Re: Precision Piezo Z-probe Now available. April 30, 2018 10:20AM |
Re: Precision Piezo Z-probe Now available. May 03, 2018 05:03AM |
Re: Precision Piezo Z-probe Now available. May 03, 2018 06:11AM |
Re: Precision Piezo Z-probe Now available. May 06, 2018 12:58AM |
Re: Precision Piezo Z-probe Now available. May 06, 2018 03:23AM |
Re: Precision Piezo Z-probe Now available. May 06, 2018 03:47AM |
Re: Precision Piezo Z-probe Now available. May 06, 2018 09:50AM |
Re: Precision Piezo Z-probe Now available. May 07, 2018 02:14AM |
Moriquendi
It's the wiring at the other end that people occasionally get wrong, I don't think that's the case here but it's an easy thing to check and one thing to cross of the list of possible causes.
I suspect that either your ramps has a particularly low threshold or the board I sent you has a particularly high logic low output. I'm happy to send you a replacement but there are a couple of things you could try if you want to solve the problem yourself.
Try putting a resistor between the signal pin and GND, maybe try 10k to start and reduce the value if that doesn't work. Don't go below 1k and make sure that the untriggered signal still goes high enough to resister as logic high (untriggered with M119)
Alternatively you could replace R9 with a higher value (currently 1k), this will reduce the brightness of the red LED and allow the output voltage to be pulled lower, 3.3k might be a good place to start.
Idris
Re: Precision Piezo Z-probe Now available. May 07, 2018 05:29AM |
Re: Precision Piezo Z-probe Now available. May 07, 2018 02:45PM |
So where is the correct one ? There is none in the manuals BTW.Quote
Moriquendi
Thank you, however the schematic you're looking at is out of date, there is no longer an unused opamp.
Idris
Re: Precision Piezo Z-probe Now available. May 10, 2018 11:31PM |
Re: Precision Piezo Z-probe Now available. May 11, 2018 12:58PM |
Re: Precision Piezo Z-probe Now available. May 11, 2018 01:11PM |
Re: Precision Piezo Z-probe Now available. May 11, 2018 03:53PM |
Re: Precision Piezo Z-probe Now available. May 11, 2018 04:01PM |
Re: Precision Piezo Z-probe Now available. May 11, 2018 04:10PM |
Re: Precision Piezo Z-probe Now available. May 11, 2018 04:12PM |
Re: Precision Piezo Z-probe Now available. May 11, 2018 04:39PM |
Re: Precision Piezo Z-probe Now available. May 11, 2018 04:51PM |
Re: Precision Piezo Z-probe Now available. May 12, 2018 11:53PM |
Moriquendi
Idris
Re: Precision Piezo Z-probe Now available. May 13, 2018 03:23AM |
Re: Precision Piezo Z-probe Now available. May 25, 2018 06:32PM |
Re: Precision Piezo Z-probe Now available. May 26, 2018 04:05AM |
Re: Precision Piezo Z-probe Now available. May 27, 2018 03:22AM |
Re: Precision Piezo Z-probe Now available. May 28, 2018 08:03AM |
Re: Precision Piezo Z-probe Now available. May 28, 2018 12:08PM |
Re: Precision Piezo Z-probe Now available. May 29, 2018 06:50AM |
Re: Precision Piezo Z-probe Now available. May 30, 2018 06:27PM |
Re: Precision Piezo Z-probe Now available. May 31, 2018 04:25AM |
