Re: Precision Piezo Z-probe Now available. February 25, 2018 02:29PM |
MKSA
DjDemonD
Good idea definitely worth considering. Depends if we go to a microprocessor or stick with analogue. It's worth thinking about as most issues are reverse polarity rather than anything more complicated.
The other advantage of a software solution is that you can better protect the design from the thieves from over there.
Re: Precision Piezo Z-probe Now available. February 25, 2018 04:47PM |
Re: Precision Piezo Z-probe Now available. February 25, 2018 05:08PM |
Re: Precision Piezo Z-probe Now available. February 25, 2018 08:54PM |
Re: Precision Piezo Z-probe Now available. February 25, 2018 11:01PM |
Re: Precision Piezo Z-probe Now available. February 26, 2018 03:10AM |
Moriquendi
Not if you make it open source you can't, that's kinda the point.
I'll do some investigation into the rectifier, however, there are developments coming that might make it unnecessary anyway.
Idris
Re: Precision Piezo Z-probe Now available. February 26, 2018 03:11AM |
Re: Precision Piezo Z-probe Now available. February 26, 2018 03:13AM |
o_lampe
Moriquendi
Idris
*sh1t*, I just ordered the current universal version....
I had hoped the teething problems were already solved. But if the only new feature will be polarity protection, I can live without...
Re: Precision Piezo Z-probe Now available. February 26, 2018 03:45AM |
o_lampe
Re: Precision Piezo Z-probe Now available. February 26, 2018 08:15AM |
Also... your order is already in the post...
Re: Precision Piezo Z-probe Now available. February 26, 2018 10:00AM |
o_lampe
Q: Has anyone used the piezo pcb to probe CNC parts? They often use multidirectional probes. Top/down and sideways. With the right probe head, the piezo would trigger on vertical and also on horizontal touch.
Re: Precision Piezo Z-probe Now available. February 26, 2018 10:05AM |
Re: Precision Piezo Z-probe Now available. February 26, 2018 10:19AM |
Re: Precision Piezo Z-probe Now available. February 26, 2018 10:31AM |
Re: Precision Piezo Z-probe Now available. February 26, 2018 10:43AM |
Re: Precision Piezo Z-probe Now available. February 26, 2018 11:00AM |
Re: Precision Piezo Z-probe Now available. February 26, 2018 11:15AM |
Re: Precision Piezo Z-probe Now available. February 26, 2018 11:23AM |
Re: Precision Piezo Z-probe Now available. February 26, 2018 11:38AM |
Re: Precision Piezo Z-probe Now available. February 27, 2018 02:43AM |
Re: Precision Piezo Z-probe Now available. February 27, 2018 04:13AM |
Re: Precision Piezo Z-probe Now available. February 27, 2018 07:22AM |
Re: Precision Piezo Z-probe Now available. February 27, 2018 08:28AM |
Re: Precision Piezo Z-probe Now available. February 27, 2018 10:53PM |
Re: Precision Piezo Z-probe Now available. February 28, 2018 01:31AM |
Re: Precision Piezo Z-probe Now available. February 28, 2018 03:54AM |
SpectreGadget
I was trying to calculate my new z offset, but I must be doing something wrong. When I try the G30 S-1 command, I get 0.04. Could it really be that small?
Re: Precision Piezo Z-probe Now available. February 28, 2018 03:08PM |
M558 P5 I1 F300 X0 Y0 Z0 R1.0 H15 T3000 A5 S0.03
Re: Precision Piezo Z-probe Now available. February 28, 2018 08:57PM |
tech-raton
Yes, mine is -0.03
Your hotend is probing, so the zoffset is minimum.
The 0.04 is your flexibility and the displacement to trigger.
It can be very small.
DjDemonD
Yes it can be that small but unless you are planning on a 0.05mm first layer you might as well set it to 0.
Re: Precision Piezo Z-probe Now available. March 04, 2018 01:36PM |
Re: Precision Piezo Z-probe Now available. March 07, 2018 12:17AM |
