Re: An alternative to buying a bad kit for $300-500 December 23, 2016 12:22PM |
the_digital_dentist
Auto switching just means that the power input to the power supply can be either 120 or 240V. It has nothing to do with the output voltage.
The chamber heater runs on the line voltage, not low voltage DC. The fan that blows the air over the heater is rated for 24VDC, but would operate very quietly on a lower voltage.
The CubeX machines had 15V power supplies.
The power supply should be marked with the output voltages and current limits.
Re: An alternative to buying a bad kit for $300-500 December 23, 2016 12:37PM |
advancedrescue
the_digital_dentist
I'll inspect it when I get it from my locker today
Re: An alternative to buying a bad kit for $300-500 December 23, 2016 01:25PM |
Re: An alternative to buying a bad kit for $300-500 December 23, 2016 02:16PM |
Re: An alternative to buying a bad kit for $300-500 December 24, 2016 07:03AM |
Re: An alternative to buying a bad kit for $300-500 December 24, 2016 05:16PM |
Re: An alternative to buying a bad kit for $300-500 December 28, 2016 08:17AM |
advancedrescue
All this may or may not get worked on tomorrow, as hopefully my wife gives me my Christmas present tonight which will be the duet wifi board. My mother in law(wife probably ordered for her) got me 2 E3D volcano extruders and hotends. Only issue is I think they got the 12V, which I wanted 24V. It's fine for now, and perhaps for good, I can upgrade to 24V extruders later if I want seeing as how the duet wifi can do both.
Re: An alternative to buying a bad kit for $300-500 December 28, 2016 11:47AM |
Dancook
advancedrescue
I asked for 3D printer/quadcopter stuff from my wife, and I got a die cast airplane coin bank instead... I was thinking "you really don't know me that well do you?" (with a smile)... thankfully, my company gave me a nice bonus this year... I just ordered all the parts I need to build a Delta printer... I'm just a little torn on which controller to get. I'm actually loving my Replicape, but I'd like to try a Duet or Smoothie.
Re: An alternative to buying a bad kit for $300-500 December 30, 2016 06:23PM |
Re: An alternative to buying a bad kit for $300-500 December 31, 2016 07:17AM |
Re: An alternative to buying a bad kit for $300-500 December 31, 2016 07:24AM |
Re: An alternative to buying a bad kit for $300-500 December 31, 2016 07:36AM |
Re: An alternative to buying a bad kit for $300-500 January 03, 2017 07:44AM |
Re: An alternative to buying a bad kit for $300-500 January 03, 2017 08:50AM |
Re: An alternative to buying a bad kit for $300-500 January 04, 2017 12:57PM |
Re: An alternative to buying a bad kit for $300-500 January 04, 2017 01:15PM |
Re: An alternative to buying a bad kit for $300-500 January 04, 2017 01:20PM |
Re: An alternative to buying a bad kit for $300-500 January 04, 2017 01:26PM |
cozmicray
Are we suppose to mine meld and know your printer situation?
Would help to know what printer configuration.
Yes its a CubeX.
What mods? what hot end, PLA?
Firmware?
Firmware settings, slicer settings, bed temp, extruder temperature.
Argh Print is crappy --- don't know anything --- fix it?????
Get a note book -- take notes --- annotate --- that didn't work
adjust one parameter note what it does
soon you will be one with your printer
Re: An alternative to buying a bad kit for $300-500 January 04, 2017 01:56PM |
Re: An alternative to buying a bad kit for $300-500 January 04, 2017 02:12PM |
cozmicray
I am planning on electronics change --- when it pisses me off!
Re: An alternative to buying a bad kit for $300-500 January 04, 2017 02:33PM |
Re: An alternative to buying a bad kit for $300-500 January 04, 2017 07:30PM |
DaGameFace
[attachment 88310 20170104_124644-1316x1449.jpg]
[attachment 88311 20170104_124525-1182x1206.jpg]
I think I need to mess with Jerk and acceleration settings. What do you guys use?
Re: An alternative to buying a bad kit for $300-500 January 06, 2017 05:18PM |
Re: An alternative to buying a bad kit for $300-500 January 06, 2017 05:40PM |
jmar896
Hi everyone,
I have a CubePro duo, same kinematics as the CubeX, that I am also converting to a reprap, I don't frequent the forums and just found this, but I am well into the conversion already (Electronics stripped, hotends removed, RUMBA and PSU already isntalled, just waiting on my new v6's). Before I reassemled the gantry I forgot to check the pulleys on the printer, does anyone know the pully size or steps per MM they put in their firmware?
Thanks
Also if anyone has any questions about the CubePro don't hesitate to ask, my school has one with everything stock (and I'm the only one who knows how to operate it ) and I have this conversion, so I can probably tell you almost anything about it stock or not. I also have a guide I will be publishing to convert the CubePro to reprap.
Re: An alternative to buying a bad kit for $300-500 January 07, 2017 12:11PM |
Re: An alternative to buying a bad kit for $300-500 January 07, 2017 01:07PM |
Re: An alternative to buying a bad kit for $300-500 January 07, 2017 01:28PM |
Re: An alternative to buying a bad kit for $300-500 January 10, 2017 09:45PM |
cozmicray
Just rip out everything?
You could be printing or hassling with wiring, boards firmware
and maybe print in 12 weeks.
Just use it as it is for a bit, learn weaknesses, strong points
Hey I have CubeX duo-- got it for $300 just like new
Used cubeX software
Fed my own filament in
[attachment 88313 benchy2.jpg]
works pretty well?
Re: An alternative to buying a bad kit for $300-500 January 10, 2017 09:56PM |
DaGameFace
Re: An alternative to buying a bad kit for $300-500 January 11, 2017 03:44AM |
obelisk79
I'm going to be the one defending ramps 1.4. It's the cheapest solution, and while the CubeX has solid mechanics it isn't going to be printing at any speed/capacity that board and it's compatible firmwares couldn't support. Others will argue with me regarding quality of cheap chinese boards, I bought mine from a reputable amazon seller and have not had any issues. My print quality went up 300% with just default marlin settings and an E3D clone hot-end. It's not a complete plug-n-play endeavor but if cost is an issue for you, as it was for me, it's a proven electronics that works.
cozmicray
Used cubeX software
works pretty well?
