Re: Precision Piezo Z-probe Now available. January 25, 2018 06:07AM |
Re: Precision Piezo Z-probe Now available. January 25, 2018 10:55AM |
Re: Precision Piezo Z-probe Now available. January 25, 2018 01:31PM |
Re: Precision Piezo Z-probe Now available. January 27, 2018 04:45PM |
Re: Precision Piezo Z-probe Now available. January 27, 2018 08:24PM |
Re: Precision Piezo Z-probe Now available. January 28, 2018 04:56AM |
ulope
Do any of you have a mounting suggestion (or even a finished model) for the E3D chimera? I've been trying on and off to come up with a proper piezo mount of this for quite some time now but apart from some overcomplicated lever mechanisms I'm not really getting anywhere.
Re: Precision Piezo Z-probe Now available. January 28, 2018 02:29PM |
Re: Precision Piezo Z-probe Now available. January 28, 2018 03:33PM |
Re: Precision Piezo Z-probe Now available. January 28, 2018 05:06PM |
ulope
It's an i3 clone / frankenstein .
Currently I have Chimera mounted via the three holes on the top of the cooler block.
Nitram
Is the fan generating electricity or is it that it is unbalanced ?
Re: Precision Piezo Z-probe Now available. January 29, 2018 04:55AM |
Re: Precision Piezo Z-probe Now available. January 29, 2018 08:14AM |
Moriquendi
Best of luck but I think you'll have difficulty drilling four holes in the ceramic of a 27mm piezo. If you can't get it to work you might try using smaller, undrilled, piezos glued to a sheet of some kind with holes drilled in the sheet. I've had success with 10.5 and 12mm piezos glued or soldered to pcbs.
Idris
Re: Precision Piezo Z-probe Now available. January 29, 2018 08:22AM |
Re: Precision Piezo Z-probe Now available. January 30, 2018 03:08AM |
Re: Precision Piezo Z-probe Now available. January 30, 2018 05:12AM |
That's useful to know, I might try that.Quote
tech-raton
I put some kapton tape around the piezo.
I drilled it (the kapton allows you to reduce the destruction of the PZT)
I'm very glad you're pleased with itQuote
tech-raton
It worked nicely !
Thank you for this simple and easy way to make a Zprobe. I used a switch, a IR probe and finally, the precision-piezo probe. It's a very nice project. I can't go back, the piezo probe is just the right tool for me.
This is a bit of an unknown, shorter is always better but how long you can make the wires before you have problems I don't know, and it's probably different for every machine. I'd suggest trying a longer cable and testing it, one of our customers used shielded wires with the shield grounded, I think he found it helped.Quote
tech-raton
Is there any limitation for the length of the piezo wires?(I've got a Universal kit and I would like to reduce the number of components on the hotend...)
I understand that with the longer cable there is more risks of noise. Is there some reduced sensitivity too?
Re: Precision Piezo Z-probe Now available. January 30, 2018 01:04PM |
Re: Precision Piezo Z-probe Now available. January 31, 2018 01:56AM |
Re: Precision Piezo Z-probe Now available. January 31, 2018 04:19AM |
Re: Precision Piezo Z-probe Now available. February 03, 2018 12:55PM |
Re: Precision Piezo Z-probe Now available. February 03, 2018 01:07PM |
Re: Precision Piezo Z-probe Now available. February 03, 2018 03:07PM |
Re: Precision Piezo Z-probe Now available. February 04, 2018 09:13AM |
Re: Precision Piezo Z-probe Now available. February 04, 2018 11:01AM |
Stopped at height -0.035 mm
16:57:38
16:57:37
16:57:36
16:57:35
16:57:34
16:57:33
16:57:32
16:57:31
16:57:30
16:57:28
16:57:27
16:57:26
16:57:25
16:57:24
16:57:23
16:57:22
16:57:21
16:57:19
16:57:18
16:57:17
16:57:16
16:57:15
16:57:14
16:57:13
16:57:12
16:57:11
M98 P0:/macros/macor
Re: Precision Piezo Z-probe Now available. February 04, 2018 12:41PM |
Re: Precision Piezo Z-probe Now available. February 04, 2018 02:53PM |
Re: Precision Piezo Z-probe Now available. February 06, 2018 09:53AM |
Re: Precision Piezo Z-probe Now available. February 06, 2018 10:13AM |
Re: Precision Piezo Z-probe Now available. February 12, 2018 04:27PM |
Re: Precision Piezo Z-probe Now available. February 13, 2018 02:36AM |
Re: Precision Piezo Z-probe Now available. February 13, 2018 02:51AM |
I think we should call it the Olampe Balanced Piezo concept, unless the man himself would like to suggest a different name
Re: Precision Piezo Z-probe Now available. February 13, 2018 03:42AM |
