let it cool tried recalibrating the trigger height but it was right on the money so tried printing again and again it was too high so I tried calibrating with the nozzle and bed at print temperatures and it was .12mm out so I ran G30 S-1 every 15 seconds or so while it was cooling down and the trigger height slowly changed from .95 @ 120c to 1.15 @ 21c which if the Printbite or adhesive tape was expanding when hot is the opposite of what I would expect, it seems as though maybe the printbite is becoming more transparent to IR as it gets hot making the trigger height drop.
I am not sure what to do about this. If I was only printing one material then I could just calibrate when hot but if I am printing other materials then the trigger height will be different depending on the bed temperature.
Re: New print surface material? April 23, 2016 09:10PM |
Re: New print surface material? April 23, 2016 09:21PM |
MightyMouth
I'm not sure how the nozzle would cause these readings as the trigger height is decreasing when hot meaning the carriages are closer to the bed whereas if the nozzle was expanding and somehow putting the sensor closer to the bed it would trigger while the carriages were further away showing a higher trigger height unless I am completely thinking backwards.
I usually print at 230c but the ABS I am using at the minute likes 210c for some reason.
I cleaned the bed as recommended before and after 2 heat cycles with 99% pure Acetone.
Re: New print surface material? April 24, 2016 03:07AM |
Re: New print surface material? April 24, 2016 11:04AM |
Re: New print surface material? April 24, 2016 11:35AM |
Re: New print surface material? April 25, 2016 10:26AM |
Dalius98
I see the conversation "detoured" a bit on to PEI vs Printbite, but unfortunately, it ended before I got the answers I was looking for
I will be buying an aluminum tooling plate for my printbed, and the seller is offering a PEI coating for additional 30Eur...
Now I am wondering, what are thickness tolerances of the Printbite and the adhesive used? By using a tooling plate, I expect to get the best flatness possible, and the coating should keep it that way. What about printbite? How much of an effect does it have on bed flatness?
As for printable materials, I see printbite has a nice list of "printable" stuff, is there such a list for PEI? I see (a few posts above) it has trouble sticking to Nylon and PC, anything else?
