Re: New MKS SBASE Smoothieware-compatible board from China January 06, 2016 10:24AM |
Re: New MKS SBASE Smoothieware-compatible board from China January 06, 2016 10:41AM |
Re: New MKS SBASE Smoothieware-compatible board from China January 06, 2016 10:44AM |
From what Arthur said above I can't wait for it to come out either but in my case adding 3 more endstops is not going to happen (at least not on this machine) so I hope they get the soft max/min limits integrated.Quote
w3drk
It's frustrating because using Ethernet with Smoothieware rocks. I bet the issue is exactly the same as mine was. Replacing the resonator with a quartz crystal would probably fix it, but without the proper tools it's not exactly trivial without risk of damaging the board.
Hopefully they make things right for you...did you get it on EBay? The seller has actually been very understanding and is sending me a 2nd board to experiment with, but at the moment it seems sticking with an official Smoothieboard is the only safe option unless you don't mine tinkering like me.
To support Arthur's earlier points, this is one reason why these closed source copies are bad. Cost savings backfired, QC missed it, and customers who think they are getting a great deal end up stuck with a flawed board. If Makerbase properly licensed the board as Open Hardware and provided all of the supporting documents (not just schematics...KiCad/Eagle/whatever files, bill of materials, etc. too) issues like this could be avoided because the community would hold the fundamental design to a higher standard and not only focus on profit.
Unfortunately I bought mine before I fully understood how the SBASE came to be. I wanted 1/32 microstepping and liked how it would be a drop in replacement for my MKS-GEN since the sockets are identical, so I chose it over the Smoothieboard. Fortunately I was able to correct the Ethernet flaw and the board works fine now, but next time I'm sticking with an official board. Needless to say I'm looking forward to Smoothieboard v2.
Re: New MKS SBASE Smoothieware-compatible board from China January 06, 2016 10:52AM |
Dark Alchemist
Re: New MKS SBASE Smoothieware-compatible board from China January 06, 2016 11:23AM |
Re: New MKS SBASE Smoothieware-compatible board from China January 06, 2016 11:30AM |
Re: New MKS SBASE Smoothieware-compatible board from China January 06, 2016 11:50AM |
Re: New MKS SBASE Smoothieware-compatible board from China January 06, 2016 11:56AM |
Re: New MKS SBASE Smoothieware-compatible board from China January 06, 2016 12:02PM |
Re: New MKS SBASE Smoothieware-compatible board from China January 06, 2016 12:12PM |
to3dornottobe
That was a time where you could record games from FM radio, at least in our country.. Try to explain that in a few years. That and needle pressure..
Thanks for the tip..
Too bad it's needed though. I guess makerbase will take care of this rather sooner than later.
Re: New MKS SBASE Smoothieware-compatible board from China January 06, 2016 01:45PM |
but apparently the people at Smoothie didn't and from what Arthur said it hasn't been requested much. I bet you because the people who use these expensive boards are mainly Delta bot users and not we Cartesian users. Just a hunch.Quote
to3dornottobe
I agree that a machine should be aware of its maximum X/Y/Z travel, and require a homing sequence before anything else.
Re: New MKS SBASE Smoothieware-compatible board from China January 06, 2016 04:13PM |
Re: New MKS SBASE Smoothieware-compatible board from China January 06, 2016 07:06PM |
w3drk
Re: New MKS SBASE Smoothieware-compatible board from China January 06, 2016 09:31PM |
dc42
Ethernet on Duet rocks even more. You get the DuetWebControl interface.
Re: New MKS SBASE Smoothieware-compatible board from China January 07, 2016 03:23AM |
Re: New MKS SBASE Smoothieware-compatible board from China January 07, 2016 04:12AM |
to3dornottobe
That duet webinterface is ok, but nothing more; I prefer the octoprint interface, because of the nice(r) features. (api for directly uploading gcode to the printer using slic3r), and the drag and drop feature is also nice; it enables you to use plugins to directly upload STL files and slice them using the build in Cura engine. Don't know what makes you say the duet interface rocks even more? I'd say you haven't used octoprint yet, or you would not be saying that? (sorry for my answer, didn't catch much sleep this night, youngest one has growing teeth, while the other couldn't sleep due to growing pains in his legs, so you better come with some right arguments ) Just grab a pi and test octopi, it's well, well worth it. Also capable of wifi printing when hooked up to a pi with a wifi adapter plugged in. Also tried astroprint, which is dream to configure, but it's a bit too much cloud for my likings. Not my (current) style of working
@w3drk; Stay away from the ramps fd. Initial creator (bobc IIRC) turned away; long story short, he uploaded schematics of a proto in his github (v1), china copied (geetech) sold, and it turns out to be a faulty breakout.. Bob turned away from it. V2 is uploaded in his github but it didn't see the daylight.
This is what needs to be done to get it to work; [forums.reprap.org]
I've sourced a duet for about 60 euro, incl. shipping. But configuring smoothie is just a dream. That txt file rocks. Smoothie with a working octoprint environment, that's a good combo. Would be nice if you could adjust the config.txt from within a webinterface/UI type of thingy to make it even more user-friendly.
Re: New MKS SBASE Smoothieware-compatible board from China January 07, 2016 06:39AM |
Re: New MKS SBASE Smoothieware-compatible board from China January 07, 2016 06:44AM |
to3dornottobe
I just fancy octoprint, as well as the android app. It's just more complete.
Re: New MKS SBASE Smoothieware-compatible board from China January 07, 2016 08:15AM |
Re: New MKS SBASE Smoothieware-compatible board from China January 07, 2016 10:15AM |
Re: New MKS SBASE Smoothieware-compatible board from China January 07, 2016 10:27AM |
w3drk
From what I understand Duets are not so easy to come by in the states...but it's good to know RAMPS-FD is a mess, so thanks for the heads up! I have a BeagleBoneBlack so maybe I'll eventually get a CRAMPs board instead and give MachineKit a try.
Re: New MKS SBASE Smoothieware-compatible board from China January 07, 2016 10:30AM |
WZ9V
Duet does not have a US distributor yet but they are quite easy to order from Think3DPrint3D and have them shipped to the US.
w3drk
Re: New MKS SBASE Smoothieware-compatible board from China January 07, 2016 10:33AM |
Remember the British pound seems to be the most valued currency in the English speaking world so pretty much 1.5 times the prices you see for USD (it once was 2x then settled around 1.6-1.7 and I see today it is 1.46 times so all currencies are taking a beating lately as we begin to enter a global monetary depression but that is another topic) plus VERY expensive shipping as I have been told England rapes with the shipping prices.Quote
WZ9V
w3drk
Re: New MKS SBASE Smoothieware-compatible board from China January 07, 2016 10:47AM |
Re: New MKS SBASE Smoothieware-compatible board from China January 07, 2016 01:35PM |
w3drk
My beef with the Duet is in my case both my printers use dual Z steppers and I don't like the idea of splicing two motors to a single driver.
Re: New MKS SBASE Smoothieware-compatible board from China January 07, 2016 02:40PM |
Re: New MKS SBASE Smoothieware-compatible board from China January 07, 2016 02:58PM |
dc42
Why not? There is absolutely nothing wrong with running two series-connected motors from a single driver. Why waste a driver that is better employed to drive a second extruder? The add-on 5V regulator board that RepRapPro shipped (and Replikeo still ships) with their 0.6 Duets includes 3 extra connectors to make it easy to series-connect two motors. From the photo, it looks like Replikeo doesn't actually fit those connectors, but the pads for them are still there.
OTOH connecting two motors in parallel as is typically done on RAMPS is a bad idea, for the types of stepper motor typically used in Repraps.
Re: New MKS SBASE Smoothieware-compatible board from China January 07, 2016 03:02PM |
w3drk
I just never liked the idea of splicing two steppers into one, but I suppose with a nice clean solution like those 3 connectors on the 5V regulator board it does keep things sane. So...I'm considering trying a Duet. Does the Duet support both min and max endstops? I built my Ord Bot with endstops on both ends which is nice to have, but looking at the pictures it seems like there's only connections for one endstop per axis.
Re: New MKS SBASE Smoothieware-compatible board from China January 07, 2016 03:46PM |
Re: New MKS SBASE Smoothieware-compatible board from China January 07, 2016 04:24PM |
to3dornottobe
Those endstops on the extruder motors can be used for an 'out of filament' pause?
