Re: RAMPS for Due! January 25, 2014 01:01PM |
bobc
One issue that I nearly mentioned but didn't was the question of opto-couplers. It seems on the skynet boards, they run off 5V which is provided externally. The optos would sink about 12mA each at 5V, or about 7.5ma at 3.3V which is a bit on the high side for the Due.
The optos also add a small extra delay of 1-2us, which may need to be accounted for.
So I think there is a definite need for a header module with level converter and pulse stretcher. I would like to use the standard pMinMo 10 pin connector, but it takes up a lot of space, so might be tricky. A possibility is to use the 4 pin motor connector for enable/step/dir/gnd, and hope that no one will try to plug an external driver into a Pololu motor output.
bobc
Ok, that is useful info. I will order one of the boards for testing.
Re: RAMPS for Due! January 29, 2014 08:51PM |
Re: RAMPS for Due! January 29, 2014 09:34PM |
Re: RAMPS for Due! January 29, 2014 10:29PM |
Re: RAMPS for Due! January 29, 2014 11:22PM |
Re: RAMPS for Due! January 30, 2014 01:42AM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: RAMPS for Due! January 30, 2014 01:49AM |
Re: RAMPS for Due! January 30, 2014 06:42AM |
Re: RAMPS for Due! January 30, 2014 10:48PM |
Re: RAMPS for Due! February 02, 2014 08:40AM |
Re: RAMPS for Due! February 02, 2014 09:25AM |
Re: RAMPS for Due! February 02, 2014 09:34AM |
Re: RAMPS for Due! February 03, 2014 01:42PM |
Re: RAMPS for Due! February 03, 2014 01:53PM |
Re: RAMPS for Due! February 03, 2014 02:53PM |
cdsteinkuehler
Another question:
I notice the LEDs for the high-current MOSFETS are driven by +5V instead of +V_POWER, and I'm wondering why.
Typcical LEDs have very low reverse voltage ratings (it's 5V for the OSRAM LH R974-LP-1 pulled up by the DigiKey part number in the BOM), and typically don't include specifications for zener or avalanch mode. If +V_POWER is 24V, that puts 19V of reverse bias across the LED, well outside it's specs. Even at 12V the LED is seeing 7V reverse bias...outside it's specification, but not as likely to cause damage as the 19V probably would. I've seen LEDs that begin to conduct under reverse voltages of 7V or less, so this seems marginal even when running on 12V.
Am I missing something that makes this OK?
Re: RAMPS for Due! February 03, 2014 03:03PM |
cdsteinkuehler
...and one more:
In trying to calculate a new operating point for the TLV431 used to clamp the ADC voltage (the BeagleBone has 1.8V Analog inputs), I thought I'd check the existing operating point.
It doesn't look like ANY current is flowing through the exsiting regulator. If the schematic indicated values are correct (R1002=10K, R1003=1.5K, R1004=1K), that's 12500 ohms for the three in series, which puts 2.4V across the 2.5K of R1003/R1004 (2500R * 12V / 12500R = 2.4V). The TLV431 would have to be a battery for OV_REF to get to 3.1V. Unlike the LED issue, this can be easily fixed with value changes.
Re: RAMPS for Due! February 03, 2014 03:13PM |
bobc
I'm confused by your comment though, the TLV431 isn't intended to generate 3.1V, but to sink current if the voltage on OV_REF exceeds 3.1V. That was my understanding of how the protection circuit is supposed to work anyway.
Re: RAMPS for Due! February 03, 2014 03:27PM |
cdsteinkuehler
bobc
Yes, it's a standard shunt regulator (basically a fancy zener diode).
My comment relates to the fact it appers the output is supposed to be 3.1V, but the resistor divider (between the 10K source resistor and the 2.5K reference resistors for the TLV431) is set to generate 2.4V. So the TLV431 won't start shunting current to regulate the voltage until something else brings the voltage above 3.1V. The only thing that can do that here would be the thermistor lines themselves, via the protection diodes, but I don't think that's really what is intended.
Re: RAMPS for Due! February 03, 2014 03:38PM |
bobc
Yes, that IS what is intended, e.g if the thermistor input is accidentally connected to 12V.
Re: RAMPS for Due! February 05, 2014 09:48AM |
Re: RAMPS for Due! February 06, 2014 09:26AM |
Re: RAMPS for Due! February 06, 2014 02:19PM |
Re: RAMPS for Due! February 06, 2014 02:40PM |
bobc
Therefore, without ability to control manufacture or use of the boards, I would rather not define any hard and fast rules for where pin 1 should be on particular connectors.
Re: RAMPS for Due! February 06, 2014 03:58PM |
bobc
There is an issue with homing, which doesn't always seem to work, and I get lots of position shifting during printing, even at low speed/accel. I couldn't find a combination of settings that worked. I suspect it may be something to do with step doubling, because there doesn't seem to be any motor stalls, the print head just goes to the wrong place.
Re: RAMPS for Due! February 11, 2014 05:44PM |
Re: RAMPS for Due! February 11, 2014 05:59PM |
Re: RAMPS for Due! February 12, 2014 02:19AM |
Re: RAMPS for Due! February 12, 2014 12:16PM |
Re: RAMPS for Due! February 13, 2014 12:45AM |
Re: RAMPS for Due! February 14, 2014 09:46AM |
