Re: Cherry Pi III Is Available March 31, 2015 07:02AM |
Re: Cherry Pi III Is Available March 31, 2015 07:27AM |
Re: Cherry Pi III Is Available March 31, 2015 07:56AM |
Re: Cherry Pi III Is Available March 31, 2015 08:00AM |
pugzor
Andy, I dare you to do a bigger slice of Pi using a Kraken.
Re: Cherry Pi III Is Available March 31, 2015 08:15AM |
Re: Cherry Pi III Is Available March 31, 2015 10:27AM |
Re: Cherry Pi III Is Available March 31, 2015 10:31AM |
dc42
What bothers me about a Kraken is the huge number of cables it needs. A simplistic approach would need 2 per thermistor, 2 per heater, and 2 for the hot end fan, making 18 in all. Some saving could be made by using a shared thermistor ground and a shared +12V for the heaters and fan, but that's still 11 wires, of which one (the shared +12V) would need to be extra thick to carry the current to 4 heaters.
So I have it in mind to design and manufacture a board that mounts on the hot end and does all the hot end temperature control. It would need 2 thick wires for +12V and ground, and about 3 thin wires e.g. for transmit, receive, and signal ground. The main printer electronics would transmit the required temperatures and occasionally thermistor and PID parameters to the board, and the board would send current temperatures along with any error status (e.g. open circuit thermistor). Or I could use thermocouples instead, so that no thermistor calibration is needed.
I would also make provision for connecting a Z probe to the board, so that separate Z probe wires would not be needed.
Does anyone think this is a good idea? The main thing stopping me is that I expect the market for Krakens is quite small, so I might never recoup the time and effort needed to develop this. I am not retired, so I still need to make a living.
The same thing could be done on a smaller scale for 2-nozzle printers, but the benefit in reduced cabling would be lower.
Re: Cherry Pi III Is Available March 31, 2015 11:19AM |
I've just completed this PrntQB V5 (that's Print Cube) as a custom build for a client :-|
Re: Cherry Pi III Is Available March 31, 2015 11:32AM |
Re: Cherry Pi III Is Available March 31, 2015 08:30PM |
dc42
Re: Cherry Pi III Is Available March 31, 2015 10:22PM |
Re: Cherry Pi III Is Available April 01, 2015 03:18AM |
Re: Cherry Pi III Is Available April 01, 2015 04:24AM |
AndyCart
All my designs are based around Bosch/Rexroth or Motedis extrusion which only costs £4.00 per metre in the UK. Not sure what Motedis charge for shipping to Oz, they are a German company. My Bosch/Rexroth supplier is KJN in the UK. I would seriously consider going down the coreXY route rather than using Cartesian kinematics. It's the most efficient system in terms of frame size to build plate size and, next to a delta, gives the best opportunity for fast head speeds. The machine pictured above prints quite happily at 70mm/s. The main costs in my previous coreXY designs have been for precision ground rods and linear bearings but I've now managed to eliminate those. I've also been comparing the merits of a leadscrew and lead nut Z lift compared to using a cheap M8 threaded rod and UHMW leadnut ( homemade by tapping an M8 thread into a 6.2mm hole). So far I can't see enough difference to warrant the high cost of a pair of 500mm leadscrews and two bronze leadnuts (about £40).
Re: Cherry Pi III Is Available April 01, 2015 02:29PM |
Re: Cherry Pi III Is Available April 01, 2015 02:56PM |
Re: Cherry Pi III Is Available April 01, 2015 03:13PM |
Re: Cherry Pi III Is Available April 01, 2015 05:23PM |
Re: Cherry Pi III Is Available April 01, 2015 06:22PM |
Re: Cherry Pi III Is Available April 01, 2015 06:27PM |
Re: Cherry Pi III Is Available April 01, 2015 06:59PM |
Re: Cherry Pi III Is Available April 01, 2015 08:12PM |
David J
It doesn't help that I am unfamiliar with the way that a Delta printer works - the Prusa i3 is self-evident once you've got the configuration right, but I don't know what to expect from a Delta. For example, if you send a 'home' command, where does the effector go? Down to the print surface, or up to the limit switches? Is there any general information on-line to help me? (not necessarily for the Cherry Pi)
Re: Cherry Pi III Is Available April 02, 2015 05:01AM |
But I would like to know how to do it properly, I haven't got the first clue how to measure the amps going to the motor, do you know of a guide that would help to show how it is done correctly. I do have a multimeter and I can just about use it for volts and resistance.|
Re: Cherry Pi III Is Available April 02, 2015 05:48AM |
Re: Cherry Pi III Is Available April 02, 2015 06:44AM |
Re: Cherry Pi III Is Available April 02, 2015 07:48AM |
Re: Cherry Pi III Is Available April 02, 2015 09:01AM |
Re: Cherry Pi III Is Available April 02, 2015 12:44PM |
Re: Cherry Pi III Is Available April 02, 2015 01:44PM |
dougal1957
Eh guys
Just had an E-Mail from E3D announcing a new hotend for £21.50 see E3D V6 Lite ok wont go as hot or fast as a full V6 but will still do ABS at reasonable speeds.
No reason at all to go for Chinese copies now eh.
Doug
Re: Cherry Pi III Is Available April 03, 2015 07:12PM |
dougal1957
Eh guys
Doug
Re: Cherry Pi III Is Available April 03, 2015 10:38PM |
