Cloned titan extruder review/opinion... March 12, 2017 03:51AM |
Re: Cloned titan extruder review/opinion... March 12, 2017 08:56AM |
Re: Cloned titan extruder review/opinion... March 12, 2017 11:39AM |
Re: Cloned titan extruder review/opinion... March 12, 2017 11:31PM |
Re: Cloned titan extruder review/opinion... March 14, 2017 03:27PM |
Re: Cloned titan extruder review/opinion... March 14, 2017 03:48PM |
Re: Cloned titan extruder review/opinion... March 14, 2017 04:08PM |
Re: Cloned titan extruder review/opinion... March 14, 2017 04:18PM |
Re: Cloned titan extruder review/opinion... March 14, 2017 04:46PM |
Re: Cloned titan extruder review/opinion... March 14, 2017 04:51PM |
Re: Cloned titan extruder review/opinion... March 15, 2017 04:44AM |
Re: Cloned titan extruder review/opinion... March 15, 2017 06:44AM |
Re: Cloned titan extruder review/opinion... March 16, 2017 04:25PM |
Re: Cloned titan extruder review/opinion... March 16, 2017 04:45PM |
Re: Cloned titan extruder review/opinion... March 16, 2017 04:56PM |
Re: Cloned titan extruder review/opinion... March 16, 2017 06:05PM |
Re: Cloned titan extruder review/opinion... March 16, 2017 10:27PM |
drmaestro
I actually have a similar setup with 2 Titans (1 is original, 1 is a clone) and the Y splitter. I also use a Prometheus 2.0 hotend. I am actually having difficulties with my setup:
I can easliy manually extrude plastic. I can start printing (single or dual filament) without a problem. However I have a hard time finishing prints, as most of them stop due to an extrusion problem. The problem is as follows:
- The extruder works perfectly for a period of 40 minutes - 2 hours (random), then suddenly there is a clicking sound coming from it.
- When I check I can see that the filament is not advancing, and there is a small kink at the level of the gears.At this point I suspect the nozzle to be clogged but if I pause the print, manually remove the filament, cut it at the level of the kink and reinsert it, and unpause the print, it continues to extrude perfectly, so there is no "static" clog but a "dynamic" one.
- This could be a problem of Prometheus not being able to cope with the filament flow but I doubt it, as I can feed it manually without a problem. Also, as the Prometheus is configurable, I have increased the hot zone's length, so that I can extrude plastic more easily, but it doesn't seem to prevent it. Also, I am printing at 25-30 mm/sec, which isn't fast at all, so feeding speed shouldn't be the real problem.
- Maybe retractions are the reason, but I retract only 2 mm with 40 mm/sec , so this isn't really an extreme retraction.
- Another possiblilty could be the 3/1 gear ratio of the Titan. Maybe it isn't powerful enough for a Bowden setup with the Y splitter (the original creator of Prometheus, Distech Automation, who also created the Y splitter, advises using a 5/1 gear ratio for the Y splitter)
- Another possible culprit could be the design of Titan. Its filament path has an unsupported area just where the filament goes past the gears. This is obvious when printing with flexible materials, as they seem to kink at this level.
Any recommendations?
Re: Cloned titan extruder review/opinion... March 16, 2017 10:30PM |
Re: Cloned titan extruder review/opinion... March 17, 2017 03:14AM |
Re: Cloned titan extruder review/opinion... March 17, 2017 06:23AM |
Re: Cloned titan extruder review/opinion... March 17, 2017 06:46AM |
nebbian
I've had similar issues. Looking at this closely, it seems to be due to using a flat idler bearing, instead of one with a fillet. The flat idler bearing squishes the filament out of round, which then gets stuck partway down the hotend. This is especially visible with PETG, not so much with PLA or ABS.
Try this: Take some filament, insert it a couple of cm past the gears. Release the lever so that the idler is pushing hard on the filament. Roll the gear back and forth a couple of times so that the same spot on the filament goes past the idler a few times. Now release the filament and inspect. Chances are that you'll see a large flat spot on the filament, opposite the tooth marks.
To fix this issue, release the tension screw a lot (I back it off completely, then go forward one turn on the tension adjuster). Try the above test again. In my tests the filament is a lot less squashed. After many failed prints, I eventually discovered this, and got a completed print with much reduced tension.
I'm going to see how easy it is to replace that idler pulley with a grooved one.
Re: Cloned titan extruder review/opinion... March 17, 2017 10:49AM |
Re: Cloned titan extruder review/opinion... March 17, 2017 11:19AM |
Re: Cloned titan extruder review/opinion... March 17, 2017 12:00PM |
Re: Cloned titan extruder review/opinion... March 17, 2017 04:06PM |
Re: Cloned titan extruder review/opinion... March 17, 2017 11:25PM |
Re: Cloned titan extruder review/opinion... March 18, 2017 02:41AM |
Re: Cloned titan extruder review/opinion... March 18, 2017 03:01AM |
Re: Cloned titan extruder review/opinion... March 18, 2017 03:42AM |
drmaestro
Congratulations nebbian, excellent modification. I don't have a grooved bearing. Would the following be ok: Link
The part needs to be quite strong so your suggestion on using PETG is very sound. Do yo think 20% infill is enough?
And a follow-up to my modifications: Yesterday I have printed an object for 4 hours. No clogs or clicking sound, so it probably works. I will test with a flexible filament and also try a longer print and a little bit more retractions (I am down to 1.5 mm which definitely isn't enough for Colorfabb nGen in my setup)
Re: Cloned titan extruder review/opinion... March 18, 2017 08:12AM |
nebbian
Next up: a flexible fllament test I'd been having loads of trouble with this previously.
