Calibration issue with Delta printer March 30, 2016 07:52PM |
Re: Calibration issue with Delta printer March 30, 2016 11:33PM |
Re: Calibration issue with Delta printer March 30, 2016 11:50PM |
Re: Calibration issue with Delta printer March 31, 2016 12:56AM |
Re: Calibration issue with Delta printer March 31, 2016 01:22AM |
Re: Calibration issue with Delta printer March 31, 2016 02:28AM |
Re: Calibration issue with Delta printer March 31, 2016 03:05AM |
Nate523
If I am understanding you correctly, we are making sure that the towers are parallel to each other as far as there length goes.... now I feel a little dumb. Thanks for explaining that though, I obviously needed it. I don't have calipers that big, so I will have to invest in some and see what I can do about that.
The twist seems like a big chore that I don't think that I am equipped to deal with yet, but thanks for all your input, it at least points me in a sensible direction. Its more information than I have been able to find so thanks a ton!
Re: Calibration issue with Delta printer March 31, 2016 03:11AM |
nebbian
A normal set of 150mm calipers should work. When you pull the jaws apart, a little metal rod extends out the bottom. Use that on one tower, and the top jaw on the other tower. Zero your caliper. Now measure elsewhere, and the caliper will tell you how far out you are.
Re: Calibration issue with Delta printer March 31, 2016 02:29PM |
Re: Calibration issue with Delta printer March 31, 2016 02:38PM |
Re: Calibration issue with Delta printer April 01, 2016 02:15AM |
Re: Calibration issue with Delta printer April 01, 2016 03:05AM |
Re: Calibration issue with Delta printer April 01, 2016 03:08AM |
Re: Calibration issue with Delta printer April 01, 2016 03:14AM |
Re: Calibration issue with Delta printer April 01, 2016 03:32AM |
Re: Calibration issue with Delta printer April 01, 2016 04:02AM |
Re: Calibration issue with Delta printer April 01, 2016 04:07AM |
Re: Calibration issue with Delta printer April 01, 2016 04:55AM |
Re: Calibration issue with Delta printer April 01, 2016 05:04AM |
Nate523
When you say right signs, the way I understand it, is that my z max is when I home the machine say it is now at 600mm. Then when I bring it down to the bed, I get a number say like .2mm for it to touch the bed. That would mean it is positive 0.2 for that point measurement correct?
Re: Calibration issue with Delta printer April 01, 2016 10:56AM |
Re: Calibration issue with Delta printer April 01, 2016 11:35AM |
Re: Calibration issue with Delta printer April 01, 2016 11:36AM |
Re: Calibration issue with Delta printer April 01, 2016 11:58AM |
Re: Calibration issue with Delta printer April 01, 2016 12:17PM |
Re: Calibration issue with Delta printer April 01, 2016 01:57PM |
Re: Calibration issue with Delta printer April 01, 2016 02:12PM |
Re: Calibration issue with Delta printer April 01, 2016 02:14PM |
Re: Calibration issue with Delta printer April 01, 2016 06:50PM |
Re: Calibration issue with Delta printer April 01, 2016 06:55PM |
Re: Calibration issue with Delta printer April 01, 2016 08:27PM |
