Re: RAMPS for Due! January 10, 2014 08:00AM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: RAMPS for Due! January 10, 2014 06:50PM |
Re: RAMPS for Due! January 11, 2014 06:44AM |
Re: RAMPS for Due! January 11, 2014 09:00AM |
Re: RAMPS for Due! January 11, 2014 06:59PM |
Re: RAMPS for Due! January 11, 2014 09:07PM |
Re: RAMPS for Due! January 11, 2014 11:15PM |
bobc
Ok, I have committed latest batch of improvements. I have discovered I am somewhat OCD when it comes to having things lined up, oh well
bobc
I did a quick test of reverse polarity using the v1 A design. Applying 12V reversed to the board, both PSUs I used provide power very briefly then cut out due to overload. The 10A fuse did not blow, and there appeared to be no damage to the 1N4004. On testing with a meter though, the diode has failed short circuit, this seems to be a common failure mode for silicon diodes. I should really get a scope on and see how long power is applied.
I don't think we could rely on the diode failing short circuit. That and a combination of slow acting PTC is possibly a source of problems in RAMPS. Hopefully the new design should be more robust.
I had a choice between a TO277 package and DO214AB. They are about the same size, TO277 might be harder to solder as it has a pad under the chip, but seems to have a wider choice of parts although there is not a lot in it. I decided to go with the TO277.
Re: RAMPS for Due! January 11, 2014 11:16PM |
Re: RAMPS for Due! January 11, 2014 11:32PM |
Re: RAMPS for Due! January 12, 2014 10:25AM |
Re: RAMPS for Due! January 12, 2014 11:00AM |
turutk
does the sainsmart due have any compatibility issues with this board?
Re: RAMPS for Due! January 13, 2014 07:42PM |
Re: RAMPS for Due! January 16, 2014 04:38PM |
Re: RAMPS for Due! January 16, 2014 05:14PM |
Re: RAMPS for Due! January 16, 2014 06:06PM |
Re: RAMPS for Due! January 17, 2014 10:28AM |
Re: RAMPS for Due! January 20, 2014 12:40AM |
Re: RAMPS for Due! January 20, 2014 11:30AM |
Cefiar
FWIW: I didn't get an order in for any boards yet, and Chinese New Year has basically put a halt on any new boards out of the place I order from. They won't be shipping anything out till after Feb 7th (more likely later, since I haven't ordered yet), so I won't be getting boards till after that time.
Sorry for the people who asked if they could get them from me.
Note: To the people who sent me email - are you expecting blank PCB's, or finished boards populated with components. I can probably ship you a blank PCB for nothing, but if you want a completed board, I'll have to pass on the cost of parts.
Re: RAMPS for Due! January 22, 2014 06:18AM |
Admin Registered: 11 years ago Posts: 954 |
---- "Let me make my move" ---- |
Re: RAMPS for Due! January 22, 2014 06:51PM |
Gordie
Do you think it's possible?
Gordie
What are your suggestions on raching 1/64th with the RAMPS-FD?
Gordie
Is it true that 1/64th cannot be reached on classic Arduino (16Mhz) due to the low MCU's power calculation?
Gordie
Or is something related to the Firmware?
Gordie
Another point, I need to control some servos and other stuff for a project that I've in mind:
- Is it possible to connect another Arduino trhu the SPI port of the RAMPS-FD?
- If so, can I use the second Arduino board, connected trhu the SPI, to control servos and other things during the printing process?
Thanks to everybody
Re: RAMPS for Due! January 23, 2014 05:24AM |
Re: RAMPS for Due! January 23, 2014 05:26PM |
Re: RAMPS for Due! January 23, 2014 07:56PM |
Re: RAMPS for Due! January 23, 2014 10:46PM |
Re: RAMPS for Due! January 24, 2014 04:40AM |
Traditional version:
- Larger PCB (50 x 100mm).
- 4 current sense resistors to reduce their power and heat dissipation.
- Amplifiers on the output signal of the optocouplers, this will allow the drive to function properly with low current input signals.
- Seperate ground plane for signal and power.
- On board space for voltage regulator heatsink.
- On board space for THB6064 heatsink.
- Easy mounting with 4 fixation holes in each corner.
Special version:
- Smaller PCB (50 x 50mm) reduces cost.
- Driver chip is located outside the PCB for easy mounting on the heatsink.
- Fewer or combined components further reduce cost.
- 2 current sense resistors.
- Unlimited heatsink size for easy chip cooling.
Re: RAMPS for Due! January 24, 2014 10:27AM |
Re: RAMPS for Due! January 24, 2014 11:04AM |
Re: RAMPS for Due! January 24, 2014 12:04PM |
Gordie
Here is the site with schematics and more: [users.skynet.be]
Here is the schematic of Traditional, which I will buy: [users.skynet.be]
So, dear masters, which components do you suggest to change/remove to give it compatibilty to the RAMPS-FD?
I choose this Toshiba component because I was looking for a good Ampere driver, I think that this step driver is good for parallel wiring the step motors as it give up to 4A. Mine RepStrap has dual step motors system on the Z and X axes, so I can save one or two step driver outputs on the controller board. My plan was using the RUMBA or RAMPS and I didn't think about 3.3v when I saw the RAMPS-FD. That's the reason I asked my first question. Thanks for your good work on RAMPS-FD!
Re: RAMPS for Due! January 25, 2014 04:30AM |
Re: RAMPS for Due! January 25, 2014 09:07AM |
