Re: Cherry Pi III Is Available March 14, 2015 08:23AM |
Re: Cherry Pi III Is Available March 14, 2015 10:52AM |
Re: Cherry Pi III Is Available March 14, 2015 02:29PM |
Re: Cherry Pi III Is Available March 14, 2015 03:59PM |
Re: Cherry Pi III Is Available March 14, 2015 04:11PM |
Re: Cherry Pi III Is Available March 14, 2015 04:25PM |
AndyCart
When you plug the PSU into the mains there should be a red led illuminated on the unit. If you short the green and white wires together it should turn green, at which point you should have 12V on the red and black wires.
Re: Cherry Pi III Is Available March 14, 2015 04:26PM |
Really? I've only got a centrifugal fan on mine which blows air only onto the nozzle tip. This one should be on all the time? I thought this was more for solidifying extruded plastic quickly.Quote
dc42
The hot end fan must be wired directly to 12V so that it runs all the time. It's purpose is to keep the top end of the nozzle assembly cool, to avoid the filament melting too high up.
Re: Cherry Pi III Is Available March 14, 2015 04:37PM |
pugzor
Re: Cherry Pi III Is Available March 14, 2015 05:41PM |
Re: Cherry Pi III Is Available March 14, 2015 06:31PM |
dc42
Your centrifugal blower sounds good as a print cooling fan. You need a separate hot end fan to blow air over the cooling fins of the hot end assembly. Usual choice is a 40mmx10mm PC fan.
Re: Cherry Pi III Is Available March 14, 2015 07:14PM |
stuuk
I'm making a variation of the CPII but using conventional ball links.
I'm a little confused on the delta rod lengths
In the description for CPII on thingiverse Andy says he used 250mm rod length but further down it says 200mm rod length
My cross brace extrusions are 250mm but what would be a good length for the delta rods?
Stu
Re: Cherry Pi III Is Available March 14, 2015 07:25PM |
Re: Cherry Pi III Is Available March 15, 2015 02:40PM |
Re: Cherry Pi III Is Available March 15, 2015 05:52PM |
Re: Cherry Pi III Is Available March 15, 2015 06:02PM |
Re: Cherry Pi III Is Available March 15, 2015 06:18PM |
Re: Cherry Pi III Is Available March 15, 2015 06:24PM |
David J
OK - a more sensible question (or seeking clarification, anyway) - am I right in thinking that the Z-probe is activated by the tip of the hot-end touching the bed, and lifting the hot-end support off a microswitch?
It's just that I was looking for something complicated like the one found on a mini kossel, where a probe is set and 'put away' after use, but I couldn't see anything like that in the Thingiverse pictures. This way seems simpler, as long as the hot-end tip is clean...
Also, looking at the effector that came along later for the E3D v6, does that have the Z-probe? I have an E3Dv6 on my Prusa i3, and I'd hope to use another on this printer - but I also wish to use auto-levelling.
Re: Cherry Pi III Is Available March 15, 2015 06:27PM |
Matt,Wheatley
Hi
I have now wired up everything on my cherry pi but I am having a bit of an issue with the stepper motors.
My pairs are Red, Blue and Green, Black. I have wired them Red, Blue, Green, Black in the plugs. When I advance the motor it make a noise and sometimes spins a bit but not consistently every time, adjusting the pot doesn't appear to make much of a difference, the tiutorials say you should wind the pot all the way down, then gradually up. the pots on mine appear to go all the way round without stopping
Any suggestions would be appreciated.
Re: Cherry Pi III Is Available March 15, 2015 06:28PM |
Re: Cherry Pi III Is Available March 15, 2015 06:35PM |
David J
Andy,
That's what I thought! I guessed that it was a mechanical system - I didn't think that it made an electrical connection.
Does the E3D version work in the same way? Or is that the one you're talking about!
I'd really like to see a picture or two of the E3D effector fully assembled, just to get my head around it.
Re: Cherry Pi III Is Available March 15, 2015 06:38PM |
Re: Cherry Pi III Is Available March 15, 2015 06:40PM |
David J
Andy,
Re: Cherry Pi III Is Available March 15, 2015 06:56PM |
AndyCart
My own Cherry Pi has been printing for weeks without me touching the calibration settings. It just works.
AndyCart
You shouldn't need a cooling fan for your JHead. The centrifugal fan is purely for part cooling. It sounds like you have got some debris in the nozzle. Given that the print looked under extruded and them jammed I suspect that is the problem. If you take the Bowden tube out of the hot end and put a short length, about 50cm, of PTFE tube in its place. Get the nozzle to 210 and see it you can manually push filament into the hot end through the short length of tube. It shouldn't require much force. If it does push the filament in and pull it out quite sharply, then discard that bit and repeat. The object is to try and pull the debris out stuck in the melted filament. As soon as you get it you will find the next bit of filament goes through o.k. The other thing to check is the actual temperature. If your thermistor is off it may read 210 but it could be much lower. A cheap IR thermometer is a useful diagnostic tool. Or just increase the temp in 5 degree increments until it's easy to push filament through. Record that temp and use it moving forward.
Re: Cherry Pi III Is Available March 15, 2015 07:09PM |
Re: Cherry Pi III Is Available March 16, 2015 03:21AM |
Re: Cherry Pi III Is Available March 16, 2015 03:27AM |
Re: Cherry Pi III Is Available March 16, 2015 03:43AM |
Re: Cherry Pi III Is Available March 16, 2015 04:50AM |
Re: Cherry Pi III Is Available March 16, 2015 03:24PM |
