Re: Réalisation imprimante 3D January 21, 2013 01:35PM |
Re: Réalisation imprimante 3D January 21, 2013 01:40PM |
Re: Réalisation imprimante 3D January 21, 2013 01:41PM |
Re: Réalisation imprimante 3D January 21, 2013 01:49PM |
Re: Réalisation imprimante 3D January 21, 2013 02:18PM |
Re: Réalisation imprimante 3D January 21, 2013 02:21PM |
Re: Réalisation imprimante 3D January 21, 2013 05:17PM |
Re: Réalisation imprimante 3D January 21, 2013 05:24PM |
Re: Réalisation imprimante 3D January 22, 2013 02:48AM |
The issue I found was if you have the Mega 2560 instead of the older
1280s then if you also do not have the reset trace cut on the Arduino
mega it will not connect. it's because the auto reset takes longer on
the 2560 vs the 1280. It has soemthign to do with 1280s use FTDI and
2560s use an 8u2 for USB support or it could just be the 2560 takes
longer to get into code from reset
Re: Réalisation imprimante 3D January 22, 2013 04:44AM |
Re: Réalisation imprimante 3D January 22, 2013 04:49AM |
Re: Réalisation imprimante 3D January 22, 2013 05:25AM |
Re: Réalisation imprimante 3D January 22, 2013 05:39AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: Réalisation imprimante 3D January 22, 2013 05:53AM |
Djamuka
pas besoin de prendre le cutter, si tu as de la tresse à déssouder c'est mieux....
Re: Réalisation imprimante 3D January 22, 2013 06:00AM |
Re: Réalisation imprimante 3D January 22, 2013 06:09AM |
Flora
Re: Réalisation imprimante 3D January 24, 2013 10:36AM |
Re: Réalisation imprimante 3D January 24, 2013 10:49AM |
Re: Réalisation imprimante 3D January 25, 2013 05:37AM |
Re: Réalisation imprimante 3D January 25, 2013 07:25AM |
Re: Réalisation imprimante 3D January 25, 2013 08:01AM |
Re: Réalisation imprimante 3D January 25, 2013 10:06AM |
Re: Réalisation imprimante 3D January 25, 2013 10:20AM |
Re: Réalisation imprimante 3D January 25, 2013 10:30AM |
Re: Réalisation imprimante 3D January 25, 2013 10:38AM |
Re: Réalisation imprimante 3D January 25, 2013 10:54AM |
Re: Réalisation imprimante 3D January 25, 2013 12:45PM |
Re: Réalisation imprimante 3D January 25, 2013 05:59PM |
Re: Réalisation imprimante 3D January 25, 2013 06:03PM |
Re: Réalisation imprimante 3D January 26, 2013 06:01AM |
